Another built motor Vortech dreamer thread.
Old May 12, 2015 | 01:49 PM
  #581
Classy's Avatar
Classy
Cosworth manifolds have been known to leak.
Old May 12, 2015 | 03:11 PM
  #582
Conway_160's Avatar
Conway_160
When you get to the dyno, get you some Soapy water or something and spray your manifold to see if it leaks.
Old May 12, 2015 | 03:23 PM
  #583
meanz's Avatar
meanz
The manifold isn't leaking Im sure. I seen the same psi with the stock plenum, kinetix, and this cosworth. All within a month, lol. I think it's my pulley slipping just that much. What could I use on the pulley to help it grip more?
Old May 12, 2015 | 03:42 PM
  #584
OldManZ350's Avatar
OldManZ350
You can try this:
http://www.carbinite.com/Applications_Auto_Pulleys.html
If heard it works great!
Attached Thumbnails Another built motor Vortech dreamer thread.-screen-shot-2015-05-12-at-7.44.09-pm.png
Old May 12, 2015 | 03:44 PM
  #585
Resmarted's Avatar
Resmarted
Originally Posted by OldManZ350
You can try this:
I haven't called them yet, but are they in business? That page doesn't work. I want that coating. On a 3.48 pulley. Actually make that 3.6
Old May 12, 2015 | 03:50 PM
  #586
OldManZ350's Avatar
OldManZ350
Then Call them!
Old May 12, 2015 | 03:51 PM
  #587
Classy's Avatar
Classy
Alotta places can do a friction coating like that, ask around locally
Old May 12, 2015 | 03:56 PM
  #588
meanz's Avatar
meanz
Thanks, I'll try and ask around local and see what I dig up. If not I'll give those guys a call in that Link above.
Old May 12, 2015 | 03:58 PM
  #589
Resmarted's Avatar
Resmarted
I don't know about local guys (here at least lol). But carbinite has a reputation.
Some people claim their coated pulley works better than an 8 rib. And I know it's not terribly expensive so...
But I want to get my kit in first, then figure out what I need to do with the intake pipe (maf tube looks janky), and get my intercooler fitted/get the t-bolt clamps. Then get the car running. Then I'll worry about the belt routing/pulleys before I get a proper tune.
Old May 12, 2015 | 04:17 PM
  #590
meanz's Avatar
meanz
Quick research shows those guys coat a lot of pulleys with success. Average price is about 100$ with quick turnaround. I'll be calling them soon to get my 2.87 pulley coated.
Old May 12, 2015 | 08:02 PM
  #591
Resmarted's Avatar
Resmarted
Yeah they have a lot of great feedback. All you need after that is some meth injection
Old May 21, 2015 | 10:56 AM
  #592
meanz's Avatar
meanz
Did some pulls last night and heard a nice loud exhaust leak. Jacked up the car this morning and found out my headers cracked around the weld. They said it was because of my heat wrap and are not warranting them. Working on welding them now..
Old May 21, 2015 | 11:00 AM
  #593
the3kgt2's Avatar
the3kgt2
That's really unfortunate. I hope you're back up and running soon. It's understandable that they won't warranty the headers when using wrap. The wrap just traps in the heat instead of dissipating it. I asked DC Sports about wrap before I bought mine and they said the same thing. That's why I opted for the ceramic headers over the stainless steel with wrap. Good luck. Get that thing back together soon.
Old May 21, 2015 | 12:56 PM
  #594
Classy's Avatar
Classy
I think that is retarded. It obviously broke at the weld, which proves to me crappy workmanship...
Also, that metal is paper thin... Junk imo
Old May 21, 2015 | 01:01 PM
  #595
meanz's Avatar
meanz
Well I had my friend weld it up for free, so I'm gonna put it back in this weekend and see what it does. Hopefully it holds till I can afford something different.
Old May 21, 2015 | 01:06 PM
  #596
OldManZ350's Avatar
OldManZ350
That happened to me. I had a second layer of steel welded around the area.
Make sure that the exhaust is well supported at the end of the test pipes.
IMO, it's from vibration and lack of support.
Old May 22, 2015 | 05:42 PM
  #597
taywan's Avatar
taywan
You're welcome
(Haha)
Old Jun 2, 2015 | 08:19 AM
  #598
meanz's Avatar
meanz
Another little update. Been messing around with the setup and started seeing 24-25psi again. Car was running strong then my teeth on the cog belt shredded. I think my belt might have Walked over to the edge of a cog just enough to shred. Been waiting a week now for my replacement belts. Gonna readjust it a little and hopefully I can still see 24psi+. Trying to get everything running smoothe before I go back to the dyno and tube this cosworth.
Old Jun 2, 2015 | 08:23 AM
  #599
the3kgt2's Avatar
the3kgt2
My belt just tore up too. It took Vortech 2 weeks to ship out their new belt. Gates 8MGT-608-21 is supposedly the strongest cog belt available. Just ordered one as a spare.
Old Jun 2, 2015 | 08:24 AM
  #600
meanz's Avatar
meanz
Yeah I run the poly carbon ones that Tim also uses.
Edit, yeah those are the ones I run and just ordered. Ordered last Monday. They normally ship pretty quick.
