My $100 like OEM fit NAVIGATION setup
Old Oct 27, 2009 | 11:11 AM
  #321
06blueZ's Avatar
06blueZ
BTW, the errors are inevitable. Keep in mind that with each error, your error log text file gets bigger. Most of us should have the 2 GB memory card with ample amount of free space left (if poi, map, lang, etc were erased). However, as it does fill up the total capacity in increments, you will want to delete these files every once in a while. It's titled "crash" or something to that effect.
any idea what happens when the card gets full from the crash folder? I think I had about 1 gig of space left on my card, but I have no plans of ever removing it, and hope that when/if the crash folder gets full it doesn't cause any issues...
Old Oct 27, 2009 | 11:34 AM
  #322
obrien714's Avatar
obrien714
Default Awsome info from 3hree5ive0ero
that error is no worries, i did just touch the screen and it cleared off. Hopefully that file never gets full.
I didnt find the one cigarette lighter the one guy posted up, this one
http://www.dcpwr.com/shop/index.php?...products_id=22
pep boys and kragan have one but it has a square mounting unit built into it... ill probably get that one and just dremel it off.
my last question before i get to the install. so i tap into the passenger side lighter wire, heres my thinking,,,
1. use the lighter power cable it came with and get the female ciggarette adapter and splice that into the wire? if i do this will i need a fuse?
2. cut the ciggarette plug off and just splce the 2 wires together? if i do this will i need an inline fuse? and how do i put the fuse in...
if i get those answers im golden,,,
thanks again for the help guys...
Pat
Old Oct 27, 2009 | 01:02 PM
  #323
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Most likely, you'll get a different error saying that you've reached full capacity for the SD card. As I mentioned before, it's only a txt file so it'll take a long time to reach that point. However, I figured I'd give everybody a heads up just in case somebody does come across a new error. BTW, I think if you delete your crash log, it deletes the parameters you set in your GPS settings. I'm not sure but that's what I think it did back when I was trying to figure things out.
BTW, this is one of the reasons why I wanted to be able to access the SD card. I never found a cheap solution to this, but if I ever come across anything, I'll let you guys know in this thread.
Pat
1. This is possible, but you're just doing extra work. You'd have to buy that female adapter, tap the existing cig jack for power, then connect the GPS power wire/cig plug into the new female adapter. You shouldn't need any additional fuses, since the cig jack should already have a fuse (OEM) and since the cig plug also has a fuse.
2. You can cut the cig plug off and physically hardwire/tap for power/ground. I'd think you'd be ok without an inline fuse, as long as you know the wire you're tapping for power already has a fuse (cig jack should have one). However, it wouldn't hurt to spend a couple of bucks on another fuse and an inline fuse holder combo. This also saves precious space behind the center console/dash.
I recommend going with what I posted in #2 and use these so you don't have to strip/cut/crimp/etc:
http://images.google.com/images?hl=e...=&aqi=&start=0 (quick splice)
http://images.google.com/images?hl=e...ed=0CCwQsAQwBg (inline fuse)
Old Oct 27, 2009 | 02:41 PM
  #324
obrien714's Avatar
obrien714
Default thx again
you are the man.. i will update the pics next week.. ill probably do it next tues.....
thx again
pat
Old Oct 28, 2009 | 01:47 PM
  #325
burner's Avatar
burner
Originally Posted by SA Z-boi
how accurate is this navi, has anyone road trip tested it.
Burner I thought you had that garmin navi
I have tested it on a road trip from Austin to Dallas. Works really good. I did have the Garmin setup, but got bored with it and decided to give this a try. Each system has its pros and cons, but overall I think I like the OCN8 software better, mostly because of the GUI.
Originally Posted by quakerroatmeal
Burner I'm not sure what piece you're talking about. Is there anyway you can provide a picture? You are talking about behind the 3 gauges on top?
You have to remove the center console (with the 3 gauge pod) then remove the panel that is to the left of it, behind the tach/speedo. It is attached to the vent, it can be a b!tch to get off. Just route the wire through the crevices in the dash. I will take some pics either tonight or tomorrow and post them, if I have time.
The system only writes the .txt file (which is only a few kb) if you exit the nav program. If you shut your car off (assuming thats how its hooked up) with the nav still on, it will be fine, and will not write the file to the card. Theoretically, if you manually turned it off and it wrote the file on there, and you have 1GB free, it would take approx. 250,000 cycles (assuming 4kb per) to fill the card up. I'm pretty sure your starter on your car would go out first!
Old Oct 28, 2009 | 01:51 PM
  #326
burner's Avatar
burner
Saw this and had to comment....Do not rely on the fuse that is built in for the cig adapter. It is a 15A (I believe) and will fry the Plenio before it fries the fuse. I have a 3A fuse hooked up to mine (you want to use the lowest amp fuse you can just as a precautionary measure). If you do hook it up to the cig adapter, just throw an inline fuse rated no higher than 5A and you should be good.
Old Oct 28, 2009 | 05:24 PM
  #327
obrien714's Avatar
obrien714
Default thx for the info
cheers for all the great help in this thread..
Old Oct 28, 2009 | 05:44 PM
  #328
3hree5ive0ero
Retired Admin
I stand corrected - I forgot that the ratings were different between the two (cig jack fuse and the gps module's fuse). Thanks for catching that.
With that said, I still recommend going with method #2 in my previous post (just with the correct fuse).
Old Nov 1, 2009 | 02:33 PM
  #329
quakerroatmeal's Avatar
quakerroatmeal
Burner you ever get that picture? I'm going to relocate mines off my dash as soon as I see a picture of the location.
Old Nov 6, 2009 | 03:30 PM
  #330
Khanvict's Avatar
Khanvict
second time now and im gettin language load errors . i reloaded the software and it works fine and after a month it came up again.. any ideas why?? (i only have 1 or 2 languages saved)
Old Nov 6, 2009 | 10:40 PM
  #331
nismo_nate's Avatar
nismo_nate
hey guys..
i bought the plenio awhile back and it worked fine using the software that came with it.. i thought, if i keep it simple that i won't run into any issues. which worked fine for awhile...
so tonight, i tried to powering making sure it works right.. i will be going tomorrow for my H1N1 shot and planned on using the plenio for directions.. it wouldn't grab the damn gps signal! i thought if i let it sit awhile that it would catch.. it didn't.
so can someone post a the link for the software that you guys are running on this thread. it won't get rid of the other features that the plenio came with right? like movies/photos/etc.
thanks in advance
Old Nov 7, 2009 | 07:59 AM
  #332
3hree5ive0ero
Retired Admin
There is no link where you can just simply download the required software from. I have been shipping customized DVDs out to those who needed it and I believe o2sys has been as well.
Old Nov 8, 2009 | 12:34 AM
  #333
quakerroatmeal
Nismonate I can send it to you over aim if you'd like. Hit me up whenever.
Old Nov 8, 2009 | 01:33 AM
  #334
solidsnake's Avatar
solidsnake
Update on where to buy the screen?
Old Nov 8, 2009 | 12:20 PM
  #335
sssmasss's Avatar
sssmasss
guys any update on where to buy it? ebay doesnt have it anymore... there is a guy who is selling his but... it says... sometimes it power up sometimes it doesnt... i dont want to touch something like that...
and how do u remove the cubby? anyone has pictures of them removing the cubby.. i meant installation from start to end? thanks
Old Nov 8, 2009 | 02:20 PM
  #336
3hree5ive0ero
Retired Admin
^^ Refer to the below link:
http://liljerk.morpheus.net/350Z/dash_removal/
Old Nov 8, 2009 | 03:04 PM
  #337
sssmasss's Avatar
sssmasss
thank you.. is it the same for all model? i have an 06 roadster touring
Old Nov 8, 2009 | 08:05 PM
  #338
3hree5ive0ero
Retired Admin
I'm sure the major things are identical. A couple of screws may be slightly different but it at least gives you an idea.
Old Nov 9, 2009 | 10:34 AM
  #339
sssmasss's Avatar
sssmasss
actually.. it is not the same.. my box where u were suppose to place the plenio is not that big.. it is not 7 inches.. weird.. or maybe i need to remove the
"wallet box" .. .. and actually.. it is not the same... tried but cant find the screw on top... let me took again.. thank you tho
Old Nov 9, 2009 | 12:01 PM
  #340
3hree5ive0ero
Retired Admin
I know there are differences with the dimensions of certain parts but the process of taking off major components (plastic pieces) should be the same. Even if everything is different, the idea behind it all should be the same. You still have to take off the shifter console first, then you take the necessary screws out to get the center console out. You still undo the same connections (different connectors) to get to the navigation cubby.
That's what I was saying. I tried to quickly search for the 06+ interior gutting, but didn't really see anything on the first page of my search. Hopefully, the guy(s) who installed this in his 06+ Z can help you out. Good luck and keep us updated on your progress.
