Robert_K's JWT TT Build Thread
Old Nov 25, 2007 | 10:34 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Exclamation Robert_K's JWT TT Build Thread
Results: https://my350z.com/forum/forced-induction/346469-jwt-700-kit-results.html
Final list and car is in the shop. Thanks for all the info.
Force Induction:
- JWT 700BB TT Kit
- HKS SSQV BOV w/ 60mm Flange
- Perrin Boost Solenoid
Engine & Drivetrain:
- ARC V2 Oil Catch Can
- ARC Oil Cap
- ARC Raditor Cap
- AP Stainless Steel Clutch Line
- Cosworth Intake Plenum w/ Carbon Fiber Endcaps
- DeatchWerks 600CC Injectors
- JWT Clutch & Flywheel
- Stillen Oil Cooler
- Tein Hood Dampers
- Walbro 255lph Fuel Pump
Electronics:
- A-Pillar Dual Gauge Pod
- Defi-Link Turbo/Boost Gauge
- Defi-Link Fuel Pressure Gauge
- Defi-Link Control Unit II
- Defi-Link Display
- Defi Oil Temp Sensor
- Defi Water Temp Sensor
- Defi Indicator II
- TurboXS DTEC Map Sensor
Brakes:
- StopTech Big Brake Kit; Front & Rear Silver Calipers (2-Four piston & 2-Two piston), Slotted Rotors (4), Titanium backing plates (4), Stainless Steel Brake lines (4), Front (4) & Rear (4) brake pads.
- Ichiba Wheel Spacers 5mm (2) w/ Studs (10) & 10mm w/ Studs (10)
Suspention:
- GTSpec Fender Braces
- GTSpec 4-Point Mid Chassis Reinforcement Brace
- GTSpec Rear Lateral Brace
Audio:
- Pioneer AVIC-D3X DVD/Nav w/ Bluetooth & iPod control
- XM NavTraffic Satellite Radio
- JL C5-650 Components
- JL TR650Cxi Rear Speakers
- JL 500/5 (100x2 Components, 25x2 Rear, 250x1 Sub)
- JL 10W3v3 Sub
- 350Z Corner Box
- Rear License Plate Camera
Old Nov 25, 2007 | 11:00 PM
JETPILOT's Avatar
JETPILOT
Don't forget a wideband. I would also go with deatschwerks injectors over RC. I would also go with 440 injectors. Get a thermostat sandwhich adapter for your oil cooler.
JET
Old Nov 26, 2007 | 12:06 AM
Canadian's Avatar
Canadian
If you're staying at the 6.8 psi the kit comes with, fuel pump, fuel return, and injectors are not needed. I have just the straight JWT 530 kit with NO other supporting mods besides boost, wideband A/F, and coolant temp gauges and it couldn't be more perfect (10K+ miles so far). Unless you plan on turning up the boost and doing internals in the future, I'd say most of that stuff isn't really required or needed at all.
Old Nov 26, 2007 | 12:43 AM
lostark374's Avatar
lostark374
Originally Posted by Robert_K
So I'm starting my JWT build. Like to get some suggestions on parts you recommend or to stay away from. Please visit; "Robert_K's 350Z" for current list of mods. I do not want to build my engine nor run high boost so upgrading internals is not needed. Here is my current list of parts for my build:
- JWT 530BB Twin Turbo Kit
- Cosworth Intake Plenum (Pre-ordered already)
- JWT Clutch/Flywheel Combo
- CJ Motorsports Fuel Return Kit
- RC 550cc Injectors w/ clips
- Defi 60mm BF Series Gauges: Boost Gauge, Oil Temp Gauge &, Defi-Link Control Unit
- CF A-Piller Dual Pod Set
- TXS DTEC Map Sensor
- Cusco Oil Catch Can
550cc injectors are going to be overkill. i had to scale down my 440cc the walbro isnt going to be needed unless your going to up your boost past about 9lbs. the 190lph that comes with the jwt kit isnt that bad. if it were me i would go with the Turboxs bcs and use it with your utec to make map switching a 1 button process unless the utec will controll the perrin bcs? i would add a water temp gauge as well.
just me thinking outloud.
Old Nov 26, 2007 | 02:57 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
JET
he has the turbo XS tuner already
+1 on the injectors and thermostat sandwhich adapter
Old Nov 26, 2007 | 03:05 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
As mentioned I have the TXS Tuner Wideband. What is a thermostat sandwhich adapter for the oil cooler?
Old Nov 26, 2007 | 03:08 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
Rather than run oil through the oil cooler all the time the thermostatically controlled sandwhich adapter opens when the oil reaches a certain point. This has many advantages...
Old Nov 26, 2007 | 03:28 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Thanks. I'll look into that.
Old Nov 26, 2007 | 08:23 AM
XKR's Avatar
XKR
+ 1000000
Old Nov 26, 2007 | 08:40 AM
TheCajunStyle's Avatar
TheCajunStyle
Agree.
The fuel pump and FMU that comes with the kit is sufficient for 6.8psi of boost. I also had a clutch, EGT, and boost gauges installed at the same time as the turbo kit. This has been working perfectly for the last 15,000 miles of hard driving. I will recommend that you have test pipes installed at the same time as this will help lower your EGT. That's it.
Old Nov 26, 2007 | 09:01 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
So if I plan on running 9lbs of boost I should pass on:
Old Nov 26, 2007 | 09:35 AM
arizzee's Avatar
arizzee
I'd recommend:
440cc injectors using the tt kit's fuel pump and fmu.
Water temp & fuel pressure sensors and Defi Display to display oil/water temps and give audible for fp problems.
Skip oil temp gauge and replace w/ wideband.
Oil cooler w/ t-stat adapter is needed.
Of course these are just my biased opinions as it's what I'm running.
Old Nov 26, 2007 | 09:42 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I already have a wideband. Can you post pics of you gauge set-up please?
Old Nov 26, 2007 | 12:33 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Oh, any recommendations for a turbo timer? I had a Blitz on my old Evo 8 and like it. Is there a DIY wiring diagram for installing a turbo timer for the 350Z?
Old Nov 26, 2007 | 12:38 PM
iStan's Avatar
iStan
ZR
Turbo Timer Install
GL with the JWT Happy Boosting.
Old Nov 26, 2007 | 12:39 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Originally Posted by istan
Turbo Timer Install
Thanks. Find it when I did a quick search.
Old Nov 26, 2007 | 04:30 PM
zul8r's Avatar
zul8r
I know the mods weren't needed but I did it because I knew I wold be bilding my engine soon. The car actually ran better with the out of the box jwt kit. Part of the problem is I have no knock amp either. Think these are all the mods
-AAM oil Pan Spacer with Oil Return Line Kit
-HKS F-Con Vpro
-HKS SSQVblow off
-AAM fuel return system
--680cc hks low impedence injectors
--AAM plenum spacer
-APS 3" dual exhaust
-Test pipes
-IMR Grounding kit
-Blitz FatDCIII Turbo Timer
check out my othere posts for pics n vids
Old Nov 27, 2007 | 12:25 AM
WA2GOOD's Avatar
WA2GOOD
Canadain is right.
To the OP.... At your moderate goals, your mod list might be overkill. We have done A TON of out of the box JWT 530 BB kits on stock (or low) boost on stock motors. The only thing realy needed for your goals is possibly gauges, if you want them. Save your money or use it on another aspect of your car.
Old Nov 27, 2007 | 02:19 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
From the sound of it I should go with the following;
- JWT Clutch/Flywheel Combo (Ordering Friday)
- Stillen Oil Cooler w/ Thermostat Sandwhich Adapter
Old Nov 27, 2007 | 02:21 AM
WA2GOOD's Avatar
WA2GOOD
Not a bad compilation of parts you have there, you should be just fine.
