Procharged G35
Old Apr 24, 2015 | 07:28 PM
  #281
Conway_160's Avatar
Conway_160
Thanks guys!
Old Apr 25, 2015 | 02:47 PM
  #282
Conway_160's Avatar
Conway_160
Well the car is Re-timed and reassembled, going to go get some more break in oil and see what happens.
Old Apr 25, 2015 | 06:56 PM
  #283
Conway_160's Avatar
Conway_160
Still needs a little work, Still misses a little but that could be old gas and fowled plugs. I will mess with it more tomorrow after I get off of work.
Old Apr 25, 2015 | 08:37 PM
  #284
OldManZ350's Avatar
OldManZ350
There you Go!
Were the Cams infact out of time?
Old Apr 25, 2015 | 08:54 PM
  #285
bealljk's Avatar
bealljk
happy for ya conway!
Old Apr 26, 2015 | 03:57 AM
  #286
Conway_160's Avatar
Conway_160
It looked like Bank 1 exhaust cam was out of time. Now I need to investigate why it still is missing and has a backfire.
Old Apr 26, 2015 | 07:04 PM
  #287
Conway_160's Avatar
Conway_160
Cleaned the plugs, drained about 6 gallons of old fuel out put 4 gallons of new fuel in and put a 32oz can of VP Octanium in. Car still misses and when you give it gas and let it out it pops backfires. It is looking like #2/6 is off some how. I'm going to let that fuel stuff set and then ill let it run for a few minutes tomorrow to see if that helps at all.
I'm out of ideas.
Things that I've looked at and/or fixed
#1 Crank Position Sensor- Put a new one in and plugs wasn't sparking. So put old one back in.
#2 Fuel Injector Harness- Had it backwards but now that's fixed
#3 Bank 1 and Bank 2 Camshaft Position sensors- Swapped the ones from the old motor onto this one, no change. (No you cant mix them up different sensors)
#4 New Spark Plugs- No change
#5 Moved Ignition Coils Around- no change
#6 Went from my 750cc injector map to my 440cc injector map- No change
#7 Checked all pins on Fuel injectors and ignition coils and the harness.
#8 Checked all Grounds
#9 Ensured all plugs are sparking.
WTF IS GOING ON IT'S DRIVING ME CRAZY ALL I WANT TO DO IS DRIVE IT!!!
Old Apr 26, 2015 | 09:12 PM
  #288
bealljk's Avatar
bealljk
^Dude - buy a label maker and label each and every coil, spark, injector plug along with label the cylinders on the valve covers.
I try my best to be bat-**** crazy about details when it comes to these little things...I etched in the numbering sequence, torque specs and other misc items into my timing chain case, intake manifold and plenum so they are immediately available and I have no excuse!
I'll snap a picture next time I'm under my plenum -which I will be to retry the det-can splice in...
with that being said - have you inspected your knock sensor? Can I assume that it's correctly installed and hooked up to the main harness? I know theres a few more wire harness back behind the plenum - like the EVAP gizmo back there (no idea what it's called) or the coolant temp sensor - I forgot to hook up those 3 things when I did my turn over and the car ran but ran like crap...
keep going - don't give up!
Old Apr 27, 2015 | 03:53 AM
  #289
Conway_160's Avatar
Conway_160
I've triple checked all my connecters. I may finish bleeding my clutch and drive the car around the block to see if I get any codes. I'm just really worried about the rings not seating correctly if the car keeps missing like it is and I keep having to start it to see if I'm making any progress.
Old Apr 27, 2015 | 01:28 PM
  #290
Conway_160's Avatar
Conway_160
well sent a log to Dynosty we'll see if they can come up with anything. I have attached the file so you guys can see what the car is doing as well.CIPHER_4-27-2015_2-51-41_PM.zip
Old Apr 27, 2015 | 04:44 PM
  #291
Conway_160's Avatar
Conway_160
So after talking with Soho motorsports and doing a little testing it appears that the motor is in time but the flywheel isn't. The car is running 30* timing at idle where it should only be running 15* or so they had me remove timing in uprev and see if the car responded and It did so that was a good sign so they had me look at Jim Wolf Technology's website and they have a pdf file on what the cams and flywheel are supposed to look like so I did it and the fly wheel don't match.
Here is what they are supposed to look like
http://www.jimwolftechnology.com/wol...tion_check.pdf
This is mine
Bank 1
Bank 2
Flywheel
So looks like I'm going to be taking the car to the hobby shop and removing the transmission this weekend. **** doing that in the garage!!!
I'm hoping this fixes my problems then I also need to remove a ton of timing from my entire map.
Old Apr 30, 2015 | 04:48 PM
  #292
str8dum1's Avatar
str8dum1
the flywheel is keyed for front (altima) or rear (350z). they should be clearly marked so hard to mess up
Old Apr 30, 2015 | 05:52 PM
  #293
Conway_160's Avatar
Conway_160
I, know that's why im so confused but better safe than sorry. When I put it together I used the marks on the flywheel and crank. But then again I thought I timed the car correctly the first time and I was wrong on that one as well.
Old May 1, 2015 | 01:27 AM
  #294
Resmarted's Avatar
Resmarted
Wow man that's really rough.
Thanks for documenting it, and many props for being so persistent. When my car is being a bish I put it off forever. Part of why I have an expensive hunk of junk in my garage
Old May 1, 2015 | 03:14 PM
  #295
Conway_160's Avatar
Conway_160
Well today sucked! I was hoping to find the root of all my problems but really I discovered I installed the flywheel correctly and that these new headers make putting the transmission in a F'ing nightmare!
Bank 1
Bank 2
Flywheel
So tomorrow I get to reassemble everything and see what happens, also I bled my clutch with a vacuum pump and I still only have 3-4" of area that feels like I have pressure "Never should have remove the rubber line!!!!"
Old May 1, 2015 | 05:41 PM
  #296
Resmarted's Avatar
Resmarted
I promise a power bleeder will make that clutch bleed a sinch.
As for the flywheel I would have been surprised if you put it on wrong. I'm pretty sure the fly wheel needs to be correctly timed otherwise vq's won't even start firing?
My car has been idling really rough (won't hold idle/pig rich/missfires like yours originally), but it's open headers atm (and oil lines open to atm/empty of oil) so I won't be trying to get it running correctly until I can quiet it down at least a bit.
So you're running Uprev correct? Did you check for vacuum leaks? How do the spark plugs look? Swapped around coils, no oil on spark plug boots, no weird spark plug gap, what heat level plugs? What's your base fuel pressure?
A friends rb26 had some wicked bad idling issues and would run really "lean" (jump from lean to super super rich) because it had a blown head gasket... But that probably isn't even close to your issue lol.
Old May 1, 2015 | 06:23 PM
  #297
Conway_160's Avatar
Conway_160
the bleeder I was using was working wonders I could watch the fulid come out. I would fill to max line and drain to min line. I repeated this process about 5 times.
Question: Should I be able to push in the slave cylinder by hand?
So orginaly I thought I lost my cps so I bought a new one from auto zone, finished the car and found my original one but allready had the new one installed so I left it. Tried to start the and wasnt getting spark so I put old one back in and viola it started. So long story short no with out a cps it wont start, not sure about timing.
what do you mean open oil lines??
Yes im running uprev. I've looked around every thing is connected, im going to do a smoke test tomorow to verify no leaks. I have nkg iridium 1 step colders stock gapping. Ialso have nkg coppers with stock heat range and gap. No oil on the plugs or boots, I've moved the coils around and the plugs all with no change. Base fuel pressure is ~52psi.
Anwsers in red.
Old May 1, 2015 | 07:17 PM
  #298
Resmarted's Avatar
Resmarted
Anwsers in red.
I prefer vacuum at the slave. It's really important for the reservoir to be as full as possible. If you have a hand soft pedal there's definitely air in there. If you bled it down to the minimum level, you could have gotten air in there at that point. As in you could have had it fully bled and then gulped some air. Kind of annoying.
As for crank yeah that's what I'd imagine would happen.
My oil lines: Feed is not attatched to turbo, return is on the ground lol. I'm switching from turbo to vortech.
And yeah the spark etc sounds solid. Is it possible your maf may have been damaged? It's unlikely a maf issue, but at this point I think it's worth crossing everything you can off the list.
I can't recall, do you have bad cam sensors? I think I've read a couple other people rebuild and have a cam sensor go bad.
And just curious, how did you re-time your engine? Did you pull the front cover off or was there an easier way?
Old May 2, 2015 | 05:25 AM
  #299
Conway_160's Avatar
Conway_160
It's a vacuum pump of sorts that I was using, ill mess with it more today.
Why are you going from a turbo to vortech? Is it at least a YSI?
Would a Maf cause #2 and #6 problems? I'll get some maf cleaner and clean it, it can't hurt correct?
It was a bad crank position sensor, but I have two sets of cam position sensors and they both acted the same way. Then again that was when my fuel harness was backwards. I'm putting in different cam position sensors in today so we shall see.
Old May 2, 2015 | 08:55 AM
  #300
2bad240's Avatar
2bad240
Here make sure your plugs are right.
