ground in trunk/spare well
Old Aug 12, 2009 | 12:26 PM
kaminariZ's Avatar
kaminariZ
Default ground in trunk/spare well
Hi guys, i can't seem to find a suitable ground for my amplifier (4guage) in the trunk/wheel well. Does anyone have any recommendations. I tried some of the bolts there and scraped the paint yet the connectivity is still pretty bad. Any advice would help. I searched and i don't get relavent posts.
Old Aug 12, 2009 | 03:28 PM
BlueZ33's Avatar
BlueZ33
there should already be a ground back there if im not mistaken, but i just used one of the pre existing holes with threads and used a screw after i sanded down to the bare metal and it worked just fine
Old Aug 12, 2009 | 03:33 PM
NttnbutaZthang's Avatar
NttnbutaZthang
yea right where the carpet meets the back of the trunk area behind the seats...lift the carpet up and there should be a bolt there a 10mm i believe...thats where im grounded 4awg as well
Old Aug 12, 2009 | 07:56 PM
kaminariZ's Avatar
kaminariZ
hey guys, another thing. so i'm using my Rockford Fosgate p5002 2 channel amplifier, except i'm only using one of the channels to power my single 10 inch woofer, at 2 ohms 250watts rms. I have a 4ohm DVC infinity subwoofer, which i wired properly for 2ohms at 1 channel. Only problem is, that when the gain is at under 50%, i get no pounding at all. I have to turn the gain past 50% to make it loud, which is what i don't understand. the frequency is set to 70-80 hertz, and the head unit has the subwoofer signal on full. any ideas?
Old Aug 13, 2009 | 07:42 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
for every intsall i do, i make the ground cable as sort as possible, to a solid part of the floor, scrape away the paint and secure it as secure as possible.
what kind of HU are you running?
Old Aug 14, 2009 | 09:14 AM
Subdermal's Avatar
Subdermal
i used the bolt that goes through the child seat hook. have had no problems with it =)
Old Aug 15, 2009 | 06:09 PM
cbr900son's Avatar
cbr900son
This is where i grounded mine.
Old Aug 16, 2009 | 07:07 AM
doug's Avatar
doug
I grounded mine to the baby seat latch.. sanded it down and put the ring terminal in the baby seat bolt .. works great
416blueZ
Jun 11, 2024 10:56 AM
m_0g
Jun 3, 2021 10:05 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
OdesiTT
Sep 30, 2015 10:47 AM
cashmoney03
Sep 27, 2015 05:24 PM
