vortech FAQ: read this before asking vortech questions
Old Jun 28, 2014 | 08:41 AM
  #2161
Conway_160's Avatar
Conway_160
You can get smaller, vacuum hose to run to your BPV. It doesn't need to be that big.
Old Jun 28, 2014 | 09:19 AM
  #2162
crd00's Avatar
crd00
Can i tee into this hose?
Attached Thumbnails vortech FAQ: read this before asking vortech questions-image.jpg
Old Jun 28, 2014 | 10:25 AM
  #2163
crd00's Avatar
crd00
Nevermind. I hooked the bov up to the vacuum hose behind the intake manifold next the the firewall. Thanks for your help!
Old Jun 29, 2014 | 07:52 PM
  #2164
ak350's Avatar
ak350
Originally Posted by lethal3
I have the V2, and it runs insanely hot. is that regular for this supercharger
My v2 runs incredibly hot as well, especially on a warm day. Remember, the housing is going to run hot due to proximity of motor, no direct air flow for cooling, and gears spinning at tens of thousands RPM. Best proven mod I've seen to dat is Titek bumper mod mod to get direct air flow.
Old Jul 14, 2014 | 10:01 AM
  #2165
kilogram's Avatar
kilogram
Edit: fully sorted now.
Next question, how close is that up pipe to your cog belts? Seems too close for comfort, but I think the engine torques away from it under load...
Old Jul 24, 2014 | 10:14 AM
  #2166
Artem_kiev's Avatar
Artem_kiev
Default Vortech V-2 Rev-Up belt size
Hello everyone!
I am running Vortech 2005-2006 350Z "Rev-up" V-2 SQ SCi System (4NZ218-060SQ kit) on my '06 DE Rev-Up 350z European model.
My serpentine belt is about to break and I can't find exact part number for it.
My pulley is stock, which i believe is 3.12 for rev-up kit.
Please tell me part numbers for Gates or Goodyear belts or whatever. Maybe someone knows exact size for it, cause I don't think I'll find Gates in stock in my country.
Thanks!
Old Jul 25, 2014 | 08:01 AM
  #2167
350z006's Avatar
350z006
For the US revup kits:
Goodyear part #4060935
Gate part #K060935
Get the gates belt if you can as it is superior to the stock goodyear belt
Originally Posted by Artem_kiev
Hello everyone!
Thanks!
Old Jul 27, 2014 | 11:51 AM
  #2168
Artem_kiev's Avatar
Artem_kiev
Gate part #K060935
thanks for info! I think i'll order Gates,hope my belt will last till it arrive
Old Jul 30, 2014 | 11:12 AM
  #2169
Artem_kiev's Avatar
Artem_kiev
Just in case somebody will need this info: european analogue of gates part number k060935 is gates 6pk2373. Have changed my belt today - fits perfect.
Old Aug 2, 2014 | 04:10 PM
  #2170
350Z_Al's Avatar
350Z_Al
Can anybody confirm the cog belt pulley size that should be on the blower on a non-rev-up kit.
I bought a rev-up kit cheap, then bought the non-rev-up bracket assembly. Currently have a 32t on he jackshaft and a 32t on the blower. Doing some reading, I think I might need a 28t on thr blower, can anyone confirm?
Old Aug 2, 2014 | 06:29 PM
  #2171
OldManZ350's Avatar
OldManZ350
Cog 32t Jackshaft, 28t Blower
Old Aug 11, 2014 | 01:41 PM
  #2172
RacingBlack350Z's Avatar
RacingBlack350Z
Hey I saw some guys in past builds getting tuner kits for under $4k. Are there any more vendors on here that sell it for that cheap anymore? Cheapest I have found so far is just over $5k.
(For the DE kit)
Old Aug 11, 2014 | 03:05 PM
  #2173
kilogram's Avatar
kilogram
You can piece a tuner kit together for under $2500 if you're looking to save money, just find a used head unit from the mustang kids (hey practically give them away) and the rest of the kit can be bought in pieces from Summit/Superchargersonline. I suggest buying the two really complicated pipes and fabbing the rest of the piping/intercooler. I got my Vortech setup on the road for about $3200 including the DW200 pump, GTR injectors and Uprev tuner.
Old Aug 12, 2014 | 12:04 AM
  #2174
RacingBlack350Z
I'm not trying to be skimpy with my money I have just seen a very wide range of prices so I wanted to see where the best place to purchase a kit would be. I'll look into getting my own kit together, thanks.
Old Aug 31, 2014 | 07:22 PM
  #2175
350Z_Al's Avatar
350Z_Al
Thank you! I've ordered the 28t pulley.
Old Oct 21, 2014 | 03:30 PM
  #2176
ge35es's Avatar
ge35es
subscribed... great writeup... saved me hrs
is there a similar writeup for procharger ? (search owns me)
Old Nov 16, 2014 | 11:44 AM
  #2177
ge35es's Avatar
ge35es
never mind lol purchased the full kit last week so i will probably see it next week
Old Nov 18, 2014 | 12:17 PM
  #2178
415FX35's Avatar
415FX35
Hey guys,
Just wondering what you guys think of my setup for my 04 FX35. I read through this whole thread and pulled together what everyone was using in their setups. I plan to get it tuned using uprev once everything is installed.
-Vortech V3 Tuner Kit with 3.12 pulley - I also have a 2.87 pulley. Do you think it would safe for me to go to the 2.87 pulley with my set up on the stock block? I've read some say yes and some say no. I am shooting for about 400whp but no more than that.
-GTR R35 570cc OEM Injectors
-Uprev GT Maf
-Walbro 255 Fuel Pump (no RFS since I need to pass smog in Cali)
-NGK Iridium Sparkplugs - 1 Step colder
-MotorDyne 5/16" ISO Thermal Space
-Fujitsubo Legalis R 3inch Exhaust
-M2 Performance Y-pipe(Might go back to the OEM HR Y-pipe because I am getting a good amount of rasp)
-Berk Technology High Flow Cats
-PLX Wideband AFR/Boost Gauges
Old Nov 28, 2014 | 12:43 PM
  #2179
BEBO'S ZEE's Avatar
BEBO'S ZEE
Im about to change the oil on my V3 but I was wondering how many of you actually use the full 4oz of oil?
I found this link and saw on a few other forums people having similar issues (oil coming out of the vent plug) https://my350z.com/forum/forced-indu...-oil-leak.html
so I was wondering if I should put in a little less to prevent that same issue?
P&k350Z tracks his car so I could see why the oil will spill out but what about for a street car? Would the 4oz be alright?
Also does the blower have to be removed to change the oil? I figured I could just measure how much comes out and put the same amount of new oil in. Doesn't seem like it needs to be removed unless your checking the oil level...
Old Nov 30, 2014 | 06:23 AM
  #2180
ge35es's Avatar
ge35es
Ive received my vortech non revup complete kit and everything is there and I have questions
1) reviewing the instructions i dont see anything about assembling the cog belt idler pulley so any pics or diagrams would be greatly appreciated
2) i have the Paxton black box as mentioned i the instructions P# 5A001-353 BUT...
I also received a larg black carton labeled Unidchip with a hand written sticker 5A003-350 containing a Q+ 0148D silver device and a slighty larger black device with no real model number except it has unichip PNP technology. There is nothing about the unichip boxes in the instructions but they themselves came with instructios.
do i use both systems ? or just one of them ?
