Official STS Rear Mount Turbo Discussion Thread
Old Sep 14, 2011 | 07:04 AM
  #2641
nissan boy's Avatar
nissan boy
no bad but for the spark plugs you really want to go with hks plugs
Old Sep 14, 2011 | 10:19 AM
  #2642
str8dum1's Avatar
str8dum1
^pretty solid OT 1st post. you should fit in well.
Old Sep 15, 2011 | 08:06 AM
  #2643
streetzlegend's Avatar
streetzlegend
Wanted to post some possible useful information for everyone running stock 2" sts piping.
I upgrade to 2.5" from turbo to intercooler and it made a major difference in spool up, responsiveness, less pressure drop. All changes were to the good, I should have done this 4 years ago. No dyno or logs yet, but I am confident that intake temps also might have gone down.
Old Sep 15, 2011 | 08:23 AM
  #2644
WASHWIZ's Avatar
WASHWIZ
Are you using the standard STS turbo?
Old Sep 15, 2011 | 08:53 AM
  #2645
streetzlegend
No, I actually do not have an STS kit. I have a custom one and have been using 2" piping all these years. (which i believe is the same size piping STS comes with standard). The turbo I have is an HX40Pro Holset, .70AR turbine housing bep
Old Sep 16, 2011 | 05:11 AM
  #2646
WASHWIZ's Avatar
WASHWIZ
Ok, you have the max w/ the 3.5? Keep us updated.
Old Sep 18, 2011 | 08:36 AM
  #2647
streetzlegend
Yeah that's me. Sure ill update, I'm putting an mrevII manifold then dyno.
Old Sep 19, 2011 | 10:59 AM
  #2648
athenG's Avatar
athenG
Good to know, keep us posted... I'm leaning of redoing my charge pipes since they are pretty much rusted (just the back portion). I was the first one to have the charge pipe modified and re-routed in the middle so all the pipes wasnt jethot coated
Old Sep 19, 2011 | 07:21 PM
  #2649
streetzlegend
Yeah same here, I was using regular exhaust shop piping (steel), was rusting and heavy, plus too small. The only small issue I am having is boost leaks, I used oval piping and I am having a hard time tightening the clamp on the flat parts of the pipe (top n bottom), using worm gear clamps. I might have to wedge something between the clamp and the coupler to push down in the middle.
Old Sep 21, 2011 | 10:41 AM
  #2650
rawley_12003's Avatar
rawley_12003
i have my pipe running along the passenger side if i re-route the pipe would i see better gains?
Old Sep 22, 2011 | 07:49 AM
  #2651
rawley_12003
ok guys finally got my longblock in from IPP last week and was talking to them and said the only people that where having issues with their built engines where rear mount turbo kit cuz of lack of oil. Has anybody ran into this issue, or does anybody here with a built motor ran into this issue is so what did you do to remedy this issue? thanks
Old Sep 22, 2011 | 12:33 PM
  #2652
str8dum1's Avatar
str8dum1
what does he mean lack of oil? obviously you need to adjust the amount of oil added to your tank to account for filling that long turbo oil feed and return.
Old Sep 22, 2011 | 06:28 PM
  #2653
rawley_12003
well thats what i said to them lol... ok good. well my z should be done within a couple of weeks.
Old Oct 4, 2011 | 07:09 AM
  #2654
rawley_12003
Well i just ordered some injected performance motor mounts before the engine is installed has anybody tried these?
Old Oct 19, 2011 | 01:52 PM
  #2655
lambo4life55's Avatar
lambo4life55
I recently purchased a used sts kit, Does anyone have the install instructions booklet they can e-mail or fax to me? or at least point me in the right direction on where I could find this info. Thank You
Old Oct 20, 2011 | 05:33 PM
  #2656
rawley_12003
call sts turbo i'm sure they have those for cheap.
http://www.youtube.com/watch?v=Y8bG9uf0j9c
http://www.youtube.com/watch?v=q4XYt...eature=related
Thought i post some vids.
Old Oct 21, 2011 | 12:42 PM
  #2657
athenG's Avatar
athenG
nice... any slip?
Old Oct 23, 2011 | 01:08 PM
  #2658
rawley_12003
i did have at one time but i think all i was running where 13.6 all night at 309whp.
Old Oct 24, 2011 | 07:26 PM
  #2659
n2deepnot2keep's Avatar
n2deepnot2keep
I had an ipp engine on a sts kit and my engine failed due to lack of oil this is after replacing the p.o.s Chinese built pump with a example pump. I saw the pump working when it was tested with my own eyes.
My engine went the same day I picked it up.
Kyle did not warranty the engine nor did he refund my core charge from my original engine.
Don't expect your $ back if if engine goes bang.
Good luck with your build, I'm going with the momentum kit now.
Old Oct 25, 2011 | 06:44 AM
  #2660
str8dum1's Avatar
str8dum1
how did you get a lack of oil? even if the pump failed, the turbo would overflow with oil but woudnt be enough to drain your motor of oil. And if the seal on the turbo actually went, your car woulda been smoking like a forest fire well before your oil pressure went low enough to kill the engine.
anyone that has to use a oil sump pump is absolutely crazy not to have an oil pressure gauge.
