FAQ: Official wheel "SPACER" thread!
Old Feb 27, 2012 | 09:17 AM
  #701
Lemz007's Avatar
Lemz007
Default spacers need help
HI, I have an 06 350z and just bought a new set of rims 18 x 8.5 with an offset of 32. I was wondering for spacers, how many mm would you guys put with an offset like this???
Thanks
Mat
Old Feb 27, 2012 | 09:20 AM
  #702
UrineDanger's Avatar
UrineDanger
Everything you need:
https://my350z.com/forum/wheels-and-...er-thread.html
For future reference search, or you will get bashed.
Old Feb 27, 2012 | 09:23 AM
  #703
Lemz007's Avatar
Lemz007
alright thx and new to this..
Old Feb 27, 2012 | 09:25 AM
  #704
ZS14RR's Avatar
ZS14RR
Why those wheels? And pics
Old Feb 27, 2012 | 09:38 AM
  #705
sportbiketed's Avatar
sportbiketed
Why did you post a second thread?
Old Feb 27, 2012 | 09:50 AM
  #706
terrasmak's Avatar
I would just start with new wheels.
Old Feb 27, 2012 | 09:59 AM
  #707
IamStrube's Avatar
IamStrube
I am looking to get these rims on my 2005 Grand Touring Roadster. The rim sizes are 19x8.5 ET20 5x114.3 67.1 front and 19x9.5 ET20 5x114.3 67.1 rear. They are saying that they will be flush. I have no idea what offsets are and don't care to learn. I am just wondering if I will need to get some spacers when these arrive or not.
Old Feb 27, 2012 | 10:08 AM
  #708
Swiffer's Avatar
Swiffer
...or in his case, a new car.
Old Feb 27, 2012 | 11:16 AM
  #709
UrineDanger
No problem, and welcome, just giving you a heads up.
Old Feb 27, 2012 | 11:34 AM
  #710
VMRWheels's Avatar
VMRWheels
Vendor - Former Vendor
I would measure the clearance you have between the tire and fenders.
Then purchase the appropriate spacers.
Old Feb 27, 2012 | 11:45 AM
  #711
Modrummer's Avatar
Modrummer
Why multiple threads for same question?
Old Feb 27, 2012 | 01:12 PM
  #712
[QUOTE=VMRWheels;9628494]I would measure the clearance you have between the tire and fenders.
It seems that this method is common sense. I fail to understand What size spacers should I get? threads.
Old Feb 27, 2012 | 02:36 PM
  #713
350ZZJoe's Avatar
350ZZJoe
Well seeing as the back will be almost identical to stock (only +1mm on the offset)
I can tell you I ran a 25mm + 3mm spacer on my 06 with stock rims, stock suspension with a 245/45/18 Nitto Invo and it worked fine and was pretty flush.
But that could maybe just be a starting point for you. I'm not sure why you would buy wheels with stock like offsets, they suck.
Old Feb 27, 2012 | 07:37 PM
  #714
ronn1's Avatar
ronn1
Watch out there..you're in flame suit territory
Ok..will you *NEED* spacers? NO.
You will, however, need a HUB RING to fit your 66.1 hub...make sure they can provide that or you'll have to order a 67.1/66.1 hub ring set.
BTW..rethink the *learning thing* because you'll be lost as to what effect such an offset change will have on the final positioning of your wheels (ie, how far out they will sit). I could tell ya that or you could go here:
You will need to know your stock offsets..I'll give to ya...+30F and +33R
http://www.1010tires.com/wheeloffsetcalculator.asp
Old Mar 7, 2012 | 11:36 AM
  #715
twinturbo666's Avatar
twinturbo666
2006 350z with stock wheels 1.5inch drop w/ 25+ spacers all around, does anyone know if 265/35/18s will work on rear with out rubbing?!?
Old Mar 7, 2012 | 11:43 AM
  #716
Brogan07's Avatar
Brogan07
265's on an 8.5 inch wheel?
Old Mar 7, 2012 | 12:36 PM
  #717
twinturbo666
I'll take that as a smart a$$ no?
Old Mar 7, 2012 | 12:58 PM
  #718
Brogan07's Avatar
Brogan07
No, I'm not saying it wouldn't work and I didn't mean to sound sarcastic, sorry if it did. I'm sure you know the stock rears take 245/45's. Just curious as to why you'd want to go bigger. Far as I know, most go smaller than stock tires to get a stretched look.
Old Mar 7, 2012 | 01:16 PM
  #719
twinturbo666
Oh my bad! hate the stretched look I like wide tires on rear. Just wondering if the tire would rub with my 1.5 drop and +25 spacer on the rear? wondering if anyone has this setup on there stock 18's v2
Old Mar 7, 2012 | 01:36 PM
  #720
terrasmak's Avatar
Just keep stock sized tires on it till you can afford some wheels.
