FAQ: Official wheel "SPACER" thread!
Old Sep 27, 2012 | 10:52 AM
  #981
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Yes it replaces the stock studs. Look into the Ichiba V1 spacer kits and buy some open end lug nuts.
Old Sep 27, 2012 | 11:00 AM
  #982
Daytondakid13's Avatar
Daytondakid13
Sweet that's what I'll do then thanks!
Old Sep 27, 2012 | 11:31 AM
  #983
VMRWheels's Avatar
VMRWheels
Vendor - Former Vendor
Originally Posted by AdvanZ33
Spacers w/ extended studs.
Old Sep 27, 2012 | 11:37 AM
  #984
VMRWheels's Avatar
VMRWheels
Spacers will definitely help, and there are vendors on this site that sell them.
For deciding what size, simply measure.
Old Sep 27, 2012 | 06:11 PM
  #985
HaroldStewar's Avatar
HaroldStewar
The best option is to get new wheels with an aggressive off set but if you're on a budget like me
Old Oct 10, 2012 | 11:59 AM
  #986
Reez's Avatar
Reez
To all the Z-owners posting in this thread
Only came across it now, after I posted my query,,,so, my bad...
This thread has certainly put a smile on my dial...Thanx for the valuable info guys...Keep up the good work Like they say..." Burn rubber & not your soul"..
Old Oct 12, 2012 | 02:08 AM
  #987
Moussa93's Avatar
Moussa93
Hey people,
I'm new around...
Trying to get some spacers for my first mod .. Some 25/30 with OEM Wheels PlastiDiped in Black...
So I have a question... I know that this is a noob question but... Which one should I go for?
Old Oct 12, 2012 | 10:53 AM
  #988
VMRWheels's Avatar
VMRWheels
Which brand or which size?
Old Oct 12, 2012 | 11:06 AM
  #989
Bmurray350z's Avatar
Bmurray350z
This might have already been answered but what size spacer (w/ built in lugs) is needed for the wheel to clear the stock studs? (If the wheel does not have gaps in between each stud hole)
Edit- nvm found the answer.. 25mm
Old Oct 12, 2012 | 08:07 PM
  #990
-Trav-'s Avatar
-Trav-
Originally Posted by Moussa93
Hey people,
I'm new around...
Id say it depends on whether your fenders are rolled and how low you are.
Old Oct 13, 2012 | 07:26 PM
  #991
pss350z's Avatar
pss350z
Default Need help finding good quality small wheel spacer
I just picked up a set of Volks off another member and turns out that the 9.5 +12 J will not clear my brembos by a C#$T hair. Just barely grabs the damn caliper. I'm looking for the smallest wheel spacer possible that isn't absolute junk. The smallest I've seen is 2.5 mm at Z1 motorsports, are there smaller than this or should I just go with what I found?
Any suggestions?
link to 2.5 mm....
http://www.z1motorsports.com/350_g35...oducts_id=3118
What a kick in the nutz
Old Oct 14, 2012 | 02:48 AM
  #992
JCITY's Avatar
JCITY
Good God man,2.5mm,thats small!Any smaller it will be in the tin foil range and crack.
Basically you need to shim the wheels a bit to get clearance.These thin spacers are
available at all the auto chain stores.
Go with the 2.5.
Old Oct 14, 2012 | 04:36 AM
  #993
AdvanZ33's Avatar
AdvanZ33
I ran these at one point. No problems:
http://www.ebay.com/itm/JAPAN-KICS-3...8bbedf&vxp=mtr
Old Oct 14, 2012 | 06:17 AM
  #994
mikes10's Avatar
mikes10
- just get the one from z1 motorsports -
Old Oct 14, 2012 | 07:29 AM
  #995
terrasmak's Avatar
That is some low quality high priced GayDM crap right there.
The Z1 spacers are from billet, not cheap cast.
Old Oct 14, 2012 | 08:53 AM
  #996
pss350z's Avatar
pss350z
thanks for the suggestion,but i have to agree that they look very snappable/crackable/sh!tty.
A buddy had .1875" spacers he gave me, just barely grabs the hubcentric ring due to the huge chamfer on it (chamfer on the hubcentric ring) I think i can get away with 2.5 mm. I'm a machinist so I may just make my own if I can get my hands on some higher grade aluminium. Sucks to have to run spacers with +12 offset wheels, already pushing the limits with fender clearance, now I'll definately have to run more camber.
A before and quick pic after....
9.5/10.5 +15 RPF1s
9.5/10.5 +12 J Te37s
I also need to change up the rear tire, for some reason the original owner ran 275/30-19, looks like a rubber band. Also, black lugs are in order.
Damn, I'm looking at the before picture and thinking WHY?
Old Oct 14, 2012 | 08:58 AM
  #997
pss350z's Avatar
pss350z
My crappy pic doesn't do these wheels justice. The wife even says there's no comparison. But If the RPF1s were darker I'd probably have stuck with them as they wouldn't look as small as they do with the silver to black contrast you see here. I've seen some beauties, i believe sparco's Z is rockin the black RPF1s and looks amazing.
Will have to contribute with some nicer pics in the Magnetic and Volk threads.
Old Oct 14, 2012 | 09:25 AM
  #998
terrasmak's Avatar
Silver looked way better on your dark car, the new wheels just blend in a look bla.
Old Oct 14, 2012 | 12:22 PM
  #999
joshie3.5.0.z's Avatar
joshie3.5.0.z
so i need someone to clear it up for me , is it really unsafe to use spacers? i heard so many things
Old Oct 14, 2012 | 12:52 PM
  #1000
-Trav-'s Avatar
-Trav-
If youre really worried about safety go with a slip on spacer with extended studs. You dont have to worry about stripped nuts, easy install (after you press the studs into the hub) and easier to re-torque if needed.
Less links in the chain means less chance for errors and/or failure.
