Vortech w/ 2.87
Old Sep 12, 2011 | 04:25 PM
meanz's Avatar
meanz
Default Vortech w/ 2.87
Just wanted to share my results with my new uprev tune and 2.87 wheel. I hit 11psi at around 6600rpm. My power was 418/352 We took it to 7000rpm once and saw 14psi. The stock rev was kept in the end. The 600dw injectors were at 95% at 7000. Not good at all. They said that it had a lot more up top but wanted to keep it safe and not hurt anything. Had to pull a lot of timing. It pulls really hard and breaks loose really easy.
Overall im happy so far. The daily drivabilty is pretty good. I do get rich here and there when i go just a little more than partial throttle when cruising and of course wot. Dosent smoke. Dont think my car likes long drives though, after over an hour on the highway it would get rich and act up at the hint of touching the pedal just cruising at 70 on the highway. After i let it cool down at the house, it seems to be driving fine. They decided to keep it a little on the rich side for safety. No check engine lights. Thought id share.
Old Sep 12, 2011 | 05:16 PM
unvmyg35's Avatar
unvmyg35
Nice numbers! I can't wait and see what my vortech build with a 3.12 will do. What year is your car and do you have any supporting mods?
Old Sep 12, 2011 | 05:22 PM
- bigc -'s Avatar
- bigc -
congrats and nice numbers!
meanz's Avatar
meanz
03 6spd, test pipes, hks rep exhaust 255 walboro with 600 dw injectors
Old Sep 12, 2011 | 05:31 PM
unvmyg35's Avatar
unvmyg35
Nice congrats on those numbers!
Old Sep 12, 2011 | 05:49 PM
mvp2765's Avatar
mvp2765
nice numbers
Old Sep 12, 2011 | 08:30 PM
350Z400rwhp's Avatar
350Z400rwhp
I hit the exact same numbers with the 2.87 nice!
Old Sep 21, 2011 | 04:27 AM
CTZ860's Avatar
CTZ860
I'd be happy with those numbers.
What do you mean by injectors were at 95%....?
Old Sep 21, 2011 | 06:52 AM
tonyzS/C03's Avatar
tonyzS/C03
Injector duty cycle...
Old Sep 21, 2011 | 10:08 PM
brocw1093's Avatar
brocw1093
Very nice! I have a 2003 with a v3 vortech, I want to make a reliable 400whp next spring after a tune. should I go with a 2.87 or a 3.12?
Ill be running 600cc dw injectors, test pipes, exhaust, 255 walbro intank fuel pump and a spacer. I am then going to get it tuned. Should a do a 3.12 or just go straight to a 2.87? I want reliablity, just curious since you most likely would know
Old Sep 22, 2011 | 07:49 AM
jpc350's Avatar
jpc350
I started with the 3.33,then the 3.12 and then the 2.87...Wish I started with the 2.87 and woulda saved $$$ in avoiding re-tunings...
Old Sep 22, 2011 | 07:07 PM
brocw1093's Avatar
brocw1093
Sounds like 2.87 is the way to go, thank you
Calinismo350z
Sep 14, 2015 04:04 PM
james12345pt
Jan 28, 2008 04:13 PM
Blackbird CPV35
Sep 13, 2007 12:59 PM
Bwicked
Feb 1, 2007 07:20 AM
kevinapex
Apr 6, 2006 06:42 PM
