my turn
Old Feb 9, 2012 | 12:07 PM
  #181
mgrotel's Avatar
mgrotel
i really dont think my timing is off, im almost willing to put money on the oil, but we will see after tonight
Old Feb 9, 2012 | 08:22 PM
  #182
johnwigs's Avatar
johnwigs
well 3 scenarios cause a timing DTC
1. cam timed wrong, you are pulling it apart to reset timing
2. cam sensor problem (sensor or trigger on cam), may need to be pulled apart
3. solenoid is somehow jammed causing an advance, easy fix
scenario 1 will show an advance of about 7* being a tooth off when you monitor
scenario 2 will show either 270* or just show nothing
scenario 3 maybe diagnosed with just unplugging your solenoids, car will start fine (just no power over 3000rpm)
Old Feb 9, 2012 | 10:18 PM
  #183
bjmax's Avatar
bjmax
scenario 1 can be easly checked by using this template.
http://www.jimwolftechnology.com/wol...c_template.pdf
Old Feb 10, 2012 | 05:13 AM
  #184
mgrotel's Avatar
mgrotel
Bank 2 solenoid was leaking, tightened it down and still got a p0021 code, but idles much better and no random misfire
I need to look up the torque on the solenoid bolts and get a new gasket I suppose
Old Feb 10, 2012 | 06:12 AM
  #185
mgrotel's Avatar
mgrotel
And I just realized I have a complete spare motor for parts here so I have both solenoids to swap out for
Old Feb 10, 2012 | 06:14 AM
  #186
mgrotel's Avatar
mgrotel
Any one know the torque spec for those 3bolts on the solenoid?
Old Feb 10, 2012 | 07:28 AM
  #187
bjmax's Avatar
bjmax
Old Feb 10, 2012 | 10:24 AM
  #188
mgrotel's Avatar
mgrotel
12Nm
Thanks bro
On another note, when the code showed up earlier today I could actually feel a decrease in power because I was accelerating at a constant rate and when the light popped up, it was a definite difference in power. New oil and filter quieted the motor down a lot
Old Feb 11, 2012 | 07:24 AM
  #189
mgrotel's Avatar
mgrotel
well, im getting really frustrated. yesterday it was running fine with the exception of that 0021 code every once in a while, but then later in the day it started clattering really bad at idle again (see video). only thing i can think of is that it doesnt get oil pressure at idle, cause if i rev it at all, then the clattering goes away. i have spare solenoids and both cam sensors so i will probably just swap those 4 parts over from my old motor to see if does anything different. any other ideas what would cause this noise?
Old Feb 11, 2012 | 07:58 AM
  #190
bjmax's Avatar
bjmax
Swap them. But don't you have a oil pressure gauge in a G35? If so what are those readings?
Old Feb 11, 2012 | 02:13 PM
  #191
mgrotel's Avatar
mgrotel
No oil pressure gauge
Old Feb 12, 2012 | 01:26 PM
  #192
kacz07's Avatar
kacz07
How is your idle? Rpm? Stable? Throttle response from idle?
Old Feb 12, 2012 | 02:22 PM
  #193
Classy's Avatar
Classy
ouch, that video sounds terrible, have you logged what your vtc is doing yet??? That can maybe narrow down the issue. I hated being in this spot when I first got my motor running... I am very much so looking forward to working on my next project car with a much simpler motor, haha
(PS, I already know what I am going to do)
Old Feb 12, 2012 | 05:28 PM
  #194
johnwigs's Avatar
johnwigs
building your own motor your self, saves $
having to build it twice, $$$$
having a professional do it right the first time, priceless
Old Feb 13, 2012 | 03:08 AM
  #195
Classy's Avatar
Classy
This kinda stuff irritates me... I have gone through a very similar problem when I built my motor, and after it all I would not have traded it for some shop to do the work, there only 3 shops in the WORLD that I would have do this kind of work for me and there are nightmare threads all over the Internet about shady shops.... I know I did the work, I know I did it right.
Mrgrotel, keep up the good fight and get it fixed!!!
Old Feb 13, 2012 | 03:44 AM
  #196
bjmax's Avatar
bjmax
He is going Fix this.. I done my own Engine.. Learned a lot of it.. not many people can say that. What Classy say's there a lot of threads that it goes wrong at the shops.. so yes if you don't know how to change oil leave it to the shops and hope your lucky and get it done as it should be. can you work on the engine and have the right tools, go for it.. And so what, you take it a part again.. thats the game... just go for it and use the Nissan book for reference. get stuck were to help out.
Old Feb 13, 2012 | 07:03 AM
  #197
mgrotel's Avatar
mgrotel
put on a spare bank 2 solenoid and have gone 55 miles without a code, normally it would have thrown the code about 3 times already. but still have the bad noise at idle, sounds great and has good power above idle though. ill get on osiris eventually and see if something looks odd. i hope its not the damn revup oil pump, that ***** was brand new.
i am very confident that what is going on in there had nothing to do with assembly, but a bad part instead.
Old Feb 13, 2012 | 07:31 AM
  #198
mgrotel's Avatar
mgrotel
it idles about 600rpm and it is stable. throttle response is great, and no noises at all whatsoever after it comes off idle, power seems good too. if i had the idle set high, it would never make a noise and no one would think anything was wrong with it, no codes anymore either. idk, i think oil pressure just drops when its idling
Old Feb 13, 2012 | 07:38 AM
  #199
bjmax's Avatar
bjmax
Get your oilpressure read asap.
Old Feb 13, 2012 | 08:07 AM
  #200
mgrotel's Avatar
mgrotel
are there procedures for that? where do you get an oil pressure reading? osiris?
