Official Aggressive Wheels & Fat Tires Thread
Old Jun 2, 2013 | 09:25 AM
  #4741
KingBaby's Avatar
KingBaby
Hardest Setting
Old Jun 2, 2013 | 09:27 AM
  #4742
jdmlove1's Avatar
jdmlove1
when i remove the spacer, everything ok. but the car look awkward coz in front there is also a 15mm spacer.
Old Jun 2, 2013 | 09:46 AM
  #4743
KingBaby's Avatar
KingBaby
Hardest Setting
Remove the fender
Old Jun 2, 2013 | 10:19 AM
  #4744
terrasmak's Avatar
You do know that spacers are made in different sizes, maybe order a 10mm to keep it from rubbing.
So how well are your fenders rolled?
Old Jun 2, 2013 | 02:56 PM
  #4745
Lubo's Avatar
Lubo
Can I play? 295/35 17 all around on 17x10 ET18
Soon to be replaced by 295/30/18 with 17x10.5 ET15 due to lack of tire choices in 17s.
Old Jun 2, 2013 | 03:31 PM
  #4746
Bmurray350z's Avatar
Bmurray350z
that actually looks great. what are the weight of the 17" RPF1s?
Old Jun 2, 2013 | 03:33 PM
  #4747
2004Black350z's Avatar
2004Black350z
Exhaust Whore
meaty yes however i do not like. Kudos though
Old Jun 2, 2013 | 03:35 PM
  #4748
kno's Avatar
kno
Claybar and rub compound that scrape lubo
Old Jun 2, 2013 | 03:38 PM
  #4749
2004Black350z
Exhaust Whore
Originally Posted by 2th pwr
bye kids... I'm off to work!
boner!!!!!
Old Jun 2, 2013 | 03:51 PM
  #4750
Lubo's Avatar
Lubo
Those are old pictures. Car is pretty much Auto-X/HPDE only. I keep it registered and insured just for ease of driving to events. That scrape got taken out last year.
Thanks they are around 17 lbs.
None of the mods done to this car were for looks. too bad I don't have any pictures with stock suspension as with the shorter tire the wheel gap on rear panel was equivalent of most SUVs
Old Jun 2, 2013 | 04:01 PM
  #4751
KingBaby's Avatar
KingBaby
Hardest Setting
post new pics then
Old Jun 2, 2013 | 09:27 PM
  #4752
jdmlove1's Avatar
jdmlove1
kept a 5mm spacers and no rubbing. so i guess changing the tire to 285 with a 10mm spacer will be perfect.
i didnt roll the fenders.
Old Jun 2, 2013 | 10:17 PM
  #4753
terrasmak's Avatar
Roll the fenders and be done with it.
Old Jun 3, 2013 | 03:43 AM
  #4754
taryon's Avatar
taryon
Just a question:
Would 305/30/19 fit in the rear?
Specs are 19x10.5 +12, no camber arms yet, lowered on HKS Hipermax LS+, fenders rolled.
Did a bit of research and found it may need -4.5 degrees of camber to fit, butnfortunately my country doesn't allow for that much camber so just wanting to find out
Old Jun 3, 2013 | 06:03 AM
  #4755
kno's Avatar
kno
Sto k camber is around 1.25 so youll rub pretty bad without camber adjustment.
Old Jun 3, 2013 | 09:02 AM
  #4756
scotts300's Avatar
scotts300
Those tires won't fit.
Originally Posted by taryon
Just a question:
+22 is ok, +12 will be very tight. If you aren't lowered, it'll be fine.
Old Jun 3, 2013 | 09:57 AM
  #4757
Lubo's Avatar
Lubo
Meant to say 18x10.5 et15. I've been running 17s for the longest time and it is my first time in like 5 years that I am buying 18s so it will take some time to adjust
Old Jun 3, 2013 | 01:28 PM
  #4758
scotts300's Avatar
scotts300
295/30/18 will be hard to come by sans Hoosier. 285/35/18 RS3 is perfect, IMO.
Old Jun 3, 2013 | 02:40 PM
  #4759
Lubo's Avatar
Lubo
Stepping up to R-comp after 5 years. I want something that I can still drive on to events. Will be either Michelin Pilot cup or Toyo 888
Old Jun 3, 2013 | 04:25 PM
  #4760
STL 350Z's Avatar
STL 350Z
I have decided on Hankook V12's in 305/30-19 for my Concept One CSL5.5's (19x10.5 +20) rear and 275/30 for the fronts 19x9 +15. Should look pretty damn good... got a friend that rolls fenders lined up to roll the rears as soon as I can make it down to his shop.
Just waiting on payday
