FAQ: Official wheel "SPACER" thread!
Old Dec 7, 2012 | 01:26 PM
  #1061
User 42426's Avatar
User 42426
Did you ever get the answer to your spacers/alignment issue? Im in this situation right now...
Old Dec 8, 2012 | 12:29 PM
  #1062
TheWoods's Avatar
TheWoods
Question 38mm+ Spacers?
Howdy folks,
So to start off, yes. I did read the ENTIRE Spacer Sticky Thread. However it didn't answer my concerns.
How much is too much? I wanna throw on some 1.5" spacers (38mm)
Can you put on the same size spacers for front or back? or does it have to be staggered?
Thanks!
Edit: Not sure if this matters, but the fender is rolled AND I have 1.5 degrees of negative camber on front and back.
Old Dec 8, 2012 | 01:39 PM
  #1063
JCITY's Avatar
JCITY
Those are some large spacers!
I'm curious,what kind of wheels&offsets are you running?
Old Dec 8, 2012 | 08:04 PM
  #1064
SlowNFurious's Avatar
SlowNFurious
Yes, you can run 1.5" spacers no problem. Plenty of people run 1.5" and wider spacers on Jeeps. You can run the same spacers front and back as wheel.
Old Dec 8, 2012 | 08:08 PM
  #1065
Mattysals's Avatar
Mattysals
I believe my back are 25mm and that puts me flush on stock wheels
Old Dec 9, 2012 | 01:12 AM
  #1066
TheWoods's Avatar
TheWoods
Not sure, all I know is its all stock, besides the camber. I have some Tein springs, not sure if that helps.
Old Dec 9, 2012 | 02:16 AM
  #1067
-Trav-'s Avatar
-Trav-
Im guessing you have stock wheels...No you do not have to run the same size, nor do you have to run staggered. Up to you.
Old Dec 9, 2012 | 02:24 AM
  #1068
KingBaby's Avatar
KingBaby
Hardest Setting
You need to re re read that thread!
Old Dec 9, 2012 | 06:15 AM
  #1069
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Measure from the top of the tire to the edge of the fender. Buy appropriate sizes spacers. Yes it can be the same size on all 4 corners or staggered.
Old Dec 9, 2012 | 10:33 AM
  #1070
tcode's Avatar
tcode
What's the most common spacers combo for OEM 18" Rays (8" fronts and 8.5" rears)?
Old Dec 9, 2012 | 10:51 AM
  #1071
TheWoods's Avatar
TheWoods
I have read the darn thing 3 times now.
Old Dec 9, 2012 | 10:53 AM
  #1072
TheWoods's Avatar
TheWoods
So far I've seen 25mm - 30mm. 25 puts you almost flush and 30 puts you a little past flush.
Old Dec 9, 2012 | 11:02 AM
  #1073
tcode's Avatar
tcode
Thank You!
Old Dec 13, 2012 | 01:03 PM
  #1074
TheWoods's Avatar
TheWoods
Ok, so what happens if you put spacers with oem wheel? The oem wheels are 66.1 and the hub is 66.1 but i cant find any those sizes together. Am I SOL?
Old Dec 13, 2012 | 02:45 PM
  #1075
terrasmak's Avatar
Just install the spacer , simple and easy
Old Dec 13, 2012 | 03:54 PM
  #1076
TheWoods's Avatar
TheWoods
So i dont need centric rings? What if its off balance because of no ring. Is that ok? My tire lug wont break off or damage the suspention because of the vibration?
Old Dec 13, 2012 | 03:59 PM
  #1077
TheWoods's Avatar
TheWoods
Default Spacer issue
Hey guys,
I just installed 1.5 inch spacers. They look sick, I love them. However, no one makes centric rings for that size space. I have vibration after install, same type as unbalanced tires. My question is, do I NEED rings? Will anything get damaged if I dont us them?
Old Dec 13, 2012 | 04:12 PM
  #1078
terrasmak's Avatar
No hub ring will be needed with a hub centric spacer like the ones you buy from http://www.z1motorsports.com/350_g35...oducts_id=4215 you will only need hub rings with aftermarket wheels.
Old Dec 13, 2012 | 04:13 PM
  #1079
terrasmak's Avatar
What brand spacers, are they hub centric, what wheels are you using.
Old Dec 13, 2012 | 04:27 PM
  #1080
ttknf's Avatar
ttknf
The good quality spacers have hubcentric rings that can be purchased in different sizes for different wheels. A good example is Project Kics.
