06 Revups w/ Utec please step in!
Old Aug 17, 2007 | 07:45 AM
chris'smax's Avatar
chris'smax
Default 06 Revups w/ Utec please step in!
Have any of you had any serious issues w/ tunning the Utec on the 06's? From what i have gathered the 06's seem to be a little more finiky when using the utec and produce a rough transition into boost. Any input would be appreciated.
Thanks
Chris
Old Aug 17, 2007 | 07:48 AM
TENGAI's Avatar
TENGAI
Rev-Ups have a little more timing in the lower RPM range, so you'll definately want to flash the stock ecu and attempt to "balance" out the transition point where the UTEC takes over... Or, you could just go with a stand-alone EMS and bypass the problem all together
Old Aug 17, 2007 | 08:06 AM
chris'smax's Avatar
chris'smax
can you describe the transition smoothness issue? Is it just not as smooth as it could be or will it really affect daily drivability?
Old Aug 17, 2007 | 08:29 AM
Alberto's Avatar
Alberto
Cranky FI Owner
My buddy had an 06' with a UTEC on a TN setup and it hiccup'd like crazy. SOme days would be almost perfect other days with its hesitations and such. Countless retuning couldnt figure it out...
Old Aug 17, 2007 | 08:33 AM
chris'smax's Avatar
chris'smax
which ems solution did he end up going with?
I hate to say it but i am really interested in the f-con IS due to it video output feature, but it is still just a piggy back
Old Aug 17, 2007 | 08:39 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
actually, the rev ups are the smoothest transitioning utec cars there are.
if you know what you are doing...
the 05s non rev ups are the problem for sure.
Old Aug 17, 2007 | 10:01 AM
Alberto's Avatar
Alberto
Cranky FI Owner
chris'smax-he ended up selling the kit and all the mods, he got tired of it. Could never get it running right...car ran a best of 12.5 @ 111mph with my slicks-him driving.
Old Aug 17, 2007 | 11:01 AM
QuadCam's Avatar
QuadCam
I have no transition problems ('05 Revup) switching from ecu to utec. sometimes, I do get a 'lil kick when letting off the throttle though.
It took some part throttle tuning to get the ecu and utec to blend, but I imagine that's normal for all utec tunes
Old Aug 17, 2007 | 11:11 AM
chris'smax's Avatar
chris'smax
thanks for the input guys, keep the reviews coming!
Old Aug 17, 2007 | 01:06 PM
athenG's Avatar
athenG
Same here.. the only hiccup I see is if I'm cruising and I'm letting that gas on and off at around 0.0 PSI.. I guess that's my fault coz it get confuse if utec should grab or not... but continues driving then transition isn't a problem
Old Aug 17, 2007 | 06:57 PM
Audible Mayhem
My350z
FCon IS is still a piggy back but will work seemlessly with the revups.
i can install and tune that one for ya man!!
Old Aug 17, 2007 | 07:19 PM
i8acobra's Avatar
i8acobra
My '06 transitions perfectly. I'm NA and tuning in SD mode. The only problem I have is that right now I go super rich (10:1) on close throttle. It's mostly a resolution issue for me though because I'm only tuning in one load column (10%) because I'm NA. I really wish there was a 5% column.
Old Aug 17, 2007 | 07:20 PM
Audible Mayhem
My350z
usually NA, you will only need to tune in the 70 80 90 and 100 actually depending how its set up...
Old Aug 17, 2007 | 10:09 PM
i8acobra's Avatar
i8acobra
I'm running SD, not Mass Air.
Old Oct 8, 2007 | 01:02 PM
Equate's Avatar
Equate
Chris'smax send me my tires! its been 5 months!
Old Oct 8, 2007 | 01:15 PM
chris'smax's Avatar
chris'smax
Man i already pm'd you a long time ago explaining that i could not find the tires and asked for a address to send you a check to refund you the 30 dollars for shipping cost. The sale was for the wheels and tires that were mounted. I was basically GIVING you tires becuase i had no need for them and asked that you just paid for the shipping. PM me with a respones.
Old Oct 8, 2007 | 06:17 PM
Abishop's Avatar
Abishop
^ man what a thread hijack!
Old Oct 10, 2007 | 03:43 AM
k3silk's Avatar
k3silk
I have utec on my JWT kit and its smooth. Not sure what Dave at Function Tuned did but give him a ring Im sure he can help you out.
Old Oct 10, 2007 | 07:12 AM
TENGAI's Avatar
TENGAI
F:T FTMFW
(shameless shop plug...)
Old Oct 10, 2007 | 07:28 PM
terps's Avatar
terps
yah mines real smooth on the stock exhaust maps but today a friend was driven with exhaust cutout op and he hit boost, backed off for a sec and then punched it and the car just died, scared the **** out of me, cars fine and runs great but I guess the stock ecu and utec were battling for control. but I don't think it was tuned for street driving with the cut out open, purley for going fast in a strait line without needing to stop, lol who knows.
Bwen
Nitrous Oxide
23
Dec 24, 2011 02:35 PM
AreYouAMac
Sep 6, 2010 10:30 AM
bd0g36
May 28, 2009 11:57 AM
mchapman
Jan 1, 2007 06:44 PM
