20g potential
Old Dec 13, 2009 | 08:51 AM
  #141
Jay'Z's Avatar
Jay'Z
Thumbs up
Originally Posted by rrmedicx
Oh Damnit, SP is closed Saturday's. I guess Monday then. Bummer.
GL Thanks for all the CF Hatch help.. BTW..
Old Dec 13, 2009 | 09:16 AM
  #142
str8dum1's Avatar
str8dum1
750 on SP's mustang dyno would be very solid as it reads like a dyno dynamics
Originally Posted by Alberto
No less than 750whp
Old Dec 13, 2009 | 04:20 PM
  #143
thom000001's Avatar
thom000001
As long as it stays under 769rwhp Randy!!!!!!! JK
Tom
Old Dec 14, 2009 | 07:49 PM
  #144
IslandZavage's Avatar
IslandZavage
Well???????? updates?
Old Dec 15, 2009 | 07:29 AM
  #145
rrmedicx's Avatar
rrmedicx
Sorry for the delay guys but tuning will be taking place today as per Larry.
I am not there so I can only hope its getting done and I will get results later on today.
I will keep you posted. If all goes well, tomorrow is cold start tuning and the car will be done. That's when I fly out to SP and drive the beast home.
Old Dec 15, 2009 | 07:34 AM
  #146
rrmedicx's Avatar
rrmedicx
No problem Jay. Glad to see it all worked out. Welcome to the CF hatch club! Lol.
Old Dec 15, 2009 | 07:52 AM
  #147
rrmedicx's Avatar
rrmedicx
Dil seems pretty confident that he was maxed out on his 20g's at 650hp. Seems pretty low compared to all the 'math' that has been presented. Maybe more people are tuner limited than kit limited but i'd rather have a non-ventilated crank case at the end of the day.
this thread hasnt narrowed down my options yet
Well on a really crappy tune (WAYYY too rich) the car made 640 on pump alone at 19 psi. With a good tune that should be much higher. In addition I think Larry has intentions of going up to 21 psi of boost. So who knows whats in store. I am leaving him in control of the car. I just requested multiple boost maps.
Low Boost (maybe spring pressure --> 1 bar)
Mid Boost
High Boost with Methanol
So far SP has:
Installed the CAN Gauge
Installed a Meth Kit Boost pressure sensor so the car will drop down to a safer map if the meth runs out.
Linked the meth kit to the ProEFI
Changed Spark plugs - since the last map made them flood out
He also installed a Boost Pressure Control **** (like a radio volume ****), so I can control the boost as I would like. ---> Sweeeet!
Tuning is next. I will update as Larry lets me know.
Old Dec 15, 2009 | 07:54 AM
  #148
Glex25's Avatar
Glex25
Very nice Randy
Didn't know your car was at SP
Let us know how it goes
Old Dec 15, 2009 | 01:33 PM
  #149
thom000001's Avatar
thom000001
And you wondered if you picked the right shop for the tune???
considering Alberto made upwards of 7xxrwhp on 18G's, I'd certainly hope the 20g's make more.
tom
Mid Boost
So far SP has:
Old Dec 15, 2009 | 02:34 PM
  #150
rrmedicx's Avatar
rrmedicx
Working out a couple of bugs. Delays are my life story. I'll get back to you when I get some info.
Old Dec 15, 2009 | 02:41 PM
  #151
midz350's Avatar
midz350
A friend of mine slipped his carbonetics triple on the dyno with the 25G's arond 650whp, he has also 4.2L stroker. I will try to get more info and post them here.
Old Dec 15, 2009 | 02:55 PM
  #152
ttg35fort's Avatar
ttg35fort
Professional
With proper supporting mods and fuel, the 20's will be capable of well over 700 whp, and probably up around the 800 whp range. That said, no matter what turbos you have, you are not going to get there on pump gas with a 3.5L motor spinning in the rpm ranges we operate (at least not for long). The limitation is the octane rating of the fuel, not the turbos!!!
For instance, I got over 600 whp (Mustang dyno) with 18G's at 17.5 psi on 93 octane. We had some headroom, but decided not to push it. It did not appear that we were anywhere near maxing out the turbos, however. Our limitation was the gas. That same limitation would have been there no matter what turbos we ran.
That said, you need to check the compressor maps for your turbos to ensure that you are not operating significantly out of the peak efficiency region. If you do, your intake air temperature will get a little high, which will decrease your ultimate HP potential. I have reviewed the compressor map for the 20G and there does not appear to be any issue with using these in a twin turbo setup on a 3.5L motor from getting well north of 700 whp. Again, you will need more than 93 octane to get there, or you will risk blowing the motor. This will be the case with any turbo you run, no matter how big the turbo is.
If you run twin 20G's with C16 or Q16, 700 whp should be a piece of cake. Using a whole lot of meth injection also may get you there. (This is based on my experience on a Mustang dyno, with a DJ I believe that it will be even easier).
Old Dec 15, 2009 | 03:41 PM
  #153
rrmedicx's Avatar
rrmedicx
Thats the plan Terry. I have a Meth kit installed.
Old Dec 15, 2009 | 06:05 PM
  #154
ttg35fort's Avatar
ttg35fort
Professional
Awsome! I can't wait to see it. I have great confidence you will get there.
EDIT: I'm assuming the clutch is up to snuff. What clutch do you have?
Old Dec 15, 2009 | 09:18 PM
  #155
thawk408's Avatar
thawk408
What ever happend to the Forced Performance 35r wheels in the 18g?
Old Feb 11, 2010 | 06:41 AM
  #156
str8dum1's Avatar
str8dum1
any new results, or are you still waiting on the full swap to E85?
I see folks fell asleep on this thread. I hope to have results today or Monday, as my car sits in Sound Performance getting tuned as we speak.
Built Block, 272 cams, 20G's, +1 valves, Meth, and ProEFI should net some good numbers.
I hope.
Old Feb 11, 2010 | 07:07 AM
  #157
rrmedicx's Avatar
rrmedicx
Well, unfortunately it turned out to be a whole lot more than just the Flex Fuel System install. I needed a complete motor rebuild. Bearing material discovered in the oil while base tuning. Should be done by end of the month (Feb) I hope.
(BTW the Flex Fuel swap is roughly about 1 hour labor to install. Just FYI for those wondering about the time and work involved to install. Its only $559 too.)
Look for news around then.
Old Feb 11, 2010 | 08:28 AM
  #158
rcdash's Avatar
rcdash
Good Luck proving your case to IPP. Chalk it up as a loss buddy. Been there done that. He'll just blame your tuner. Thus begins the finger pointing match.
Sorry for your loss. It's never fun to lose all that $$$.
When I saw the above I figured as much. Sorry to hear. Not sure why spun bearings seem to be such a hurdle on new motor builds...
Old Feb 11, 2010 | 09:39 AM
  #159
thom000001's Avatar
thom000001
Builder issues normally.....
tom
Old Feb 11, 2010 | 10:01 AM
  #160
str8dum1's Avatar
str8dum1
wow that's crazy. This is the motor you built a few years ago though right (as part of your DIY??)? I guess you didnt notice anything that may have contributed to a spun bearing?
