My $100 like OEM fit NAVIGATION setup
Old Dec 16, 2009 | 04:09 PM
  #381
Miko's Avatar
Miko
Any way for an '05 cubby install with minor modification, even if i took it to an audio/video installation service and brought along the plenio? Don't want to go through the hassle of buying an '03 cubby with paint mismatch.
Old Dec 20, 2009 | 12:59 PM
  #382
A4T350Z's Avatar
A4T350Z
I just got my Plenio in the mail...However, I wont be doing the install for a while since the car is about to go into a paint booth.
3hree5ive0ero- Thank you for the software CD. I will hit you up if I come across any issues with the software install.
Old Dec 23, 2009 | 04:21 PM
  #383
BlackBZ's Avatar
BlackBZ
Default Thought you guys might want to know...
I have an '05 and over the holidays I plan on installing my Plenio. I'm going to remove the old cubby and build my own in place to hopefully get a factory look. I'm a degreed mechanical engineer and product designer for a plastics manufacturer and have access to 3d modeling software as well as cnc machines(my boss gives me free reign to use the equipment). If everything goes smooth with my design and install, I'll consider selling kits for those with Plenios, or a modified version for those without, who want to use other screens.
I plan on:
-Removing the cubby door completely for a factory look similar to those of the '06+
-adding a rear baffle and small thru holes (on the sides of the bezel to guide the sound towards the driver) This is just to increase volume, but is still not definite.
-may add a cut-out and light pipes to show the power. This is up in the air since it's blue and does not really fit well with the orange
-will add a cutout to allow use of the remote. The remote has too many quick access buttons for me to want to tap the screen.
-Will have a secure mounting bracket for the screen to either snap in, or simply bolt into from behind.
-Assuming there is enough space, I'll try to allow for mounting of the gps antenna behind the screen.
I was going to integrate an SD extension, having the slot either in the lcd bezel, or down by the seat heater switches, but there are no extenders that I could find at a reasonable price. If anyone finds one, let me know.
So if anyone thinks they may be interested in the final product or having a kit when everything's complete, hit me up. I'm pulling everything out tonight to begin measuring and sketching before I start modeling. Wish me luck...
Old Dec 24, 2009 | 04:53 PM
  #384
quakerroatmeal's Avatar
quakerroatmeal
I have uploaded the files off my sd card for the plenio / ocn8 software. Links for the plenio files will be up on on the original post / first page soon..
Old Dec 24, 2009 | 08:36 PM
  #385
BlackBZ's Avatar
BlackBZ
Looking forward to it. I've been pulling files from all over the net in hopes to get it up and running, but you sure can make life easier. Thanks for all your help!
Old Dec 25, 2009 | 05:54 AM
  #386
mw9's Avatar
mw9
If anyone is interested, I am going to sell mine, software already loaded on it. So your good to go, PM me if you are interested.
SOLD
Old Dec 25, 2009 | 07:10 PM
  #387
BlackBZ's Avatar
BlackBZ
Just got mine up and running. Added the topographical maps to show 3d terrain(mountains, hills, etc). All I need to do now is add the Nissan or 350Z logo and mount it.
Old Dec 27, 2009 | 05:51 PM
  #388
swampotter's Avatar
swampotter
Anyone who's got this to work willing to throw a guy a bone and PM me the files? I've been working on it for 2 days straight with no luck.
I get to the main screen, I select navigation, I then get a gray screen with a S-Curve background image that says "languages" on the bottom right corner of the screen.
Then get an error message "FFVIERROR: Parse error [/layer expected]".
I've got a feeling that it's because I'm trying to do this on a Mac and not a PC.
Anyone?
Old Dec 28, 2009 | 11:59 AM
  #389
o2sys's Avatar
o2sys
Anyone?
never heard of that error before. Can mac's save .txt files???
Also my cubby rattles sometimes like crazy!!!! its driving me nuts and enough for me to think about ditching the navi just to stop the rattle!!!!!
i think the navi unit is a bit too heavy for the cubby and even though i have 3m tape all around the edges its still causing it to rattle.
im going to see if i can remove the metal piece on the back of the navi where the suction cup bracket would go to see if i can shed some weight off!
Old Dec 29, 2009 | 06:55 AM
  #390
swampotter's Avatar
swampotter
Yes, they can save .txt files
Old Jan 4, 2010 | 03:51 AM
  #391
bbs350z's Avatar
bbs350z
my next mod
Old Jan 4, 2010 | 03:52 AM
  #392
mw9's Avatar
mw9
Originally Posted by bbs350z
my next mod
have one for sale if interested.
SOLD
Old Jan 4, 2010 | 06:45 AM
  #393
o2sys's Avatar
o2sys
OCN8 download available now on the first page, original post!
Old Jan 6, 2010 | 09:29 AM
  #394
swampotter's Avatar
swampotter
Thank you! Whatever I was doing wrong was fixed using your links. I had an error with the Washington POI, but I don't need it so I deleted that file. Works like a charm. Can't wait to finally get this thing installed in my Z.
Old Jan 6, 2010 | 09:59 AM
  #395
o2sys's Avatar
o2sys
megaupload was courtesy of Quakerroatmeal
Old Jan 9, 2010 | 07:49 AM
  #396
swampotter's Avatar
swampotter
In that case, I thank you both.
Old Jan 10, 2010 | 04:47 PM
  #397
greygooser151's Avatar
greygooser151
Thanks to the OP and quakerroatmeal for the upload. Maybe a dumb question, but I've loaded the files on the Plenio, and the GPS icon is "greyed out" on the main menu, I can't click it. Does that mean a hardware malfunction or do I maybe need to do some of the instructions in the OP's PDF?
Old Jan 10, 2010 | 05:48 PM
  #398
o2sys's Avatar
o2sys
yes, either the SD card cant be read, is not in correctly, or there is no GPS file
Old Jan 11, 2010 | 05:06 AM
  #399
greygooser151
thanks, i'll try a different SD card.
Old Jan 11, 2010 | 10:09 PM
  #400
greygooser151
ah, i found out the problem. My file structure wasn't set up correctly. The two RAR files make a folder called SD CARD, which I copied right on the card. I needed to copy the contents of THAT folder. Probably obvious to others, but I must have missed that.
Oh, and I also had to delete the Washington POI, iGo gives an error when starting with it loaded on.
