Official STS Rear Mount Turbo Discussion Thread
Old Oct 27, 2012 | 06:05 PM
  #2881
rawley_12003's Avatar
rawley_12003
hmmm thats odd.... the only thing i have thats heat wrapped are the stock manifolds.
I'm having issues as well and its starting to **** me off. well i'm having a vibration noise and its very bothesome, I notice it more on 6th gear at around 50 to 60mph. Here is what has been changed recently since i was going to change them out anyways. I changed out all wheel bearing(timken). Just changed out the axles with new stock axles from autozone(duralast) and swapped out the entire diff and pumpkin from a another z with very low miles. The only thing i can think of is the propeller shaft, diff bushings, transmission bushing. I have rotated the propeller shaft like the fsm tells me too but still have vibrations but not sure if it propeller shaft i don't want to throw $700 away on a brand new shaft. I guess i will change bushings on diff and transmission and go from there huh.. this has been very annoying.
Old Dec 14, 2012 | 07:01 PM
  #2882
rawley_12003
any help still having this issue its either the propeller shaft or clutch or transmission. Has anybody had this problem this vibration is making me not want to drive my z since i can't pin point the issue.
Old Dec 15, 2012 | 12:26 PM
  #2883
str8dum1's Avatar
str8dum1
best bet is to make a new thread about it in the engine and transmission forum.
Old Dec 26, 2012 | 03:54 PM
  #2884
rawley_12003
no luck yet but next month i'm dropping the transmission for the new clutch and flywheel install and i will inspect further into the issue checking the trans mount and have the driveshaft checked for balancing.
Old Jan 17, 2013 | 06:47 PM
  #2885
rawley_12003
how is it going guys thought i drop by and show you what i have been messing around with. Plasti dip monster green paint.
Old Jan 17, 2013 | 07:19 PM
  #2886
2004Black350z's Avatar
2004Black350z
Exhaust Whore
yikes
Old Jan 18, 2013 | 03:20 PM
  #2887
rawley_12003
you don't like it lol..
Old Jan 18, 2013 | 03:39 PM
  #2888
2004Black350z
Exhaust Whore
We all have different taste. I love monster lol
Old Jan 18, 2013 | 07:25 PM
  #2889
rawley_12003
i get alot of thumbs up for the color lol
Old Feb 17, 2013 | 06:56 PM
  #2890
rawley_12003
question guys i'm looking at upgrading my y-pipe megan racing and already have the z1 plenum spacer not installed yet. Will this greatly affect my tune oh i just installed the 3.3 fd gears and love them
Old Feb 19, 2013 | 10:23 AM
  #2891
athenG's Avatar
athenG
it's hard to tell what will be the effect but if it was my car then I'll just install it and do some logs before I decide if i need to re-tune... i forgot what ems do you have? if it was a standalone then it maybe able to do some minor adjustment if the change isnt that much.
Old Feb 19, 2013 | 03:48 PM
  #2892
rawley_12003
well i'm about a month away from my dyno tune to 500+whp. hence why i'm asking i will be upgrading my clutch (soutbend) light weight flywheel (Z1motorsports) bigger fuel pump (walbro) and z1 plenum spacer. I have the haltech pro for the 350z.
Old Feb 19, 2013 | 06:08 PM
  #2893
2004Black350z
Exhaust Whore
What made you go z1 spacer jw
Old Feb 19, 2013 | 07:41 PM
  #2894
rawley_12003
well i didn't want to drop alot of cash for a cosworth or the kinetix ssv, but i did have the kinetix v+ but was hesitant to use when i saw it flexed when revving so i sold it. But i still wanted to get a bit more air in to the forward cylinders but not lose my oem strut bar. Was buying the z1 spacer a bad idea?
Old Feb 20, 2013 | 08:05 AM
  #2895
athenG's Avatar
athenG
how the 3.3 FD? was it a noticeable difference?
Old Feb 20, 2013 | 08:39 AM
  #2896
rawley_12003
3.3 is great to stay in gear longer. 2nd gear i still breake loose and 3 and 4 actually stay planted to the ground pretty good after tire warm up. My z is a base so i don't have to worry about cruise control being a problem. But i think this is a great upgrade if you goin to hit 500 whp from what the other guys on the forum have said. You get to feel the power instead of eating up tire all the time
Old Feb 20, 2013 | 10:14 AM
  #2897
athenG's Avatar
athenG
what is your HP right right now? does it make a difference on the sts on lower power let say 400whp and on the lower gears (1st and 2nd gears)? I'm worried about the lag in the lower gear with STS. if the RPM doesnt climb fast enough then the turbo may not spool fast enough on lower gears. I know in higher gears it may not be a problem.
Old Feb 20, 2013 | 08:13 PM
  #2898
rawley_12003
well i'm currently 407whp and 392 tq and i don't see a problem really it still spools like the same to me but i have not noticed a difference really tires still spin and in 2nd and 3rd sometime but 4th still feel pretty good. The guys on the forum recommend it with 500whp. I will find out how it feels next month i will be having the clutch and flywheel and bigger fuel pump and still need a 750 mile break in. So i will be posting up videos of dyno.
Old Feb 20, 2013 | 08:14 PM
  #2899
rawley_12003
Old Mar 20, 2013 | 07:48 PM
  #2900
rawley_12003
latest dyno run
