vortech FAQ: read this before asking vortech questions
Old Mar 17, 2014 | 06:49 PM
  #2121
crd00's Avatar
crd00
anyone else agree if this is a good set-up?
Old Mar 17, 2014 | 06:56 PM
  #2122
IcanHaz's Avatar
IcanHaz
Yes I agree it's a good set up, should be all you need.
Old Mar 26, 2014 | 10:55 AM
  #2123
tukeeg35's Avatar
tukeeg35
Does anyone know off hand what fabbing would need to be done to make a Z kit fit a G coupe?
Thanks
Old Mar 26, 2014 | 01:53 PM
  #2124
str8dum1's Avatar
str8dum1
none.
Old Mar 26, 2014 | 09:37 PM
  #2125
tukeeg35's Avatar
tukeeg35
Awesome, thanks.
Im having a hell of a time with the drivers side IC pipe mating to the cast up-pipe, and I saw on the first page Sentry wrote
Originally Posted by sentry65
- the 350Z and G35 vortech kits are a little different. Some custom fabbing of the piping has to be done to make one fit in the other type of car
so I was just curious
Old Apr 3, 2014 | 05:20 PM
  #2126
Guilty1s's Avatar
Guilty1s
anybody looking to trade a 3.12 for a 2.87.
Im also in search of a 28T cog pulley for behind the SC
Old Apr 17, 2014 | 10:12 AM
  #2127
kbailey91's Avatar
kbailey91
Default need help/advice for v3 setup
i am new to posting and to my350, so i am hoping y'all can help. No need to bash just provide useful knowledge or insight to help a fellow member.
i have a 03 track model 350 so non rev up with about 115k miles (most of them hwy miles due to commute about 30miles a day). Car is very well taken care of and never had 1 mechanical issue.
it has been driven with just CAI, hi flow cats, borla exhaust and there was plenum spacer installed a while back.I finally wanted to get into something quicker so decided to go FI rather than buy a new car as i love my z.
i bought a v3sci tuner kit, dw600, intank walboro fuel pump, 1 step colder ngk plugs, an oil cooler and catch can, long tube headers to get rid of cats also have full set of gauges including wideband a/f. I will be using uprev osiris to tune.
i bought the 2.87 pulley to upgrade right away as i want to be over 400whp but really no more than 500.
with the supporting mods i have, and the state of the car being a DD and my goals in mind, is there anything else i need to get/do to accomplish and have a well built and functional Z.
(fyi- vortech said i need to machine the pulley to get it fit the jackshaft, is this true? do i need a smaller belt to run the smaller pulley, and if so what size? the dyno shop in AZ said i should 100% replace the rods, pistons, and bearings since they have seen many z's (DE) fail right on the dyno going over 380whp... is this true, and if so can anyone suggest what to replace with?)
Thanks again for the help!
Old Apr 17, 2014 | 10:24 AM
  #2128
Staisman's Avatar
Staisman
I have similar setup (here is my build https://my350z.com/forum/forced-indu...n-03-350z.html), with 3.12 pulley pushing 427 Whp and 370 torque. I think 2.87 will bring you close to 450 and 400 torque which is too much for the DE engine. If you want to do it right the first time - build your motor, especially with 115K miles on it. For the 500 whp you can go with Eagle or K1 rods and Wiseco pistons. Everything you need is here on this forum was posted many times, tons of different builds, so use search.
Old Apr 17, 2014 | 10:38 AM
  #2129
kbailey91's Avatar
kbailey91
Thank you for the insight. I dont want to go that high and think that right now i may just swap out the pulley and run somehting like your set up and then when the motor goes due the rebuild then... i know its a matter of opinion (build now or later). So if i dont want to build the motor now, i can run the 3.12 pulley with what i have not replace the internals and get over 400 correct?
Old Apr 17, 2014 | 11:00 AM
  #2130
Staisman's Avatar
Staisman
You can run any pulley with your stock internals but nobody can tell you when your engine will give up. You have to be ready it will give up sooner or later and no matter what pulley you are running. I know mine won't last long because i am pushing it, so I am building an engine right now.
Old Apr 17, 2014 | 11:17 AM
  #2131
kbailey91's Avatar
kbailey91
completely true. i think i will keep the smaller pulley for future.. run the 3.12 and rebuild once the motor goes and then drop in the 2.87. Is there anything else you did or you can think of that would be good to add to the current setup i'll be running?
Old Apr 17, 2014 | 11:49 AM
  #2132
Staisman's Avatar
Staisman
I would also recommend Fuel Return System from CJI. Get stage 0 it will help with tune other than that you are good to go.
Old Apr 17, 2014 | 11:50 AM
  #2133
- bigc -'s Avatar
- bigc -
Originally Posted by kbailey91
...(fyi- vortech said i need to machine the pulley to get it fit the jackshaft, is this true? do i need a smaller belt to run the smaller pulley, and if so what size? the dyno shop in AZ said i should 100% replace the rods, pistons, and bearings since they have seen many z's (DE) fail right on the dyno going over 380whp... is this true, and if so can anyone suggest what to replace with?)
This post (from a few pages back in this same thread) shows you what needs to be machined on the 2.87" pulley:
https://my350z.com/forum/10120022-post2095.html
Old Apr 17, 2014 | 12:23 PM
  #2134
kbailey91's Avatar
kbailey91
staisman and bigc, thanks for the input ill check them out. and if anyone else or if you guys want to add anything, the input is welcomed.
oh also i forgot, is upgrading the MAF to the uprev MAF a good idea with this setup im looking at?
Old Apr 17, 2014 | 12:37 PM
  #2135
Staisman's Avatar
Staisman
Yes, factory MAF u will get maxed out at around 400 whp.
Old Apr 17, 2014 | 01:43 PM
  #2136
OldManZ350's Avatar
OldManZ350
what are you using for Tuning?
Old Apr 17, 2014 | 01:44 PM
  #2137
OldManZ350's Avatar
OldManZ350
Not True, depends on what you control it with.
Old Apr 17, 2014 | 01:59 PM
  #2138
Staisman's Avatar
Staisman
Old Apr 17, 2014 | 03:22 PM
  #2139
OldManZ350's Avatar
OldManZ350
With uprev you will need to upgrade.
Old Apr 17, 2014 | 03:59 PM
  #2140
kbailey91's Avatar
kbailey91
great thank you
