Turbonetics Detonating on 93 Octane
Old Dec 25, 2005 | 01:28 PM
  #241
kcobean's Avatar
kcobean
Originally Posted by 35ounces
Congrats on solving the issue JET. Thats great news.
So how did you mount it? Is it venting to atmosphere and if so is it LOUD?
Was it the dump pipe causing the issue or what? Trying to understand the issue with the WG angle. Got pics? Thx man.
We know it wasn't the dump pipe (not solely anyway) based on my test of flipping the Evolution gate over and the high boost problem persisting. This was probably a combination of gate size and location, though it would be interesting to see if the Evolution in a different location would do the job...
Old Dec 25, 2005 | 02:12 PM
  #242
JETPILOT's Avatar
JETPILOT
Originally Posted by D350Z10
You should have no problems detonating now... I am almost postive it was your tune before... I talked to my shop about this and they said that they were pretty sure that it had to do somthing with the tune... Since you you have the UTEC you should be set and hopefully have no more problems!!! Along with that IF you look at my pics... my waste gate also dumps out to the atmosphere!! pics.... www.putfile.com/d350z is yours like this????
No... It wasn't my flash. It was my wastegate not operating properly due to poor mounting location per the TN kit.
The flash was fine. 12.5 pounds of boost was not fine.
Respect
JET
Old Dec 25, 2005 | 03:28 PM
  #243
D350Z10's Avatar
D350Z10
IS your wastegate setup like mine by any chance???
Old Dec 25, 2005 | 03:42 PM
  #244
JETPILOT's Avatar
JETPILOT
I'm not using an Evolution gate. I'm using a Turbosmart 48mm gate mounted in a new location. But yes it does dump to the atmosphere.
Respect
JET
Old Dec 25, 2005 | 03:48 PM
  #245
D350Z10's Avatar
D350Z10
I c... Where is the new location? and what spring size are you using in the turbosmart?
Old Dec 25, 2005 | 03:53 PM
  #246
SoFla350z's Avatar
SoFla350z
+1
Do you think that the evolution wg in the new position you put the wg would control the boost? Was it worth that change to keep the Pro1
Old Dec 25, 2005 | 05:46 PM
  #247
kcobean's Avatar
kcobean
Respect
JET
How do you find the sound level to be? I personally couldn't tolerate it based on the one drive I took with the Evolution flipped over and dumping to atmosphere. You looked at gate mufflers or anything?
Old Dec 25, 2005 | 06:11 PM
  #248
JETPILOT's Avatar
JETPILOT
I will post pics of the new wastegate setup and location as soo nas I can.
The spring in the Turbosmart wastegate is 7psi. It boosted 6.5 without a boost controller installed.
The wg is loud as sh*t. But it's only loud on boost. It's tolerable for daily driving if you stay off boost.
I can't estimate if the Evolution would control boost mounted in place of my Turbosmart wastegate. But paying for a custom install I wasn't going to chance doing it again since the mounting flanges for the wastegates are different.
In my opinion the Evolution is best suited to Civic type installs.
Respect
JET
Old Dec 25, 2005 | 06:12 PM
  #249
35ounces's Avatar
35ounces
03 CS Track 6MT
Your right. I thought maybe with a larger gate and the out-of-the-box setup he may have gotten it to work. I am not totally understanding the location issue or how moving the gate will help it flow any better. Maybe pics will help.
Old Dec 25, 2005 | 06:18 PM
  #250
JETPILOT's Avatar
JETPILOT
The exit for the wastegate is 90 degrees off the exhaust flow as provided with the TN kit. Not very efficient. The new gate was oriented with a direct flow of high velocity exhaust. No more inneficient 90 degree turn.
Respect
JET
Old Dec 26, 2005 | 01:42 AM
  #251
prescience's Avatar
prescience
Lucky guess LOL
https://my350z.com/forum/showthread....20#post1904720
Old Dec 26, 2005 | 04:42 AM
  #252
35ounces's Avatar
35ounces
03 CS Track 6MT
Respect
JET
Jet,
How did you mount it so that its not at 90 degrees. Did you weld the flange at an angle or something?
Is the Evolution WG out all togother now too?
Old Dec 26, 2005 | 01:07 PM
  #253
JETPILOT's Avatar
JETPILOT
We welded a pipe to the up pipe and mounted the wastegate to the pipe. Much more efficient mounting. Yes the evolution was removed, and a block off plate was used.
Respect
JET
Old Dec 28, 2005 | 08:22 AM
  #254
35ounces's Avatar
35ounces
03 CS Track 6MT
bump for pics (please)
Old Dec 28, 2005 | 06:18 PM
  #255
35ounces's Avatar
35ounces
03 CS Track 6MT
in case anyone was interested int he pics and didnt see the thread: https://my350z.com/forum/showthread.php?p=1963642
ATI ProCharger
Mar 9, 2004 07:30 AM
cbsuper
Aug 21, 2003 08:13 AM
oscarmayer00
Jul 17, 2003 05:26 PM
jesseenglish
May 28, 2003 02:43 PM
chahny
Apr 1, 2003 07:50 AM
