Cass007.... ver 5.0
Old Apr 19, 2011 | 03:12 PM
  #501
Zquicksilver's Avatar
Zquicksilver
^ good lord...
i shaved my rear fenders... i was keeping in mind that when running a ON or OFF ramp at high speeds the tire will flex IN or OUT at the top, so you need a little wiggle room. that was my biggest fear when running the 305's, slicing my side wall open on a ramp, loosing control and crashing :O
Zquicksilver
Old Apr 19, 2011 | 03:34 PM
  #502
nyqueenz's Avatar
nyqueenz
Originally Posted by Zquicksilver
^ good lord...
Zquicksilver
I had to go wide because 285s wasn't cuttin it on my 11''s rims..lol 305 are a prefect fit
Old Apr 19, 2011 | 06:37 PM
  #503
Cass007's Avatar
Cass007
Lance - Are you running a spacer with your setup?
Old Apr 19, 2011 | 07:37 PM
  #504
rcdash's Avatar
rcdash
If you run the correct offset, you can run a 19" wheel, wider tires AND not have to increase height AND not have any rubbing. A 10.5" wheel with a +27 or +30 offset I think would work and give you a flush look assuming you also rolled the fenders (maybe with a +30 or +32 and 305s you wouldn't even need to roll).
Old Apr 19, 2011 | 07:46 PM
  #505
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
For reference, I have 19 x 11, +35 offset, with 305/30 and rolled fenders. No rubbing or interference issues on the street or track prior to my car going under the knife for the full FI build.
Old Apr 19, 2011 | 08:24 PM
  #506
nyqueenz's Avatar
nyqueenz
no spacers .. but i think my fronts need some.. rear is perfect
Old Apr 20, 2011 | 08:38 AM
  #507
binder's Avatar
binder
i'm running 10" wide rims, 18" mickey thompson drag radials in 305/35/18 without rub. I think the g35 has wider rear fenders because i don't have my rolled and still have a finger width between my rims and tires. I'm probably going to roll them and go to 325's though. The other option is to go down to 16's or 17's so i can get a thicker sidewall.
Cass: about the tires wearing, camber usually is'nt the issue with eating tires like everyone thinks. Toe is what eats tires. I ran 3* negative camber on mine when i first got it for corner handling and my tires didn't have any issues with wear. M series bmw's come factory iwth 2.5* neg camber. On my minitruck i was running -15* camber iwth no tire wear issues. When i went that low the toe was way out and toe is what causes the scuffing and dragging of the tires which eats them off. Your -1.3 camber is well within factory spec so it shoudln't eat tires. Have them adjust toe. I have mine aligned every year. It seems these cars can't hold an alignment for crap.
Old Apr 20, 2011 | 11:33 AM
  #508
Cass007's Avatar
Cass007
Just had it aligned last week. I will see how the new tires hold up once I make up my mind on them. I found the oil filter relocation kit I have been looking for:
Its all plumbed with -10AN lines and most importantly it retains the use of the stock filter. I need to put the Mocal thermo plate on this so finding the 20mm x 1.5 oil filter connection was clutch. It seems the industry standard is 3/4-16 using a huge Ford filter. Total cost on the cooler parts and install will be almost $1K This car eats $100 bills constanly.
Just had a random thought that the car may have roughly 8 quarts of oil in it with the new setup (it holds 6.5 right now)... I hope it helps.
Old Apr 20, 2011 | 12:12 PM
  #509
str8dum1's Avatar
str8dum1
dunno if you bought yours already but you could get this
http://cgi.ebay.com/ebaymotors/ws/eB...m=230516043866
and make your own lines. it will come out cheaper and look better.
be interested to see where you mount the new filter. its all quite a bit bigger than you'd think. I had to get creative with the mount. wouldnt look good in your pristine engne bay, but mine is all over the place so its ok
Old Apr 20, 2011 | 12:47 PM
  #510
binder's Avatar
binder
Attachment 312869
a grand?! that's stupid expensive. You better have had some insane oil temps to make you want to get that setup. Mine weren't even high at 16psi and no cooler but i added a cooler just in case.
Old Apr 20, 2011 | 01:06 PM
  #511
rcdash's Avatar
rcdash
Sell the APS oil pan and just put a oil pan spacer and regular oil pan in there if you need the space for the Mocal and fittings. Forget the $1k filter relocation kit! The Stillen deep oil pan looks like a nice clean option too though I've never seen it installed.
Old Apr 20, 2011 | 01:14 PM
  #512
Cass007's Avatar
Cass007
First Blackstone results are back:
Old Apr 20, 2011 | 01:20 PM
  #513
nyqueenz's Avatar
nyqueenz
I think i need to send another sample to Blackstone before i turn th boost up on an hit them high numbers..
Old Apr 20, 2011 | 04:20 PM
  #514
Cass007's Avatar
Cass007
Most of the cost is already spent, the bulk was labor to fab the mounting in the crash bar, Mocal coolers, Mocal thermo plate, several fittings at ~$20 each and so on...
I considered selling the pan, but this is less headache to do right now, plus its a nice pan with baffles and fins and a mount for the temp sensor.
Old Apr 20, 2011 | 05:13 PM
  #515
ToastZ's Avatar
ToastZ
Cass,
See you at ZdayZ - dinner is on me, I am buying Raj dinner too after he uses Rocket fuel to crush me Mike, Sharif and the Forged folks - whoever else makes dinner. We will toast to the Cass, the survivor
-Paul
Old Apr 20, 2011 | 08:34 PM
  #516
binder's Avatar
binder
i wish i could go. 2 more years guys and i'll be out of grad school so i can go!
Old Apr 22, 2011 | 10:45 AM
  #517
Cass007's Avatar
Cass007
See you there Paul
Just ordered the R888s from Treadepot.com - $310ea - $650 total with shipping. I figured I can't really hear much over the exhaust anyhow, so whats a little road noise gonna hurt. I just want to have the best chance at traction as possible.
Old Apr 30, 2011 | 04:51 AM
  #518
Cass007's Avatar
Cass007
Got the filter relocation kit installed finally, it required some slight modification of the nut that goes onto the factory filter hanger. It was too long to mount the relocator plate flush to the factory sandwich plate, so it needed to be ground down a bit. The filter and Mocal thermo plate is now mounted on the drivers side next to the oil pan. Here are the pics:
Cass007.... ver 5.0-1304007991924.jpg Cass007.... ver 5.0-1304014677744.jpg Cass007.... ver 5.0-1304014691785.jpg
Also got the fenders rolled and put on the 295/30R19 Toyo R888s... all I can say is WOW!!! Caught a shift from 1st to 2nd at 6K rpm on my 12lb map yesterday and there was no spin at all, just hook and go. There is a little tire noise, but not that audible over the 3" exhaust.
Old Apr 30, 2011 | 05:26 AM
  #519
0jiggy0's Avatar
0jiggy0
Here's to hoping the good news and progress keeps coming.
Old Apr 30, 2011 | 07:33 AM
  #520
eltness350's Avatar
eltness350
The Untouchable
^^^^^^ +1000000000000000000000
