Anyone interested in a new custom intake for the DE motor?
Old Dec 10, 2010 | 05:19 PM
  #101
Zazz93's Avatar
Zazz93
Originally Posted by ChrisNelson
That's pretty crazy! Did that one make any N/A power?? Thanks for posting.
Makes tons of power on a fully tuned, ultra highly sprung NA application. I think their released figure was in the upper 400's at the crank (460-480).
http://www.fontananissanracing.com/About_the_Car.html
Old Dec 10, 2010 | 05:22 PM
  #102
Zazz93's Avatar
Zazz93
Did you include velocity stacks in your's?
Old Dec 11, 2010 | 08:17 AM
  #103
ChrisNelson's Avatar
ChrisNelson
Yes
Old Dec 11, 2010 | 02:46 PM
  #104
Zazz93's Avatar
Zazz93
Cool, I take it back. Looks efficient, now the real test: Flowbench, dyno, or both.
P.S.
Did you take measurements of the runner lenths and diameters stock and modified?
Old Dec 16, 2010 | 05:18 PM
  #105
ChrisNelson
Direct port is about finished. This will be an option when selling the manifold.
Old Dec 16, 2010 | 05:45 PM
  #106
omsin523's Avatar
omsin523
looking good man
Old Dec 16, 2010 | 05:46 PM
  #107
2004Black350z's Avatar
2004Black350z
Exhaust Whore
still in for results
Old Dec 16, 2010 | 05:55 PM
  #108
derekinthez's Avatar
derekinthez
bump for results too
Old Jan 7, 2011 | 04:39 AM
  #109
rich2342's Avatar
rich2342
Did you ever get a chance to dyno this yet?
Old Jan 7, 2011 | 01:41 PM
  #110
GeauxLadyZ's Avatar
GeauxLadyZ
+1 forgot about this.
Old Jan 9, 2011 | 07:17 AM
  #111
03basesedan's Avatar
03basesedan
I'm not seeing the rear cylinders starving, but I have a little bit of a question about velocity. The collector area looks like it may cause a bottleneck depending on the interior wall and horns setup. But, aside from that looks like a great prototype.
The Fontana guys used what I think is the best design for outright peak figures.
So hot...
If you can show dyno gains (without the typical tuner BS), etc., then a lot of people will be interested.
Bump for the OP.
Old Jan 11, 2011 | 04:49 AM
  #112
ChrisNelson
Thanks for the bump. Still in process.
Old Jan 18, 2011 | 09:00 AM
  #113
Steve-O Z33's Avatar
Steve-O Z33
I would like to see someone make a manifold like they have on LSX engines. Maybe make a wire harness to extend the drive by wire setup and TB to the front and even make a nice cover for the top to cover the wiring as it goes over the top. I think there is a lot of power potential in the manifold b/c the factory design has that bend in the neck. If air just went straight in, I think it would help a lot.
I'm still anxious to see the results of this but with the bend, I think there will still be room for improvement.
Old Jan 18, 2011 | 01:43 PM
  #114
snobes's Avatar
snobes
Can't do that to our car like the lsx.
Our bonnet is to low and we have the timing chain cover in the way
Old Jan 18, 2011 | 01:49 PM
  #115
kacz07's Avatar
kacz07
Making power, especially to redline, seems to be held in the plenum volume. Increasing the volume from the TB to the heads is where you'll find effective gains. If this plenum has increased volume in that area, it will make high RPM power. If it doesn't, my bet is that it will be comparable to current manifold options. If the runners are longer than stock and the volume is smaller than stock, expect to see losses and peak power being made below 6250rpm. I'm curious to know how much R&D was done with these key points in mind.
Old Jan 18, 2011 | 01:51 PM
  #116
kacz07's Avatar
kacz07
Wrong.
http://speedforceracing.com/index.ph...&productID=929
Old Jan 18, 2011 | 02:56 PM
  #117
SexyRob's Avatar
SexyRob
wow looks sick with all the nitrous hardlines.
Old Jan 18, 2011 | 03:38 PM
  #118
snobes's Avatar
snobes
Originally Posted by kacz07
That's nothing like the ls series manifolds that enter in the front in the middle like what was talked about
Old Jan 18, 2011 | 05:01 PM
  #119
SexyRob's Avatar
SexyRob
think he meant this.
Old Jan 18, 2011 | 05:15 PM
  #120
snobes's Avatar
snobes
Steve-o ment the log manifolds that sit inside of the valley and go forwards where our timing chain is
