Weird noise
Old Apr 28, 2008 | 03:49 PM
BlackoutBeds's Avatar
BlackoutBeds
Default Weird noise
i was on my way to URI last sat and while cruisin on the highway, everytime i would give it a little gas past 77mph it would make this low whistle sound, and wen i let off the gas it would go away...does anyone know what it could be??
--it doesnt do it any time below 75mph...could it be a sign to slow down hah
Old Apr 30, 2008 | 07:15 AM
BlackoutBeds
no one has any clue??
Old Apr 30, 2008 | 07:38 AM
cheshirecat79's Avatar
cheshirecat79
is it engine related or body dynamics related? if it's engine most likely you would hear the noise at the same rpm regardless of what speed you are going. if it's aerodynamics, it would be speed-based and would be wind whistling through a crevice somewhere. some people have complained about wind whistling through the side mirror housing.
Old May 1, 2008 | 08:02 AM
BlackoutBeds
its only wen i step on the gas at that certain speed or if i set it on cruise control it will make the noise until i turn it off...it starts as soon as i give it the smallest amount of gas after 75mph
Old May 1, 2008 | 08:37 PM
got556's Avatar
got556
I have the same thing. Mine is an 04.5 btw.
Anytime above 80mph more so for me. But coasting at 80 while the foot comes off the gas...no noise. But after pressing back into the pedal no matter how much gas I give it....it gets the noise....
Weird...and since two of us have this, I'm wondering if more have the same thing.
FYI the motor runs strong at 23K on the ODO and don't have any other weird noises coming from it.
Old May 3, 2008 | 09:37 AM
BlackoutBeds
exactly my prob brother
Old May 4, 2008 | 01:18 PM
jray8's Avatar
jray8
it either the differential, tranny or tires, there are several threads on this, most say its normal, i have the same noise
Old May 4, 2008 | 03:11 PM
Rommy's Avatar
Rommy
I have the same thing as well. 80MPH+, there's a whistling noise. Hopefully nothing bad, but it scares me. This car makes me so paranoid sometimes.
Old May 26, 2008 | 07:44 PM
Ruinizer's Avatar
Ruinizer
in my 06 i get a whistling noise that seems like it is audible through the air vents while pressing the accelerator in any gear and is higher in pitch as the RPM's increase.... it is independent of the air conditioning system as it does it if the air is turned off and the same with radio and everything i have tried
Old May 27, 2008 | 09:05 AM
BallZdeepNYC's Avatar
BallZdeepNYC
go get ur car checked at nissan mine was cause somehow rear passenger strut arm or something was slightly bent
Old Jun 11, 2008 | 01:14 PM
rockinbboy's Avatar
rockinbboy
I seem to have a weird noise at 80 mph, but only if the throttle pedal is pressed. I can't say its a wind wistle noise as it does sound more mechanical. The sound is very very subtle. I didn't think much of it until I noticed it happened exactly at 79-80 mph and its consistent.
I have no clue. Could be a number of different things as people said in above posts.
Old Jun 11, 2008 | 04:58 PM
BlackoutBeds
now it does the low whistle noise in every gear higher then 3rd at low rpms only...between 2k-3k
Old Jun 26, 2008 | 05:54 AM
350z-Helsinki's Avatar
350z-Helsinki
It's the popcharger or intake and it's normal
Old Aug 25, 2008 | 01:10 PM
rockinbboy's Avatar
rockinbboy
Update: I don't hear the noise anymore. I also changed my tires/air filter and then the noise disappeared. Could have been tires and/or my air filter.
Old Aug 26, 2008 | 10:20 AM
j.arnaldo's Avatar
j.arnaldo
Silent beaZt here!
____________________________________________________________ _____
'O4 Touring Coupe! FLAWLESS AT!! 13k!!! $2O,5OO!!!! NO feathering!!!!!
Obadabot
Jun 18, 2023 11:31 PM
Uriyo_
Sep 8, 2021 08:46 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
