Unofficial Enkei Wheels Thread
Old Jan 8, 2011 | 05:51 PM
  #601
exarmyguy's Avatar
exarmyguy
Originally Posted by rich2342
Fenders rolled?
Lol, unfortunately. Check out what happened... https://my350z.com/forum/exterior-an...ghtmare-2.html
Old Jan 25, 2011 | 06:28 PM
  #602
rich2342's Avatar
rich2342
Ouch, Damn sorry that happened.
Old Jan 29, 2011 | 03:00 PM
  #603
terrasmak's Avatar
18x9.5 +15 RPF1 over the 6 piston 14 inch Wilwood BBK. Fits just fine, just took me a while to take the pic. Sucks the pic is from my phone, but....
Old Jan 29, 2011 | 04:27 PM
  #604
05Z33's Avatar
05Z33
WOW!!! Those brakes fit tight in there. Looks good.
Old Jan 29, 2011 | 04:57 PM
  #605
terrasmak's Avatar
Not even close, search for some of the pics of those brake with last years 17 inch track setup over them.
Old Feb 15, 2011 | 11:56 AM
  #606
mpthree50's Avatar
mpthree50
Does anyone have the PF01's in black mounted successfully? Search around the forum and came up with nothing.
Old Feb 15, 2011 | 12:42 PM
  #607
217350z's Avatar
217350z
Originally Posted by Kal_El
I've been happy ever since I got these wheels.
NICE whats your sus set up ???
Old Feb 22, 2011 | 12:25 PM
  #608
TheSyn3rgist's Avatar
TheSyn3rgist
This is going to be a dumb question, but I'm wondering how the guys with 18x10.5s all around are making the front and rears look flush/even? I've got 265/35s and my front looks slammed and I can easily get 2 fingers between the tire and fender in the rear. Obviously, I could lower the rear, but it looks like my Z sits level right now... Also, for performance reasons, I thought it was better to have a slightly forward rake...
Old Feb 22, 2011 | 12:28 PM
  #609
rich2342's Avatar
rich2342
pics?
Old Feb 22, 2011 | 12:33 PM
  #610
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
With a square set up, expect to run spacers in the rear to have it look as flush as the front.
Old Feb 22, 2011 | 12:34 PM
  #611
TheSyn3rgist
This is on the stock wheels. I haven't purchased RPF1s yet because I don't want to go square if I can't get it to look even and perform well. I'll go 18x9.5/10.5 if that's what it takes, but I'd like to go square so I can rotate my tires correctly...
Old Feb 22, 2011 | 12:39 PM
  #612
AdvanZ33's Avatar
AdvanZ33
This is on the stock wheels. I haven't purchased RPF1s yet because I don't want to go square if I can't get it to look even and perform well. I'll go 18x9.5/10.5 if that's what it tales, but I'd like to go square so I can rotate my tires correctly...
If you are going square with the same size tires all around, you will have a larger fender/wheel gap in the rear no matter what. Of course you can lower it to close the gap but I think it depends on your goals. Are you taking it to the track?
Old Feb 22, 2011 | 10:29 PM
  #613
pizzato16's Avatar
pizzato16
anyone know if the SBC RPF1's can be repaired? Freakin sewer drain pulled my car into the curb, its pretty badly chipped now .
Old Feb 23, 2011 | 11:17 AM
  #614
TheSyn3rgist
It looks like BarefootRacer may have pulled it off...
Originally Posted by BarefootRacer
Only other decent pic i have at the moment.
And I will be using it for track and autox.
Old Feb 23, 2011 | 11:25 AM
  #615
AdvanZ33's Avatar
AdvanZ33
^^^ Yes sir. Pretty sure he had a 20mm spacer in the rear too.
Old Mar 9, 2011 | 11:06 AM
  #616
ppwpz33's Avatar
ppwpz33
He did.. I bought that setup from him. Good looking functional setup.
Old Mar 13, 2011 | 09:28 PM
  #617
LeMansZCa's Avatar
LeMansZCa
HI,
I've recently bought a set of RPF1 matt black , 18x9.5/10.5 +15 for track use on my suspension that has been lowered.
I am thinking to get 265x35 and 285x35 tires, Potenza Pole Position 04 or AD08.
I am trying to do this without rolling the fenders and no rub.
Let me know what you guys think of this setup and pref of the tires.
Thanks!
Old Mar 13, 2011 | 11:49 PM
  #618
terrasmak's Avatar
Originally Posted by LeMansZCa
HI,
Thanks!
Probably work, front will be fine with around -2 camber, the rear may need a roll.
Old Mar 14, 2011 | 08:56 AM
  #619
r_seng's Avatar
r_seng
HI,
Thanks!
Rear will need to be rolled.
Old Mar 14, 2011 | 10:11 AM
  #620
rich2342's Avatar
rich2342
Reserving my space. Rims on order.. tires next..
Did you guys know they discontinued the Gunmetal RPF1's.. Very p.o.'d about that. settled for silver.
