Another built motor Vortech dreamer thread.
Old Feb 17, 2015 | 01:00 PM
  #441
str8dum1's Avatar
str8dum1
this is what I did
Old Feb 17, 2015 | 01:29 PM
  #442
Resmarted's Avatar
Resmarted
Originally Posted by taywan
resmarted, you think the Rev up lower would help me on a single turbo build or a waste? Being turbo, that tq will already be up there anyways
On turbos the tune will make a bigger impact than anything else. As well as how you setup your wastegate duty cycle/boost controller. But I don't see why you wouldn't get more flow near 7k rpm.
Old Feb 17, 2015 | 02:26 PM
  #443
OldManZ350's Avatar
OldManZ350
Nothing wrong with that.
You're car screams......
Originally Posted by meanz
Lol yeah nice to finally meet you.
Car pulls good as usual. Car made 580/490@20 psi... So this is where I'm at for now. I'm finished for a while for chasing more power. I'll still mess with the belt setup and rod to see if there is anything else to be pulled. But for now, I'm content.
Old Feb 21, 2015 | 08:03 AM
  #444
meanz's Avatar
meanz
Been messing around with a new belt and this brace on the bracket. I'm currently running open blower and no front bumper at the moment. Doing a pull in 1st and 2nd, I see 25-26psi. 3rd gear and up i see right around 24. At 6k I see 20psi pretty regular on my aem gauge. I plugged in the laptop to see what the haltec was logging. It pegs 22.5 every time. Doesn't see 22.6 or 22.7.. I emailed hal and he is believing that I might be maxing out the internal halted map sensor and may need to change to an external. My aem gauge matches my laptop logs all the way up till it gets past 21-22. Then the laptop will peg 22.5 and stop.
I almost shredded a belt. I stopped seeing past 21-22psi. So I was looking over things. I didn't add lock tight to the strut brace and it back out letting the bracket flex out. I loosened my belt up and readjusted the strut brace adding lock tight and retightened the belt. Made some more pulls and it was back up to 24psi. I have more work cut out for me, but it seems that I'm starting to get the hang of things. Remember i dynoed at 580 at 20psi. Now seeing up to 26psi so far. Still need to work out something for an intake and get my bumper back on.
Old Feb 21, 2015 | 09:27 AM
  #445
Cux350z's Avatar
Cux350z
hatersgonnahate
straight from the haltech manual, that map sensor is rated to 22psi.
http://files.haltech.com/downloads/p..._Z33_Rev_D.pdf
Selectable onboard internal MAP sensor rated to 150kPa (up
to 1.5 Bar or 22psi boost
Time to go external.
If you want, i have a thread on how to tie your aem boost to your haltech. that way your haltech and gauge are always in sync.
http://forums.haltech.com/viewtopic.php?f=24&t=9069
Its not the same for PNP but you should be able to take the manual and make it work.
Old Mar 6, 2015 | 08:15 AM
  #446
Classy's Avatar
Classy
Found the video I was talking about, yes this is a spring loaded tensioner, but still shows how crazy that belt goes on a supercharged car
Old Mar 6, 2015 | 11:11 AM
  #447
SOHOMotorsports's Avatar
SOHOMotorsports
Vendor - Former Vendor
That is correct, you are maxing out the internal map sensor, time to go external.
Old Mar 6, 2015 | 05:31 PM
  #448
NAbuilderZ33's Avatar
NAbuilderZ33
2012 327 Supercharged COPO Camaro Under Hood Maple Grove Raceway 2014 May 23 mp4 - YouTube
That's insane.... Wow.
Old Mar 7, 2015 | 09:25 AM
  #449
meanz's Avatar
meanz
Went to track today, street tires and popped an axle on a 4500 rpm launch.. Street tires and they are sticky!!
Old Mar 7, 2015 | 10:07 AM
  #450
Conway_160's Avatar
Conway_160
Damn, what are you ordering for replacements?
Old Mar 7, 2015 | 10:38 AM
  #451
meanz's Avatar
meanz
Talking to a vendor now to see what's out there.. I already fixed it and back in the staging lane.
Old Mar 7, 2015 | 11:36 AM
  #452
meanz's Avatar
meanz
Finally got a decent run
60ft. 2.00
330ft. 5.19
1/8. 7.76
Mph. 95.40
Lot of spin and some hop out the gate. Had to get out of it a little then back in. Was short shifting around 6500.
Old Mar 7, 2015 | 11:44 AM
  #453
Voodoo Club's Avatar
Voodoo Club
60ft. 2.00
330ft. 5.19
1/8. 7.76
Mph. 95.40
daaamn.. that sounds fun.
Old Mar 7, 2015 | 12:55 PM
  #454
meanz's Avatar
meanz
Old Mar 7, 2015 | 01:30 PM
  #455
Conway_160's Avatar
Conway_160
How much boost are you seeing now?
Old Mar 7, 2015 | 02:20 PM
  #456
meanz's Avatar
meanz
I did some pulls before the track and was seeing 22-23psi. Don't know what I seen at the track, no time to look, lol
Old Mar 7, 2015 | 02:22 PM
  #457
Conway_160's Avatar
Conway_160
Is the radius rod making a difference? How far are you from a 1/4 mile strip?
Old Mar 7, 2015 | 02:54 PM
  #458
OldManZ350's Avatar
OldManZ350
Street tires with Lack of Cushion and Wheel Hop is what kills axles.
I still on stock axles with a 1.51 60ft.
With all that power you need a good set of Slicks and you would be in the 11's first time out, if you ever get to a 1/4 mile track. Plus it's a lot more fun....
You must have brought a spare axle with you, good thinking.....
TimRod
Old Mar 7, 2015 | 03:01 PM
  #459
OldManZ350's Avatar
OldManZ350
Just watched you're video clip again.
You car is fast and if you set it up right you would see 10's in the 1/4 mile, that is if you're interested in doing so.
You can hear the car spinning the tires in 3rd gear....
Old Mar 7, 2015 | 03:16 PM
  #460
Conway_160's Avatar
Conway_160
Havr any more videos??
