87mm TB Project
Old Feb 9, 2015 | 03:29 AM
  #321
Fixxxercask's Avatar
Fixxxercask
Going with JWT C2 cams.
Already have a feeler gauge. =)
Old Feb 14, 2015 | 05:15 AM
  #322
Fixxxercask
Ordered the cams, springs, shims and spring compressor tool today. That was a nice punch to the wallet!
So change of plans. I am going to install cams and the handful of other parts on the spare motor I have and swap that motor into the car in the coming weeks. Once new motor is in and ready to go, I will then take it to the dyno. I plan on tuning this motor with the OEM plenum/TB/intake and see what kind of power it makes. Then swap the new plenum/TB/intake on and tune it. That way I can see how much more power this thing adds or doesn't add. Same day, same dyno, yadda yadda yadda...
Old Feb 15, 2015 | 08:17 AM
  #323
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
^ Awesome! Keep us updated.
Old Feb 16, 2015 | 03:09 AM
  #324
mw9's Avatar
mw9
Damn, must be nice to have a spare motor laying around
Old Feb 16, 2015 | 05:05 AM
  #325
Conway_160's Avatar
Conway_160
It is a good thing unless it has a shattered a piston that F'd up your number 5 Cylinder walls and head....
Old Feb 16, 2015 | 10:47 AM
  #326
Fixxxercask
It is very nice having a spare motor.
Old Feb 16, 2015 | 10:51 AM
  #327
Classy's Avatar
Classy
Does it look like this?
Old Feb 16, 2015 | 03:49 PM
  #328
Fixxxercask
Haha...
Unfortunately no. Many years down the road perhaps. Or just an insane 8500 rpm revving VQ monster. For the class I want to run in, I will never need more than 330whp at my current weight. So who knows.
Old Feb 19, 2015 | 02:54 PM
  #329
Resmarted's Avatar
Resmarted
Haha...
Good luck with that LOL
Old Feb 19, 2015 | 03:10 PM
  #330
03threefiftyz's Avatar
03threefiftyz
He needs those cams to catch up with the freak show DE in a certain other TT3 car ....
Old Feb 20, 2015 | 11:31 AM
  #331
Fixxxercask
LOL indeed I do sir.
Old Feb 22, 2015 | 03:26 PM
  #332
Fixxxercask
Cleaned it up and painted it.
Been spending time looking over the FSM for all this work about to happen. Patiently waiting for all my parts to get here. Just because the timing chain and all that will be coming off, I think I should replace the tensioners and maybe the chains just to cover my a$$. I guess we'll see what it all looks like when its all apart.
Attached Thumbnails 87mm TB Project-optimized-img_20150221_161025425_hdr.jpg
Old Feb 23, 2015 | 04:23 PM
  #333
misterniceguy's Avatar
misterniceguy
Looks nice. Thanks for your work so far.
Old Mar 5, 2015 | 02:48 PM
  #334
Fixxxercask
Got all my parts. Got the motor tore down enough to do all the work needed. Got the new rod bolts, oil pump, Viton valve seals, JWT springs and shims all installed. Tomorrow I will be checking cold clearances on all the buckets. I've only checked one cylinder so far and they are all too tight actually. Looks I will be ordering some buckets along with new timing chain tensioners and guides for good measure. So after tomorrow, its order more parts to finish this thing then wait until they get here. Racing season is fast approaching. Got to get it all done.
Old Mar 6, 2015 | 11:29 AM
  #335
Fixxxercask
Some pics...
Attached Thumbnails 87mm TB Project-optimized-img_20150227_153745978.jpg   87mm TB Project-optimized-img_20150228_113621345.jpg   87mm TB Project-optimized-img_20150228_130242506.jpg   87mm TB Project-optimized-img_20150301_145948878.jpg   87mm TB Project-optimized-img_20150301_150008308.jpg
Old Mar 14, 2015 | 02:31 AM
  #336
Fixxxercask
Took the day off work yesterday and spent all day in the garage. Cams installed finally with the 22 new buckets I had to order to have correct valve lash. New motor is 90% done. Have to install accessories (power steering, alternator..etc) then she is ready to go in. Pulled the old motor yesterday and installed new Z1 solid motor mounts. Should be able to install new motor in the car today. If all goes well, hopefully dyno in a few weeks.
Old Mar 14, 2015 | 05:57 AM
  #337
Classy's Avatar
Classy
Nice! I was too lazy to assemble the heads when I built my motor, paid the machine shop to do it
Old Mar 15, 2015 | 05:57 AM
  #338
Fixxxercask
Motor is in!
Spent all day in the garage yesterday again. I have to put core support and rest of the front end of the car back together today and hopefully get it started soon. Then dyno time!
Old Mar 15, 2015 | 06:08 AM
  #339
Fixxxercask
Pic of mounts.
Old Mar 15, 2015 | 05:05 PM
  #340
Conway_160's Avatar
Conway_160
How hard was the motor install with the transmission allready in?
