Cass007.... ver 5.0
Old Apr 19, 2011 | 08:45 AM
  #481
XKR's Avatar
XKR
Glad to see you up and going again Chris....looks like you had fun in that video...very Kool.
Old Apr 19, 2011 | 08:56 AM
  #482
Cass007's Avatar
Cass007
Hi Mike... welcome home
Old Apr 19, 2011 | 09:01 AM
  #483
Cass007's Avatar
Cass007
Originally Posted by rh_334
Yes mine are rolled, alot of that depends on your offset. I had to roll mine when i went to 285s and luckily it was enough to hold 295s (not sure my offset) but its so close that if i put a thick layer of tire shine (gel) on it rubs off
And the list to get properly sorted out prior to the airstrip gets longer again
Damn Chris those were some nasty roads... group deal on rim repair and alignment afterwards?
- Its the worst road I've ever seen in MD. If anybody asks you to go to Pretty Boy Reservoir just tell the no. I bottomed out so hard twice that most of the time I was hitting my brakes was because I kept having to change my line after seeing the Nismo's rear take a hard dip. As soon as we stopped I got out and looked under the car to see if the oil pan still had fins on it. Luckily it seems the underbrace took the hit again. Both corners are now folded over onto themselves.
Old Apr 19, 2011 | 09:10 AM
  #484
03threefiftyz's Avatar
03threefiftyz
Chris, just say no to hoosiers for the road. You might be able to get down and back on a set of drag radials, but not on R6/A6's if you drive with any vigor a couple of times up and down the dragon. I have already blown through a set of A6's in about 65 autocross runs (maybe 40 miles). Luckily I have 8 more A's to make it through the year .
Old Apr 19, 2011 | 09:15 AM
  #485
Cass007's Avatar
Cass007
Thanks Mike, they are crossed off the list then. Comparing Toyos, Yokos, KDWs and a couple others right now on price vs road noise vs grip.
Old Apr 19, 2011 | 09:23 AM
  #486
rcdash's Avatar
rcdash
Your shocks seem kind of soft for being that low. What do you have on there?
Old Apr 19, 2011 | 09:45 AM
  #487
Cass007's Avatar
Cass007
I was just thinking the same thing today Raj. I have the Tein Comfort-Sports. I may have to swap them out this coming winter because under max power they let the rear wallow a bit over bumps and undulations in the pavement. It does seem to let the weight transfer well and the car squats and goes well. I have -1.1 to -1.2 camber in the rear right now and am still seeing a ton of wear on the inside vs outside on the rears though and I'm not sure why.
I'm leaning towards the Bridgestone Potenza RE-11 in a 285/35R19 size as a possible compromise in getting slightly wider without having a roll be a must or pinching the tire too much. The R888 only comes in a 295/30R19 and will most likely require the fender roll. I could also do Yoko Advan AD08 too in the same size as the Toyos
Old Apr 19, 2011 | 10:24 AM
  #488
Alberto's Avatar
Alberto
Cranky FI Owner
Rolling is so easy I wouldnt compromise traction or tire sizing over not having to roll fenders.
Old Apr 19, 2011 | 10:29 AM
  #489
Cass007's Avatar
Cass007
Its a time issue as well Berto, gotta find someone with a roller fast cause I can almost see the belts on the rears
Old Apr 19, 2011 | 10:34 AM
  #490
03threefiftyz
The R888's on a 9.5" can be done, but it will just feel a bit more vague and sloppy. They will, however, provide the best traction of the lot you picked.
Old Apr 19, 2011 | 10:52 AM
  #491
rcdash's Avatar
rcdash
Both the RE11 and R888 come in a 305/30/R19. Roll the fender and set your height so it doesn't rub (though with such soft springs that might be quite high!). Keep the camber.
Old Apr 19, 2011 | 10:58 AM
  #492
Alberto's Avatar
Alberto
Cranky FI Owner
I have a fender roller but I have no time to help you do that-I used to roll as a side $$$$ when I first got it to pay it off, which I quickly did! Im busy the next 2 weekends and out of town after that. PM me if you want to tackle it yourself. Actually let me check to see that I have it at home, if not its with my Z and its not accessible to me at the moment.
Old Apr 19, 2011 | 11:28 AM
  #493
djamps's Avatar
djamps
Paul AKA "p's g35" on driver has a roller and is doing side jobs currently.
Old Apr 19, 2011 | 11:53 AM
  #494
Cass007's Avatar
Cass007
I will have to measure to see if I can fit the extra 15mm on each side and stay under the fender. The 275mm seem very close without the roll and I would hate to have to raise the car up or have the rear higher than the front, looking like a camaro
Thanks. I have to see if I can remember my login over there.
Old Apr 19, 2011 | 12:25 PM
  #495
GreenGoblin's Avatar
GreenGoblin
Some one please help him out, I have a roller here. Wish you were closer I would be on my way to take car of it for you.
Old Apr 19, 2011 | 12:54 PM
  #496
nyqueenz's Avatar
nyqueenz
IF i were you i would go with a more lighter forged rim like Kinesis.. in 18s
and maybe these tires 305/45/18
Heat Cycling
Competition tires are built with a highly sophisticated tread compound. This compound is capable of sustaining traction throughout a much wider temperature range, but is also extremely sensitive to the first heat cycle of its use. During this cycle the tread compound stretches as it heats.
Old Apr 19, 2011 | 12:56 PM
  #497
nyqueenz's Avatar
nyqueenz
BTW call Paul or Frank Hill they have rollers
Old Apr 19, 2011 | 02:37 PM
  #498
Cass007's Avatar
Cass007
TY, spoke with Frank regarding the oil plate issue and confirmed he has the roller and can help.
jtgli is running 18s with a 315mm drag radial and it is sick, but I won't spend money on new wheels until the car runs for at least a whole season.
Old Apr 19, 2011 | 02:46 PM
  #499
03threefiftyz
Just find a pair of inexpensive 17x10's. Then run 305-315 DR's when you plan to put the power down. I'd keep the others with street tires. I can fit (4) 18" RPF1's with 285 hoosiers in my car, and still have room for impact gun, tool box, fold out chair, two helmets, etc.
I can't see out of the car or put it in reverse, but I can get to and from without a little tire trailer.
Old Apr 19, 2011 | 02:48 PM
  #500
nyqueenz's Avatar
nyqueenz
Kool, yea Frank took care of me when I put my 305/30/19 on and all seem fine until my fat azz sat in the car and drove out his shop over that 1st speed bump.. I cut the sidewall on my left tire..lol So we brought the car back in and Frank re-rolled my fenders completely that the wheels fit perfect.
