Tire FEATHERING: FYI
Originally posted by Michael-Dallas
At 9k miles, my RE040's were feathered, but I still had plenty of tread left. The feathering was mostly a noise inconvenience for me and not an accelerated tire wear problem. I could have easily gone up to 15k w/ them, but the 4 track weekends I did chunked the center tread...
If you separated the tread blocks the reason is obvious, what I am more interested in is to what side did you scrub off the tread if you got the rollup of rubber on the blocks - there is a long-standing caster/spring/rebound relationship you derive from what direction and degree of wear you see on the track with treaded tires...I did not separate the center tread but did see wear consistent with either too stiff springs matched to slow rebound, or caster settings when running my stock 350Z on the track...and despite babying the brakes in the extreme, they just weren't up to the task (stock, not Brembo)
Thanks.
For more pics of the wear I ran into see:
http://homepage.mac.com/stracy01/Auto/PhotoAlbum12.html
There's been too much of a lynch mob mentality and too many half-baked conspiracy theories on this board regarding to tire wear.
Tires are a consumable item and Nissan tuned the 350's handling characteristics w/ the alignment specs. Otherwise, the 350 would be no different in handling w/ a G35 sedan, which shares the same suspension design.
You guys make it sound as though the 350 is the ONLY sports car (keywords: sports car) out there w/ tire wear issues. The Acura NSX is considered one of the best handling sports car out there. Ever consider the reason why? Perhaps this will shed some light. Pay particular attention to this comment made:
After a class action lawsuit about what they considered to be premature tire wear, the rear alignment settings were changed. With less rear toe, the rear tires last longer. There is no reason you can't run the original '91-'92 settings if ultimate performance is the goal and tire life is not a primary concern
Michael.
Michael.
I plan to go back to my alignment specialist and get his opinion on the TSB this week, if I can. If I have anything useful to report, I'll post it here.
Originally posted by SteveZ
I read your linked article. I'm not sure what your point is, read this thread and you'll find lots of references to Audi TT's and other cars with the RE-040 Bridgestone with poor wear, but not with uneven feathering/cupping wear. People on this forum are not ignorant of other cars' wear issues - just the opposite, they're not happy because compared to other Sports Cars they're seeing worse than they expect. It's a well-informed group despite the occasional juvi response you see.
If you could attribute this issue to just the RE-040 the first replacement set of anything else would likely have ended this issue a long time ago. I lost over 2X the wear on the insides of my tires at 6k over the outer side. Swap the tires, fine, but the wear was on track for rendering the fronts utterly gone by 15k or a little more, with a lot of tread still in the middle 70% of the tire and the shoulders shot. If this was due to hard cornering, I'd expect the outer shoulder to wear instead.
Stating the 350Z as essentially the same as a G35 Sedan isn't a good comparison. It is shorter, has different braking characteristics, stiffer springs, less HP in the Sedan, and I believe the majority came with tires other than the RE040's.
One inconsistency is the G35 Coupe pulls .94 g's on the pad, is faster through the slalom than a track Z. I seriously doubt a heavier car with a longer wheelbase would do so with "the same suspension" and harder compound Michelin P/S tires.
Also, check out the long term R&T test car:
http://www.roadandtrack.com/article...2&page_number=1
Same issues with pulling to the right, but they massaged 19k out of the RE-040's somehow.
If soft compound put in there for handling was the main cause, as I understand your post, we'd just have replaced with harder tires. But, the Michelin P/S has a higher wear rating, same traction and temp ratings, but manages to last longer and stick almost half a g better than the stock 350Z Track on the skidpad. Why didn't Nissan just put these on the Z? Easy - $$$.
I don't think you can dismiss the wear as normal, and comparing over 40,000 350Z's to the experience of NSX owners just doesn't seem relevant.
Did you chunk the tread as in separation of the blocks or scrub it? Did you get the worn rubber rolled to one side or the other of the center tread blocks?
I've got close to 4k on my S-03's and new alignment (I asked for a little toe-in). I've done 2 track weekends w/ them and tire wear is fine w/ no tire noise / rumble.
Michael.
Sorry - one point your link mentioned that is worth looking into -
"The car wants the tire go straight when the alignment setting makes the tire want to turn, thus, (simplified) the car is dragging the inside of the tire more than the outside. and wearing the inside. Hard cornering does not effect wear as much as straight line driving."
I did very little HWY miles compared to a mix of rural and city. I noticed a lot of people I've talked to with rapid tire wear (<5K feathering) "just mostly drove to work and back on the highway"...mine didn't really show the wear until 6-7k.
I dont know if this is acceptable......but without reading all 104 pages, can someone please tell me if my dealership has to replace my front tires due to excessive wear on the insides of the tires (feathering)? The dealer has rotated the tires in the front and said this is all they can do and it's normal for this type of car to have this type of wear. FYI they just replaced my front brakes again and shaved the rotors.....I have 13.5K miles
They do not have to replace them. The key is finding a dealer that will. I have been to 2 dealers and neither of them would replace them, the one I bought it from and the dealer where I live now.
The point is that the 350 isn't the only sports car w/ tire wear problems.No kidding? "I didn't have to graduate from Lincoln High School to know that" (apologies to Eminem)
The NSX also had tire wear problems and after a class action lawsuit, Acura updated the alignment specs. The answer is a simple as playing w/ the alignment settings. No big conspiracy theory about flawed suspension design.
Well, that settles it - if changing the 4-wheel specs worked for a completely different Honda car it must be the answer for the 350Z. Nissan has had ample opportunity in 16 months to update specs and offer the same service if your solution is the "answer". You should not have to go to a Class Action lawsuit for this. BTW, the only conspiracy theory I subscribe to on this issue is mis-management on the part of NNA and inconsistent execution on alignments. Not exactly the X-files...
Do you understand the affect of negative camber and toe-out?
Yes, but you told me anyway
The suspension design is the same (you should be able to buy the NISMO S-Tune springs and shock absorbers and install them on a G35 sedan/coupe). This indicates that the suspension is NOT faulty in design, otherwise, we'd hear about tire feathering problems from G35 sedan/coupe owners.
Not sure what you consider as "design" - I would include spring rates, unsprung weight, all components including wheels and tires as the "original" design. That seems to have a few issues. BUT - no question the Pilot Sport is a great tire IMHO. If the Spring rate and shocks are the same as my '03 Z, well, they're not. My Z was noticeably stiffer in the springs and felt lacking in rebound dampening, from day one. The '04 G35 does not.
Doubt all you want, but it's the truth. The max performance Pilot Sport are just a far superior tire (w/ SOFTER compound) over the ultra-high performance RE040. And the longer wheelbase will certainly improve balance and slalom. If you want my guess, the low skidpad number is probably because of the understeer dialed from the factory. I can almost guarantee you that w/ S-03's and the full S-Tune suspension, the 350 will produce a better skid pad number than .86/88.
0.92 vs. 0.88...stock. So now what would the G35 do with S-tune...blah, blah, blah - compare stock to stock, after all, "Nissan had specific handling in mind..." That's like saying my Silvia drifter can beat your Dad's car on the skidpad. Sorry, that's a huge difference for the "same" suspension except for tires.
My position is you should not have to shell out the $$$ for S-tune just to get "normal" wear for a sports car. I don't personally have an issue with upgrading the car, that's great, but I do have an issue for all the people who just want to buy it and drive it moderately.
Like I said, I could have gone to at least 15k miles on my factory RE040's. The tire feathering was not as much a wear problem for me as it was a noise problem.
Noise is not a problem? Maybe not on the track with the windows down at 6000 rpms. NVH is a huge factor for many people buying yes, even a sports car. I could also have gone 15k with my RE-040's, BUT as my photos show, the uneven wear likely cost me another 5k miles on top of that.
... Nissan chose the RE040 because they wanted the 350 to handle a certain way.
No kidding - I thought maybe it was pure coincidence.
You're not a freshman college prof by any chance?
The inner and outer tread blocks were fine (except for the inner feathering pattern).
Fine...except for excessive wear, noise, and premature expiration...guess we have a different definition of fine.
Almost the same things I experienced with 040's at 4k...no issues. You also know just like I do that tracking the car changes the wear dynamics in a compressed manner w/re to time. Daily-driver-only people never see the temp or loads on their tires you and I have. You're comparing your experience to a universal solution - "just play with the alignment specs" - sounds like a new Nissan TSB.
So, just buy some more tires, S-Tune, get a proper alignment? If that's all you had to add, been there, heard that...and you could have saved your lecture for next period.
You're not a freshman college prof by any chance?The inner and outer tread blocks were fine (except for the inner feathering pattern).
Originally posted by grifferjr
nothing that new to add other than my own personal experience that will help because i was in the same boat as you, over 12k miles ... well here's the shocking news: NISSAN EVEN DENIED MY MANUAL GRT!!! Well this is where i got stern with the dealer and after some back and forth the dealer has to be the one to pay for the bill on the tires, NISSAN WILL NOT. My dealer rationalized this by admitting to me that NNA alluded to some kind of recall in jan-feb 04 in which time the dealer would be reimbursed for the tires. sorry for the length but thats the way to handle over 12k cars.
Well, that settles it - if changing the 4-wheel specs worked for a completely different Honda car it must be the answer for the 350Z. .. BTW, the only conspiracy theory I subscribe to on this issue is mis-management on the part of NNA and inconsistent execution on alignments. Not exactly the X-files...
etc. etc.
etc. etc.
You sure do like to argue just to have the last word, don't you?
https://my350z.com/forum/showthread....light=tire+tsb
There's your new TSB. Read it carefully. What does it say about the preferred toe setting and alignment machines? Lemme guess... you still have doubts about it.
All I can say is that it works for me and droid. And if you haven't tried it yet, then you have no room for criticism. You asked your questions, I gave my answers (many I had to repeat since you obviously don't read my posts carefully).
Out of all your replies to droid, none contributed any useful information. Out of all your replies to me, none contributed any useful information. Your reply is as classy as droid's post. NICE.
Michael.
Michael.
Michael.
Michael.
You didn't add anything new at all; you'd know that if you read much more than your own posts. Check all my posts and photos on this thread - pics of the wear, accounts of all dealer and other...listened to my friends' try not to get into Lemon Law issues, posted TSB's and the results I found...
I have to have the last word? Read more carefully? Droid-boy swears a blue streak and tells us all to "**** off" if we don't agree with him??? You tell us to go get a real alignment and stop making such a big deal about things?
Go hang with your boy Droid, you can play "who's biggest/baddest" with each other.
Originally posted by bhobson333
Frankly, I appreciated Michael-Dallas's informative post. Your dripping attitude didn't add much to the conversation, though. It's certainly not productive. Why do you still hang around? To bash? Aren't there any G boards for you to haunt?
I'd think rather than dissing the G's you'd maybe want to take a look at what they are doing differently, maybe draw your own conclusions. When you've put a few thousand miles in both cars, then let's talk. I have - starting with 15 months in my 350Z.
BTW, head to the top-level menu and you'll find G35 Sport Coupe in this forum. So yes, I do have "G" boards to "haunt" - you're reading one, fool.
Go play with your alignment & tires, and speculate all you want - been there, done that. Personally, I'll just drive my car and not worry about feathering or ******** with giant egos...I'll just enjoy the ride.
Like I told the droid when he wasn't telling everyone to fvk off, nothing new here, not rocket science, and cars with this TSB applied still have the issue thousands of miles later.
Get this through your thick TX head(s) - alignment and/or new tires alone do not solve this problem. Even a quality alignment. You cannot say it worked for you when you and droid-boy went to S-Tune suspension and other mods...well, you can, and be incorrect, which does not seem to be an issue for you.
This BS/TSB does not fix the stock car setup, period. Note they still tell you to swap the tires side to side so you have some fresh rubber to slice and dice.
So go argue this to death, swear at each other and the world, let me know how it works for you replacing tires every 10-15k max, rationalizing the expense in the name of "sports cars". Duh - no wonder Bush wants "no child left behind"...
Can't we all just get along here?
And SteveZ please stop referencing them as the "TX boys" as you may have noticed there are more then just two boys from Texas on this board....no offense ofcourse Brad and Michael
I called the BBB yesterday and re-opened my LL case. The "clicking" sound has returned and since Nissan conducted the "final" repair on 1/5/04 - that's it as far as I'm concerned.
The BBB is going to notify Nissan that I am not happy with the final work and that the problems have returned in less than 2 weeks.
all I have to say is..... $hit!
After watching and reading this thread for over a year now, I think we're starting to get somewhat over-reactive with one another. Frustrated; yes. Given that we all want the same thing out of this in the end, which is to have our Zs work the way they were intended, the sniping at one another makes us look like a bunch of children. I expect that from my college aged son. We have to keep on topic, stick together, focus on the technical issue here and keep the emotions in check. Keep in mind NNA is also reading these posts as well, they are not blind or stupid.
To Boomer, ChinaClipper, Droid:
Having said that and my tire problem "fixed" in October with the alignment and new RE040s, I wonder if there is a "Time" limit on whether or not NNA will replace the replacement tires when they finally feather again after 5,000 miles or so? I hope they won't but I'm not convinced the feathering has been cured. Since the winter has set in and there's snow and salt all over the place here now, I use the Z less than once per week, and it will be May/June before I put another 5,000 miles on it.
Also, I don't plan to alter my Z in any way from stock since it's got such a low VIN, so Nissan's delaying this gets me concerned about the "Time" element [read this as: I'm going to have to pay for the next round of alignment / tire replacement out of my pocket if the clock runs out].
PS: Replaced Trans. after six months + continues to be perfect.
