Amazing Breakthrough following DIY Build
Old Jan 29, 2008 | 05:56 PM
  #161
rrmedicx's Avatar
rrmedicx
Cool. That's why I did it.
Old Jan 29, 2008 | 06:14 PM
  #162
JZurita's Avatar
JZurita
Glad to see everything is going well Randy. Even though you ****ed me over!
Old Jan 29, 2008 | 09:40 PM
  #163
overZealous1's Avatar
overZealous1
Originally Posted by rrmedicx
I will win! I didn't come this far to fall flat on my face. Setting my sites on a big Month of March!
thats the spirit!!!
Old Feb 4, 2008 | 08:28 PM
  #164
ByReaL's Avatar
ByReaL
when i got my GT2871R from atpturbo.com they recomended me a 0.9mm oil restrictor, and from what i know the old turbos need a 1mm to 2mm restrictor, and the new turbos ball-bearings ones need a 1mm oil restrictor
http://www.turbobygarrett.com/turbob...o_tech101.html
Garrett ball bearing turbochargers require less oil than journal bearing turbos. Therefore an oil inlet restrictor is recommended if you have oil pressure over about 60 psig. The oil outlet should be plumbed to the oil pan above the oil level (for wet sump systems). Since the oil drain is gravity fed, it is important that the oil outlet points downward, and that the drain tube does not become horizontal or go “uphill” at any point.
the main idea is to adjust the size of the restrictor in such a way that you will not exceed the max oil pressure supported by the turbo
Old Feb 5, 2008 | 04:04 AM
  #165
rrmedicx's Avatar
rrmedicx
I hear ya man, but the Greddy Turbos are supposed to be "bullet proof". Not to many people, in fact, no one I know has ever 'over-fed' a Greddy with too much oil. That is a rare problem. I do know that there are a few folks on this board that have utilized Oil restrictors on other brands of turbos that were getting too much oil. But not Greddy's. I've put that out there already and asked a number of installers/tuners here on this forum. It is an absolute rarity, but thanks for the info.
Old Feb 5, 2008 | 07:00 AM
  #166
gothchick's Avatar
gothchick
I am still waiting for Kyle to finish assembling my motor and then it needs to be shipped from Texas to NYC...another few days. So by Mid Feb. I'll have my new motor.
Kyle is an awesome guy to work with! Glad to hear your build is moving forward again~ :-)
Old Feb 10, 2008 | 05:54 PM
  #167
rrmedicx's Avatar
rrmedicx
Motor being shipped to NYC on Monday 2-11-08 should have it before the week is up.
Happy Days.
Old Feb 10, 2008 | 11:12 PM
  #168
TTRANK's Avatar
TTRANK
Wow I bet you are excited. It sure has been long enough. I would be going insane by now.
Old Mar 11, 2008 | 06:37 PM
  #169
zex350z's Avatar
zex350z
MANNN!!!!! You Neeesaaawn guys are tough on each other. I'm so used to the Honda world - throw together a 1.8 liter OVERNIGHT and dyno next day with similar HP results you are showing.
I don't think I will be going FI w/ my Z anytime soon haha.
Goodluck!
Old Mar 11, 2008 | 08:35 PM
  #170
go-fast's Avatar
go-fast
Goodluck!
hondas are the disposable diapers of the car world.
Old Mar 11, 2008 | 11:08 PM
  #171
JETPILOT's Avatar
JETPILOT
MANNN!!!!! You Neeesaaawn guys are tough on each other. I'm so used to the Zonda world - throw together a 6.8 liter OVERNIGHT and dyno next day with similar HP results you are showing.
/\ Fixed!
JET
Old Mar 12, 2008 | 05:33 AM
  #172
rrmedicx's Avatar
rrmedicx
No worries. 500 miles into the break in of my new motor. Once I get to 1000 or so, apart it goes, and in with the TT and my new EMS.
So far, so good. No issues.
Old Apr 26, 2008 | 08:07 AM
  #173
rrmedicx's Avatar
rrmedicx
Car's done with break in.
Installed TT and everything else.
Hooked up O2 sensor signal to EFI.
Old Apr 26, 2008 | 08:09 AM
  #174
rrmedicx's Avatar
rrmedicx
What happened to your post Julian?
Anyway. Thanks for your helping my sidekick Boogie Yesterday. It didn't take him very long to test out your handy work and get pulled over by the PoPo.
I am anxiously awaiting his feedback on your tune. But from the sounds of it he is very happy. Thanks for the help.
As far as my car...I dropped it off at Turbo Trix yesterday. They are gonna need it for about a week. When they're done, it should be damn n ear perfect. I'll let you know how it worked out.
Thanks.
Old Apr 26, 2008 | 08:40 AM
  #175
Julian@MRC's Avatar
Julian@MRC
Thanks.
Good luck this time around
Randy, were all hoping for the best!! Ill post up "boogies" dyno in a few..
PS not a bad job on the install, the only problem we found was the water line for the turbo, you had routed right over the Throttle Body wires and the Stainless Steel line acted like a saw and cut throught the TB wires and shorted the TB out after 30 dyno pulls.. Other than that, nice install!!
Old Apr 26, 2008 | 08:57 AM
  #176
rrmedicx's Avatar
rrmedicx
Thanks. The water lines job was Boogie's handywork. He got the water lines at home and decided to DIY. But glad it all worked out. Obviously, if I saw the car before he got to you, I would have made sure that was not the case... But thanks for the compliments. Nice work tuning on your behalf.
I told him not to expect anything big in terms of hp numbers because I didn't want him to be disappointed. I told him between 350-380 tops.
But WOW! about 410 at stock Turbonetics boost (8psi I think). Very Impressive. Looking forward to the thread. BTW, if you need install pics to spice up the thread, let me know I have them all. Clutch and turbo install.
As far as my car, I'll let you know when I get it back. Keeping my fingers crossed.
Old Apr 26, 2008 | 09:19 AM
  #177
Julian@MRC's Avatar
Julian@MRC
LOL, he blamed you for the water line..Now the truth comes out...
Here is the thread, I told him he needs the 550cc injectors, he is going lean up top...There is also a weird boost creep issue after 5000 rpms..
Here is the thread.
https://my350z.com/forum/tuning/355015-mrc-and-another-great-tune-turbonetics-single.html
Old Apr 26, 2008 | 10:15 AM
  #178
failsafe306's Avatar
failsafe306
Randy, when you pull the motor for the TT install, that would be a great time to re-torque those headstuds
Old Apr 26, 2008 | 11:58 AM
  #179
rrmedicx's Avatar
rrmedicx
Already installed in the car but thanks.
Car is in the hands of the tuner. I'll let you guys know how things worked out in about 1 week.
Old May 10, 2008 | 06:24 AM
  #180
Julian@MRC's Avatar
Julian@MRC
Car has been a TTR fior over 14 days now...Randy, is there a problem with the PRO EFI or the tuning or the motor??Please tell me everyhting is going smooth for you..Waiting for results..
