Procharged G35
Old Apr 18, 2015 | 07:08 PM
  #261
Conway_160's Avatar
Conway_160
Silver ones are 2,6.
I also pulled off my timing covers to look at my cams compares to my other motor and they look identical. So im gonna do a compression test to see if i can find anything.
Old Apr 19, 2015 | 01:17 PM
  #262
Conway_160's Avatar
Conway_160
So bank 1 was 130 and bank 2 was 110....should I be worried?
Old Apr 19, 2015 | 10:58 PM
  #263
Resmarted's Avatar
Resmarted
How'd your oil and oil filter look? Any particulate?
And did you get any codes/pull them? I'm not familiar with uprev, but I'd imagine it would be obvious if you had codes on osiris, no?
Old Apr 20, 2015 | 12:04 AM
  #264
Conway_160's Avatar
Conway_160
I haven't drained the oil, the car hasn't even been drove yet. It still have a horrid miss that im trying to figure out. I only did the compression test to see if I could narrow down my possibility's of failures. The car has only been started maybe 10-11 times and ran maybe a total of 4-5 minutes. But no I don't have a code of any sort.
Tomorrow im going to put 440s in with new plugs and different tune in to see if that makes any difference.
Old Apr 20, 2015 | 09:11 AM
  #265
Conway_160's Avatar
Conway_160
Well, new plugs, different injectors, and different tune all had the same result...looks like this weekend the motor will be coming apart...fml
Old Apr 20, 2015 | 09:46 AM
  #266
jdm-v35's Avatar
jdm-v35
tried switching coils around? looks like 2 and 6 didnt even have a spark. I dont see any type of oil or water on them though, at least in that pic. also maybe you have the injector harness mixed up?
Old Apr 20, 2015 | 10:04 AM
  #267
Conway_160's Avatar
Conway_160
I've moved plugs around, I've moved coils around, I've swapped 2/6 harness connectors, 2/6 plugs have fuel on the them.
#6 injector wont reach #2 so I think its safe to say those are right.
Old Apr 20, 2015 | 10:13 AM
  #268
jdm-v35's Avatar
jdm-v35
well I mean completely reversed the banks on injector harness. if you have fuel on them but no oil/water then that's a good sign.
Old Apr 20, 2015 | 10:27 AM
  #269
Conway_160's Avatar
Conway_160
I had the banks backwards in the beginning, but that is fixed now.
Old Apr 20, 2015 | 10:41 AM
  #270
jdm-v35's Avatar
jdm-v35
if you have extra plugs, try and pull the 2 and 6 coils(leave them connected) and put the extra plugs in them then crank/start it up ground the plug and see if they are producing any spark.
Old Apr 20, 2015 | 10:45 AM
  #271
Conway_160's Avatar
Conway_160
I have all 6 are making spark.
Old Apr 20, 2015 | 10:46 AM
  #272
OldManZ350's Avatar
OldManZ350
Make sure you are grounded and grab onto the SparkPlug tight with your bare hand.
Then you will know for sure if you have Spark.
Old Apr 20, 2015 | 10:50 AM
  #273
Conway_160's Avatar
Conway_160
Lol, hell no I've been hit by a 4 wheelers spark before no way would I want to get hit with a cars.
  #274
jdm-v35's Avatar
jdm-v35
must be a timing issue then if you have fuel and spark. I would check cams before pulling the whole thing out.
Old Apr 20, 2015 | 10:53 AM
  #275
Conway_160's Avatar
Conway_160
Cb7I looked at the cams while #1 was at tdc and compared it to my other motor and I cant see a difference between any of the cams
Old Apr 20, 2015 | 10:51 PM
  #276
Resmarted's Avatar
Resmarted
Pretty sure you'd hear some heinous noises if you had a cam off by any significant amount. But they might be off a degree or two... I think though you would get a p0340/5 code or something similar.... Not sure. Could be a sensor? Do you have good grounds?
Old Apr 21, 2015 | 04:43 AM
  #277
Conway_160's Avatar
Conway_160
It doesnt make any good sounds and it backfires every now and then. I wish i would get a code or something that would help. All my gronds are good.
Old Apr 24, 2015 | 04:46 PM
  #278
Conway_160's Avatar
Conway_160
So I reset the timing it looked like bank 1 exhaust was off a few teeth. I also pulled my plugs and 2/6 are still silver like they arn't firing. I will be putting it back together tomorrow and hoping for the best.
Old Apr 24, 2015 | 04:53 PM
  #279
meanz's Avatar
meanz
Wish you luck! It's frustrating as hel1 when your so close.
Old Apr 24, 2015 | 07:08 PM
  #280
bealljk's Avatar
bealljk
^ the more you suffer the more it shows you really care! You'll get there -
