FAQ: Official wheel "SPACER" thread!
Old Mar 7, 2012 | 02:38 PM
  #721
twinturbo666's Avatar
twinturbo666
Just keep stock sized tires on it till you can afford some wheels.
Selling my volks. Wanna go back to stock. Just a wider tire than weak 245's. You should take a reading comprehension class...
Old Mar 7, 2012 | 04:39 PM
  #722
ronn1's Avatar
ronn1
They should fit, but will be PINCHED a bit. They are approved down to 9".
The real problem is that the DIAMETER is way out of spec for VDC. They are 1/2" shorter than the stock fronts! You would need a shorter front tire to meet VDC specs. I agree with other poster...why invest $$ on these tires for STOCK rims? yeah..they're wider, but then you have this stuff I pointed out here to deal with.
Old Mar 7, 2012 | 07:32 PM
  #723
twinturbo666
Ahh good point. I was thinking 245/40 front n 265/35 . Just love the wide *** rear end with fat tires looks mean
Old Mar 9, 2012 | 11:00 PM
  #724
Bumble Z's Avatar
Bumble Z
would a 20mm spacer on the front and a 25mm on the rear on a nismo stock suspension work for the nismo stock wheels with a 245f and a 265r or will i have rubbing issues with the fenders?
Old Mar 9, 2012 | 11:47 PM
  #725
hellsoldiers08's Avatar
hellsoldiers08
^i think that question has already been answered with in the last ten post.
Old Mar 10, 2012 | 12:13 AM
  #726
KingBaby's Avatar
KingBaby
Hardest Setting
[QUOTE=davidv;9628811]
Originally Posted by VMRWheels
I would measure the clearance you have between the tire and fenders.
It seems that this method is common sense. I fail to understand What size spacers should I get? threads.
Old Mar 10, 2012 | 08:31 AM
  #727
Bumble Z's Avatar
Bumble Z
i havent been in the mood to do searching and going through the whole thread
Old Mar 10, 2012 | 10:55 AM
  #728
Z_enthusiast's Avatar
Z_enthusiast
^ think they are in the mood to give you info that's been answers countless times just because your lazy? Lol good luck with that attitude bro.
Old Mar 11, 2012 | 01:27 AM
  #729
FlushedOut's Avatar
FlushedOut
ok so ive searched every where and i haven't gotten a clear answer to my problem atm. I bought a set of te37s that are 5x130 from a member from another forum that included a conversion adapter/spacer to make it fit on our 5x114.3 pattern. when i installed the spacers, the hub fits perfectly inside but when i torqued my factory lugs up to bolt up the spacer to my car, the spacer in the end has a bit of play in it in which i can wiggle the spacer back and forth. I test drove my car to see if that would cause a problem and when i drive and brake, i get noises as if my rear wheels are not spinning straight and when i checked, i found rub marks on my struts. How do i stop the spacers from moving so my car will stop making noises while i drive?
Old Mar 11, 2012 | 05:02 AM
  #730
MantisMan's Avatar
MantisMan
^ Maybe the stock lug nuts (closed end) are bottoming out....not allowing the spacer to tighten up. Try some open end lugs and see if that cures the problem. Do NOT drive the car unless the spacers/wheels are fully torqued to spec and have zero movement.
Somewhat similar situation for me when installing my Z1 Motorsports spacers yesterday. The spacers apparently have longer studs because if I installed the spacer and bolted it up with the supplied nuts when I put on the wheel my stock lug nuts bottom out on the studs.
I ended up using the stock lugs to bolt up the spacers and the supplied spacer nuts (open ended) to bolt up the wheels. Don't really like doing this so I'll be purchasing some extended length lug nuts very soon. I'm assuming this may be a somewhat common problem so just giving a FYI to anybody that may have this issue.
Car looks great though with the 25/30 setup......I"ll get some pics posted up.
Old Mar 12, 2012 | 03:16 AM
  #731
CircleHeartX's Avatar
CircleHeartX
i want spacers then ill be flush!
Old Mar 12, 2012 | 10:04 AM
  #732
Bumble Z's Avatar
Bumble Z
not trying to have a bad additude or just being straight up lazy or a douche but by the time i get home from work which is around 130 am im drained i work in a prison its get exhausting and to search an entire long thread such as this one i doubt my eyes would stay open for long just need quick answers to let my friend at the shop whose getting them for me know
Old Mar 13, 2012 | 01:21 AM
  #733
FlushedOut's Avatar
FlushedOut
definitely gonna try the open ended nuts tomorrow, i had to mount spare tires on my car for the time being until i get this problem fixed T.T
Old Mar 13, 2012 | 09:07 PM
  #734
paulmess7's Avatar
paulmess7
I don't think this has been covered in this thread yet, but lets say I'm driving down the road and all of a sudden I see my tire roll past me because my spacer failed. Moments later my car spins into a tree and is a total loss.
Is the insurance inspector going to deny my claim because of the spacer?
That's my biggest worry right now.
Did anybody here with bolt on spacers upgrade their oem studs to a higher quality stud that can better withstand the added strain?
My new Konigs are +30 and my friends are telling me my car looks like a "sunken battleship", whatever that means.
Old Mar 13, 2012 | 11:23 PM
  #735
-Trav-'s Avatar
-Trav-
Id try and play it off as an OEM part or something came with the car that I had no knowledge of. If you add this part to your policy then they might cover it if something where to happen. Definitely call them and ask.
Old Mar 14, 2012 | 01:25 AM
  #736
KingBaby's Avatar
KingBaby
Hardest Setting
If you buy a quality spacer your konigs will fail first...and haven't you learned don't do anything to impress your friends...
Old Mar 14, 2012 | 02:41 AM
  #737
terrasmak's Avatar
No they will not deny your claim
Slip on spacers with ARP studs, strong as hell, screw the bolt on crap. Slip on spacers are available up to 20mm.
Old Mar 14, 2012 | 05:29 AM
  #738
xman2yman's Avatar
xman2yman
Hello everyone, I read the first 5 pages and tried to search for G35 rays on this thread. I am wondering what size spacers I can run with those wheels on. They have the OEM tire size. I am also lowered about 1.5" on coil overs. I was thinking 20-25 but pretty sure that will mean I'm rolling or cutting. I would not care normally but one of my rear fenders has a small build up of rust and I worry that rolling will make it worse. I can provide pics if needed.
Old Mar 14, 2012 | 07:06 AM
  #739
Z_enthusiast
Just measure the distance from your tire to the inner most edge of your quarter panel, bam! There's your spacer size.
Old Mar 15, 2012 | 08:14 AM
  #740
sry110's Avatar
sry110
Anyone buy spacers from this outfit before?
http://www.ezaccessory.com/Billet_Hu...p/5114-10n.htm
About 50% of the price of the same size/type spacer from Eibach. I know "you get what you pay for", but given the material type and assuming they are machined with parallel faces (should be since advertised as CNC), it seems like there isn't much that could be messed up here.
