Procharged G35
Old May 2, 2015 | 09:21 AM
  #301
Conway_160's Avatar
Conway_160
Well car is leaking oil between my rear timing cover and upper oil pan. And still missing, looks like its about time to throw in the towel and let it set untill I can pay some to fix my mistake.
Old May 2, 2015 | 09:30 AM
  #302
Conway_160's Avatar
Conway_160
Your the best 2bad240. Ive swaped the dam coils around like 8 times with no luck and now it fixed it.
Old May 2, 2015 | 09:38 AM
  #303
Resmarted's Avatar
Resmarted
Lol! Didn't you have the same problem earlier in the thread? Well that is good.
And no I got a great deal on a TI kit. Reason is local LEO. Long story. Besides that my turbo system hangs low on the car and it's bothered me more and more over time. One bad bump could rip it all off or cause a crash at high speed. Not worth it. With my water meth system too, I'm not worried about my power goals. Anything the vortech can't make, a dry shot will help me reach.
Old May 2, 2015 | 10:46 AM
  #304
2bad240's Avatar
2bad240
It's good now?
Old May 2, 2015 | 10:50 AM
  #305
Conway_160's Avatar
Conway_160
Yes it no longer misses, now I need to figure out the stupid slip/traction control light and why its comming on. Then pull lower pan and re seal it , get tuned, tires and probably bushings.
Old May 2, 2015 | 09:56 PM
  #306
Resmarted's Avatar
Resmarted
I remember when I got my brand new r888's put on. The car's traction control light kept going off. Car was NA, so I just laughed at it and kept going.
Old May 4, 2015 | 04:59 PM
  #307
Conway_160's Avatar
Conway_160
So, car is up and running but I need to get my AFR's and Timing. Car is running rich and it fells likes it has no power at 3k+
Also figure out why my slip light is coming on, my steering angle is at -37* when wheels are straight forward. Is there a way to reset the steering angle?
Old May 4, 2015 | 05:08 PM
  #308
2bad240's Avatar
2bad240
Adjust steering shaft. Assuming you disconnected it.
Old May 4, 2015 | 05:40 PM
  #309
Conway_160's Avatar
Conway_160
I was trying to avoid that, I was hoping there was a relearn trick. But I will do what I have to fix it
Old May 4, 2015 | 05:57 PM
  #310
Conway_160's Avatar
Conway_160
well crap "To adjust neutral position of steering angle sensor, make sure to use CONSULT-II. (Adjustment cannot be done without CONSULT-II." Straight out of the FSM
Old May 4, 2015 | 07:25 PM
  #311
OldManZ350's Avatar
OldManZ350
I would think that if the wheels are pointing straight and the steering wheel is straight then it should be correct, unless it is 1 full turn out.
I'd try relocating it, in till you get it to "0"
The best way in the future is to "Mark it" or "not move it" after it's disconnected. A little thinking ahead saves a lot of time, but everyone misses something.
Old May 5, 2015 | 10:06 AM
  #312
str8dum1's Avatar
str8dum1
nope, you have to go to dealer to get it reset.
100$ when then did mine
Old May 5, 2015 | 11:17 AM
  #313
OldManZ350's Avatar
OldManZ350
Never had a problem with mine.
Old May 5, 2015 | 01:08 PM
  #314
Conway_160's Avatar
Conway_160
I'm going to ask the dealer what it cost if its more than 20, ill just do it myself.
Old May 5, 2015 | 05:29 PM
  #315
bealljk's Avatar
bealljk
Just asking the dealer what it costs will cost $20...
Old May 5, 2015 | 06:19 PM
  #316
Conway_160's Avatar
Conway_160
I know some people,
Old May 5, 2015 | 08:28 PM
  #317
bealljk's Avatar
bealljk
^ha! I was gonna say! a twenty? you may want to take a case of beer too?
Old May 6, 2015 | 04:25 PM
  #318
Conway_160's Avatar
Conway_160
So $186 to fix my Steering angle, and re do my oil pan so it doesnt leak any more.
Old May 7, 2015 | 09:38 AM
  #319
Resmarted's Avatar
Resmarted
If that's to reseal your upper pan (and they're actually going to remove it and re seal it) that's a great deal. You sure it isn't your rear main seal? Might be worth it to have them replace that too...
Old May 7, 2015 | 09:40 AM
  #320
NAbuilderZ33's Avatar
NAbuilderZ33
Just caught up reading your thread, Conway. Glad everything worked out and the worst of the issues you had are over. Seems like all thats left is the small stuff and a retune! Congrats!
