How-To Repair Stuck / Broken Window Motor ...
Old Sep 6, 2012 | 04:39 PM
  #461
Kingeddie's Avatar
Kingeddie
Originally Posted by bmyles
A little while, but it's way overpriced.
really? well i found it for 200shipped new oem and thought it will last me couple years and 150 refurbished after the core at a local auto part store, but with lifetime warranty i don't know what to do lol.
Old Sep 27, 2012 | 12:39 PM
  #462
Rodney Litorja's Avatar
Rodney Litorja
Default Window Up is down / Down is up
I searched around the site but couldn't find an answer. My drivers side window button is upside down... Any ideas? thanks in advance.
Old Sep 27, 2012 | 03:16 PM
  #463
bmyles's Avatar
bmyles
Umm...is it literally mounted in your door upside down, or does it operate backwards? Need a pic/better explanation.
Old Sep 28, 2012 | 07:36 PM
  #464
Rodney Litorja
Well when I pull up on the drivers side window (button) the window goes down. when i push down on the button the window goes up.
Old Sep 29, 2012 | 07:23 AM
  #465
coanan's Avatar
coanan
Sounds like the wires got switched in the plug on motor or harness side. Who worked on it last?
Old Sep 29, 2012 | 08:31 PM
  #466
samsniss350z's Avatar
samsniss350z
my 350Z is suffering the same problem here in the UK, its going in under warranty next week and i'm going to insist they put a new motor in. I've had 2 UK 200sx's, one with 130,000 miles on the clock and never had any problems like this. Like the 'clicking' axles the motors seem to be a weak point.
Old Sep 29, 2012 | 10:41 PM
  #467
grekker's Avatar
grekker
Bought my first Z (been saving up forever for one ) and after a few months the driver-side window started acting up. It's gotten to the point where I don't even try to put it down anymore (or can't).
Came here looking for some clues and I'm both pleased (guides and advice) and disappointed (sucks that it's so common) to see how many other people have similar problems.
The car is an '08 350z with just 14k miles on it, so I'm bummed that it's already having window motor problems.
Looks like I'll be spending some time reading up a bit more on the different things people have tried and coming up with a plan for working my window.
It's kind of embarrassing every time I pull into a parking garage, tollbooth, etc and have to open the door to grab tickets, etc.
Old Sep 30, 2012 | 04:31 AM
  #468
bmyles's Avatar
bmyles
Yeah, I had to open up my door once, and that was enough for me. I hate having embarrassing things wrong with my car. I need to do my passenger side motor at some point. Just putting it off because it's not broken yet, just slow, heh.
Old Sep 30, 2012 | 11:24 AM
  #469
blAk mAx's Avatar
blAk mAx
Just an FYI if it's stuck down you can get it to go up by slamming the door while holding the up button
Old Oct 2, 2012 | 03:43 AM
  #470
ShMiCk's Avatar
ShMiCk
To the OP, many thanks for this, fixed both my drivers and passenger window!
1 issue though, the passenger window has that weird thing were if you press the auto-up button to shut the window, it will go all the way up then half way down again. When I open the door as well it doesn't go down slightly then up again when I close it.
Now, I know that there is a reset switch guide, but my 2003 350 doesn't have said button! Instead it's just a hole, this is the same for both windows (but drivers window has no problem).
Does a 2003 350 have the reset button elsewhere or is there another way of resetting the passenger window only?
Many thanks.
Old Oct 2, 2012 | 03:17 PM
  #471
bmyles's Avatar
bmyles
I have an '03 and I have the reset button on the driver side. Haven't checked the passenger side, but it's supposed to have one. It sounds like someone put remanufactured motors in there without buttons...
Old Oct 2, 2012 | 04:45 PM
  #472
tblunt1's Avatar
tblunt1
Could try the 3rd response in this post, I have no idea but a couple responded that it worked for them. I have NOT tried this, I reset mine with the button after rebuilding it (And for some reason have had to reset it like 3 times now). https://my350z.com/forum/maintenance...dow-motor.html
Old Oct 3, 2012 | 09:03 PM
  #473
samsniss350z
Give vo7848 a gold star for entering this onto the site. It's the most comprehensive pictorial presentation as to how to fix a faulty motor i've seen and i've been searching, UK, Canadian and all other English language sites for weeks. A lot of the other sites give part of the detail but seem to miss out the most important instructions/pictures rendering instructions at best confusing, at worst unusable. Thank you again.
Old Oct 16, 2012 | 07:31 PM
  #474
lfuentes92's Avatar
lfuentes92
please help i took the motor out of the housing cleaned it and everything and it doesnt want to go back in please help
Old Oct 17, 2012 | 02:14 PM
  #475
bmyles's Avatar
bmyles
Picture...
Old Nov 3, 2012 | 07:19 PM
  #476
masphx's Avatar
masphx
For those with the 07-09 350z our inside panel is different from the 03-06 Zs shown in the original thread. Use this link to see how we remove the panel. Seems easier then the 03-06 Z's so that is good news. I did my driver today and the mechanics under the panel seems the same as the earlier models. Window works great for now!
https://my350z.com/forum/audio-video...r-install.html
There is my contribution to this thread.
Mason
Old Nov 4, 2012 | 07:40 PM
  #477
samsniss350z
Wow what a comprehensive guide, i could almost have been looking over your shoulder whilst you were doing it. For that sir i thank you. I was lucky enough to get my drivers door done under warranty but have noticed that the passenger window is starting to get slower and slower as it winds down. I wouldn't have noticed it if it weren't for the new motor. My warranty has since run out and i was dreading trying to take it to bits with no guide, but thanks to your brilliant guide i can attack it with confidence. THANK YOU.
Old Nov 12, 2012 | 01:41 PM
  #478
jhonster's Avatar
jhonster
Default Any Nissan techs out there?
Hello there...John here =))
I just signed up to this forum to see if I could find a little more tech info regarding the pwr window systems on these Z's.
A little background about me. I'm a 35 year tech that's worked on a lot of computer controls & electrical systems on pretty much anything. Worked for GM for many years & then went on to open my own place for 11 years. Taught at Snap On Technical Training for about 10 years teaching driveability diagnosis, yadda, yadda, yadda. I guess what I'm saying is....I'm no dummy when it comes to diagnostics. I work for the Fire Dept now as a mechanic.
Now....I'm doing this for my girlfriends son who has no money, so I'm trying to help him out.
The car is an 03 Z & the passenger side window is inop. The window is sitting about 1/2-3/4 inch down & doesn't respond to hitting the door. Now, I've gotten a factory schematic & ck'd all the inputs & outputs, grounds, etc to the passenger side switch. The only thing I haven't look at is the digital signal (power window serial link) from the body control module to the passenger side window switch. I've swapped out the switch w/a good used one & same with the motor, still no operation. Can a grounded serial data link cause the window to not operate? I haven't whipped out my lab scope yet to ck to see if there is digital talk on the line, but I'm starting to think this might be an issue seeing how in the factory schematic shows a digital line out on pin 16 to the switch, then from the switch out on pin 12 to the "encoder" on the motor . I don't have a Consult, otherwise I would have scanned the body control module by now. Any insight into how the system works would be greatly appreciated. Thanks in advance.
John
Old Nov 12, 2012 | 02:10 PM
  #479
Fryrot3's Avatar
Fryrot3
When replacing my motor I pulled all of the wires out of that white sub switch on the passenger side. My question is, while someone is replacing the motor do you think you could write me up a dummy schematic and tell me what colors go into what recepticle/hole? Ex/ starting from top left hole one receives white, and hole two recieves brown etc.. I would much appreciate it.
I have an 03btw, idk if there's a diff in years.
Old Nov 12, 2012 | 03:06 PM
  #480
jhonster's Avatar
jhonster
Here's a schematic I drew. Just waiting for the pics to upload from my iphone of what it looks like all wired in. The little square at the top of the connector is the locking tab & its a view from the backside of the connector. Good luck.
Attached Thumbnails How-To Repair Stuck / Broken Window Motor ...-350z-passenger-side-window-sw-schematic-2.jpg
