Another built motor Vortech dreamer thread.
Old Dec 25, 2014 | 03:19 PM
  #261
Conway_160's Avatar
Conway_160
Whens the retune?
Old Dec 25, 2014 | 04:25 PM
  #262
meanz's Avatar
meanz
Originally Posted by Conway_160
Whens the retune?
I emailed hal about tuning the 1st week of February. I would do it in jan, but the only weekend we could do it, they are leaving town. Still waiting for a reply. Being the holidays, I expect a delay to get back to me. Car seems just as bad as before, except a little more up top, lol I'm hoping he can squeeze everything that this blower is capable of out.
Old Dec 25, 2014 | 04:27 PM
  #263
meanz's Avatar
meanz
Also I'll prolly pm old man to get one of his braces. I seen 21 psi, if we can push the car harder, I don't want to miss out because of bracket flex or slip.
Old Dec 26, 2014 | 05:51 AM
  #264
Conway_160's Avatar
Conway_160
Best of luck would be awesome if you could could get 700. You thought about E-85?
Old Dec 26, 2014 | 06:06 AM
  #265
meanz's Avatar
meanz
I have, but at this point, I don't want to dump any more money into it. Pretty sure my fuel setup would be maxed if I went e85. I have been thinking about doing a 50/50 with race gas and 93. Im just happy to be able to drive it around and not be so damn slow, lol. February can't get here fast enough.
Old Dec 26, 2014 | 06:48 AM
  #266
Conway_160's Avatar
Conway_160
550 is slow? Man then my 100 is three two'd sloth slow.
Old Dec 26, 2014 | 07:28 AM
  #267
meanz's Avatar
meanz
No, lol I was driving the z around all motor with out the blower.. I sold my other blower and waited a month for this to get here.
Old Dec 26, 2014 | 07:41 AM
  #268
Conway_160's Avatar
Conway_160
Oh gotcha.
Old Dec 29, 2014 | 06:10 AM
  #269
meanz's Avatar
meanz
Here is a better pic
Old Dec 29, 2014 | 06:46 AM
  #270
Conway_160's Avatar
Conway_160
Weird but they must serve a purpose.
Old Dec 29, 2014 | 08:04 AM
  #271
meanz's Avatar
meanz
Maybe for balancing?
Old Dec 29, 2014 | 11:00 AM
  #272
Conway_160's Avatar
Conway_160
That makes sense, since they aren't all the same size.
Old Dec 29, 2014 | 01:10 PM
  #273
str8dum1's Avatar
str8dum1
yes, every turbine/compressor wheel must be high speed balanced. instead of adding weight like on your car wheel, they most of the time remove
Old Jan 20, 2015 | 02:48 PM
  #274
meanz's Avatar
meanz
Little update. Got everything on and car is running great with the previous tune. Still scheduled for feb 5th tune date at dynosty. Still hitting 21psi at 7k. Car pulls hard. Afr Is in and around 10.8 at redline. Little rich, but that will be adjusted.
Now ive been thinking about bringing a 2.75 pulley with me and see what it can do, but im certain I will be getting slip and revving a little higher. So now im throwing around the idea of running a 34/28 cog setup. With this, it spins the blower slightly higher than a 2.75. I need to research but what are some of the other guys running their blowers up to?
Right now im spinning to 61,500=21psi
With the 2.75 at 7k I should be around 64,200
With the 2.87 and 34/28 at 7k I should be around 65,400
I was really wanting to rev higher than 7k, but don't want to run more of a risk of hurting the new blower..Should I try to spin it higher and see if it will make power past the 26psi that vortech says that is the limit? Im only 5psi shy of it right now.
For anyone running the 34/28 setup, did you need to change to a different belt size or make any other adjustments? This question mostly directed at oldman since I read this is what he is running..
Old Jan 20, 2015 | 06:51 PM
  #275
350z006's Avatar
350z006
I needed to switch to a Gates 544 8mgt 21 polychain belt to run a 34/28 setup, but I have a revup vortech kit and I'm not sure if the belt size applies to the standard DE Vortech kits...
Also to minimize belt slip, you'll probably want to run the 34/28 with the 2.87...the bigger the jackshaft pulley the less slip, and of course you get no slip wiith the cog pulleys...
That being said, I did manage to run a 34/28 setup with the 2.75 with no slip, thanks to Oldman's TIMROD assembly, and an extremely tight belt, with an ATI crank pulley....
Old Jan 21, 2015 | 05:19 AM
  #276
OldManZ350's Avatar
OldManZ350
I have an old type SC Trim Standard blower rated @ 1000cfm.
Stock Crank Pulley, 34/28 Cog and a 2.87 Serp. and rev to 7100rpm, Blower to 62,355rpm.
For the 34/28 cog stock belt works fine.
The Vortech V2 Ti-Trim is an HD Stout Blower, very tough ,rated @ 1400cfm and 26psi.
If your making 21psi IMO you should be closer to 600whp or more. See Colombos Post.
You must have a larger diameter crank pulley, right?
TimRod
Old Jan 21, 2015 | 05:25 AM
  #277
meanz's Avatar
meanz
Yes the crank pulley is the fluid dampr. Pretty sure it's 6.12 where the belt rides.
Old Jan 21, 2015 | 05:34 AM
  #278
OldManZ350's Avatar
OldManZ350
Yes, that's right.
Have you ad your car on the dyno with the Ti-Trim?
Old Jan 21, 2015 | 05:36 AM
  #279
meanz's Avatar
meanz
Feb 4 is my retune at dynosty.. I will be taking the car back to Cin after the tune to get actual gains from their dyno since that was the last dyno I used.. I'm just wondering how high I can spin this blower up.
Old Jan 21, 2015 | 05:48 AM
  #280
OldManZ350's Avatar
OldManZ350
Well I've be spinning mine to 62355rpm for a long time with many hard runs on it, and it's a standard, not an HD, like I said. But spinning them up that hi has caused belt slip problems for most everyone.
I think you will have belt slip and be sorry you did not have the Radius Rod installed. To go to all that work, with a New Bigger Blower and dyno time and end up with belt slip is a pain in the ***. And on top of that, not being able to reach your goal. I hope you don't and all works out well for you.
