Official STS Rear Mount Turbo Discussion Thread
Old Oct 28, 2007 | 10:05 PM
  #781
aarantes's Avatar
aarantes
Originally Posted by Cube
Hey, I was wonderin, anybody ever heard of the STS single turbo kit? I heard Camaros and Tacomas and even Corvettes are putting their turbos in the rear, anybody ever try it on a Z???
lol... anyways, is it just me or are people hearing about 2 instances now of stuck-open injectors due to an STS install...? One engine-destroying and the other... not?
Yes I got that PM he said only one was stuck open and mine had 5 stuck open...
BTW sent the utec and injectors to STS because they wanted to test them I will let you guys know as soon as I do.
Old Oct 29, 2007 | 05:05 AM
  #782
Ahsmo's Avatar
Ahsmo
Imakecopies
Originally Posted by zmedic16
does this kit fit the 06 rev ups/??
yes, I don't see why not.
Old Oct 29, 2007 | 05:21 AM
  #783
goosegoose's Avatar
goosegoose
Side question. Exactly how can you tell whether one of your injectors are stuck or not after the kit is already installed and running?
Old Oct 29, 2007 | 09:53 AM
  #784
ramairZ's Avatar
ramairZ
Default stuck injector
aarantes and goosegoose, I look forward to your reply on my PM.
My kit was installed but car ran extremely rich. Exhaust smelled like raw gas and had white gas vapor coming out of tail pipe, have a video. If you struck a match the car would become a flame thrower. We first thought problem was a defective injector due to wet sparkplug on #2 cylinder. Swapped injector to another cylinder and #2 still flooding out. So problem was the UTEC. Process of elimination.
I'm curious to know how many STS users had problems with poorly programmed or totally defective UTECs. aarantes, I'll bet your problem was a defective UTEC also.
Old Oct 29, 2007 | 10:08 AM
  #785
DanielW's Avatar
DanielW
^^interesting, I wonder how they go about programming the UTECs
Old Oct 29, 2007 | 10:12 AM
  #786
athenG's Avatar
athenG
I once had a problem but mine suddenly became lean in the middle of a cruise that I attended last week. I came at the meet around 11am and I was running fine. I had my Laptop plugged in and was doing some logging the entire cruise but after 3 hrs of driving, I start to hear my Laptop buzz (UTI does give sound when Knock is detected) and my A/F was around high 12's to mid 13's. It doesn't matter what I do with the Temp Correction coz my A/F was the same. I thought my Inj failed on me so I just went back home and unplugged the battery and let it cool down for around 5hrs. Guess what!!! The chit all went back to normal!!! It wasn't even that hot that day coz it was only high 70's.
Old Oct 29, 2007 | 10:13 AM
  #787
athenG's Avatar
athenG
I don't think it is anything programming coz all they do is load a Base map which even Sharif verified it was right.
Old Oct 29, 2007 | 11:15 AM
  #788
ramairZ's Avatar
ramairZ
I'm not a computer type person but is'nt the base map a computer program? Could be a glitch in the base program causing UTEC problems. I had first UTEC swapped. Second unit went rich within 6 days,100 miles. Second UTEC needed professional programmer/tuner attention to get to operate correctly. I now have about 700 miles on the repaired/tuned/programmed second unit. Keeping my fingers crossed as to NO more computer problems.
Old Oct 29, 2007 | 11:30 AM
  #789
athenG's Avatar
athenG
If you were fine the first few days then the map was not the culprit but I could be wrong. I'm no a Utec expert but based on looking at the Maps, all i can see is Pulse Width #'s on the Fuel Map and not specific on which injector.
Old Oct 29, 2007 | 11:35 AM
  #790
aarantes's Avatar
aarantes
Ramairz I will pm you as soon as I work out everything and get it all figured out.
But I do think its strange that we both had utecs that caused injectors to be stuck open... I thought it was just my unit and that I had a freak accident but this makes me wonder. All I can do is wait for the tests to be done.
Old Oct 29, 2007 | 01:13 PM
  #791
athenG's Avatar
athenG
I thought you guys sent the Inj. to a third party for testing?
Old Oct 29, 2007 | 02:47 PM
  #792
aarantes's Avatar
aarantes
Sharif was suppose to do that but he got to busy to deal with me so he said he was just going to uninstall it and I could deal with it. I don't think its the injectors its either utec or the install.
Old Oct 29, 2007 | 03:26 PM
  #793
ramairZ's Avatar
ramairZ
The installer did just that, installed what came with the kit. I would only place blame on installer if they broke a part. Defective parts are not their fault.
Old Oct 29, 2007 | 03:32 PM
  #794
aarantes's Avatar
aarantes
Yeah Im not jumping to conclusions that is why I wll wait for the test results.
Old Oct 29, 2007 | 03:38 PM
  #795
ramairZ's Avatar
ramairZ
Hope STS is going to be honest with you. Sending parts to them for inspection could be like the "fox guarding the hen house"
Old Oct 29, 2007 | 03:39 PM
  #796
athenG's Avatar
athenG
Hey ramairZ, what mod do you have and how much power are you pushing?
Old Oct 29, 2007 | 03:42 PM
  #797
ramairZ's Avatar
ramairZ
Car is stock besides the STS kit. 335hp/304tq
Old Oct 29, 2007 | 03:44 PM
  #798
athenG's Avatar
athenG
Are you running of the base map that came with it or this is with a full Tune? What dyno is it?
Old Oct 29, 2007 | 03:47 PM
  #799
ramairZ's Avatar
ramairZ
Those numbers are at 6.75 boost on a 5AT
Old Oct 29, 2007 | 03:48 PM
  #800
athenG's Avatar
athenG
Not bad!
oh, are you the guy from G35driver?
