87mm TB Project
Old Dec 19, 2014 | 11:01 AM
  #301
m e l l o w's Avatar
m e l l o w
Fixxxercask, What thickness did you end up using with the pipes and sheets?
Old Dec 19, 2014 | 11:24 AM
  #302
Fixxxercask's Avatar
Fixxxercask
1/8"
I plan on doing some more work tomorrow on it. I am cutting everything off I've done and starting over. This is proving to be pretty tough, but I will get there.
Old Dec 19, 2014 | 06:52 PM
  #303
bealljk's Avatar
bealljk
Rome wasnt built in a day...keep going, one step at a time and you'll get there!
Old Dec 25, 2014 | 10:15 AM
  #304
Fixxxercask
So I scrapped my first plenum. It was proving to be a dead end and I didn't plan it out well enough from the start. Started on a 2nd much more simpler design. It is similar to the one someone posted in the thread earlier. The only difference is that I am not going to put the TB all the way down where OEM filter sits. I will find a way to get it to fit near OEM location. Here is what I have so far.
Old Dec 25, 2014 | 11:33 AM
  #305
Classy's Avatar
Classy
I liked where you were going with the first one, doesn't seem like you will have enough clearance with the second one
Old Dec 26, 2014 | 11:09 AM
  #306
Fixxxercask
I am concerned about the clearance with this one as well. I might cut some of the sheet metal out around the brake booster area and all that. I've been wanting to do that anyway for a long time to cut some more weight. I hate how cramped these engine bays are.
Old Dec 26, 2014 | 11:37 AM
  #307
Classy's Avatar
Classy
A lot more room with a ls in there
Old Dec 27, 2014 | 03:48 AM
  #308
Fixxxercask
Haha...indeed
Old Dec 27, 2014 | 04:45 AM
  #309
mw9's Avatar
mw9
I would have to agree
Old Jan 1, 2015 | 01:40 PM
  #310
M-train's Avatar
M-train
Question, since you have the most experience with the uprev, and bigger throttle body.
Is it possible to tune with the uprev to make a bigger tb work, or is it just not doable?
Old Jan 2, 2015 | 11:20 AM
  #311
Fixxxercask
I definitely do not have the most experience with Uprev. I am a newb at best.
The only reason I chose this TB was because I heard the internals of it are made by the same company (hitachi) and they should work without too much change.
Other TB's though I would think would prove to be a lot more work. If I had the extra cash right now, I would probably go full stand alone.
Old Jan 2, 2015 | 01:02 PM
  #312
M-train's Avatar
M-train
What, in your opinion, is the sticking point to getting the uprev to work with this tb?
Does it, the uprev, run out of parameters to set, or ????? I agree, stand alone would be great if it weren't so expensive.
Old Jan 2, 2015 | 01:18 PM
  #313
Fixxxercask
To be honest after fiddling with it a bunch, there really isn't anything in TB that needs changed. Well, after I figured out that I had wiring problem and corrected that, I set the TB table back to normal since all the changes I had previously made were for nothing since it was a wiring issue the whole time.
The only outstanding issue that I have with it is getting it to idle on cold starts. I am not sure what I am going to do about that yet. I will cross that bridge once I get this plenum done.
Old Jan 3, 2015 | 12:32 PM
  #314
M-train's Avatar
M-train
That is good news! Getting it to run in all other conditions with only a cold idle problem is a success in my book. Good job. Looks like you have cracked the code for doing this with the UpRev instead of a stand alone setup.
I hope you don't mind if I send you a few more questions via PM on this........thanks.
Old Jan 31, 2015 | 06:47 AM
  #315
Fixxxercask
Sorry no updates on this lately. I put it on hold for the last so many weeks and did a bunch of suspension work. Had to tear down most of the rear suspension to install the last of my SPL bushings. The entire car now has all SPL including subframe and diff. Also just added the SPL titanium camber and traction arms and had to replace one of the rear wheel bearings. Suspension is all back together.
I just got back from a much needed vacation in Mexico away from this frozen tundra like weather here in Ohio. Finishing this intake is number 1 priority now. I need to man up and battle the cold and get cracking on it again.
Old Feb 8, 2015 | 03:43 AM
  #316
Fixxxercask
Making more progress. Got the 2nd pipe cut and most of the way welded. The 2nd pic: the test fitting of the TB. Flange and TB both fit. I am going to have to notch a tiny bit out of the hood framing for the hood to shut. Shouldn't be too much though because it almost shuts all the way now. Going out in the garage here in a bit to work on it some more.
Attached Thumbnails 87mm TB Project-optimized-round3.jpg   87mm TB Project-optimized-round4.jpg
Old Feb 8, 2015 | 09:16 AM
  #317
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Looking good!
Old Feb 8, 2015 | 09:40 AM
  #318
Fixxxercask
Thanks!
Getting there. Got the flange tached onto the pipe to test fit intake piping. I finally feel like there is light at the end of the tunnel. Also, ordering cams, springs and retainders on Friday.
Old Feb 8, 2015 | 10:48 AM
  #319
The_Assassin's Avatar
The_Assassin
Nice work man. What cams are you going with?
Old Feb 8, 2015 | 01:16 PM
  #320
Resmarted's Avatar
Resmarted
Thanks!
Be prepared to order a few buckets, and a feeler gauge.
