Lap times DB and track Videos
Old Jun 11, 2014 | 01:02 PM
  #541
scotts300's Avatar
scotts300
Originally Posted by scotts300
Track: http://www.thunderhill.com/
Date: 5/11/2010
Best Lap time: 2:05.6 with cyclone (not the shorter/faster bypass)
Car: 2003 Performance 350Z coupe
Tires: Hoosier R6, 285/295
Brakes: Stoptech 332mm front kit with PF97, OEM non-Brembo rear with Raybestos ST43
Other Modifications: TCKline DA shocks, NISMO LSD, Hotchkis sways, Intake, Plenum Spacer, Pulleys, Shockwave Exhaust, ART pipe
Lap Notes (Rain, heat, etc): Dry and cool
Attach video and pics if you want:
http://www.youtube.com/watch?v=xc9gQy5KI0w
http://www.youtube.com/watch?v=gS4HnqIRoS8
Date: 6/7/2014
Best Lap time: 2:04.5 in qual, 2:05.206 in Time Attack with cyclone (not the shorter/faster bypass)
Car: 2007 NISMO 350Z coupe
Tires: Maxxis RC1, 275 square on 9.5" RPF1s
Brakes: OEM Brembo with ST47 / ST43
Other Modifications: KW Clubsports, Wavetrac LSD, Motordyne's ART test pipe and Y-pipe, SPL FUCAs
Lap Notes (Rain, heat, etc): Dry and HOT!
Old Jun 12, 2014 | 02:49 PM
  #542
Fixxxercask's Avatar
Fixxxercask
Date: 6/7/2014
How do you like the Maxxis tires?
Old Jun 12, 2014 | 05:51 PM
  #543
scotts300's Avatar
scotts300
Very much. They seem better than take-off R6s, similar to brand new RS3 but a touch faster, and better than R888.
Old Jun 13, 2014 | 04:17 AM
  #544
03threefiftyz's Avatar
03threefiftyz
I have heard the RC1's cycle out super quick, though....
Old Jun 23, 2014 | 05:41 PM
  #545
l30thelion's Avatar
l30thelion
Default TTC 350Z Sebring 2:29.748
Track: Sebring
Date: June 22, 2014
Best Lap time: 2:29.748
Car: 2003 350Z Enthusiast, TTC Dyno Re-classed at Comp. Weight of 2940lbs/235hp
Tires: Hoosier R6 255/45/17
Brakes: Stoptech Front/Stock Rear
Other Modifications: Truechoice Koni Phase IV, OS Giken LSD
Weather: 90s, sunny, humid, very hot.
<iframe width="854" height="510" src="//www.youtube.com/embed/3ZL7sLRYTBQ" frameborder="0" allowfullscreen></iframe>
Ice Mode:
<iframe width="854" height="510" src="//www.youtube.com/embed/YL62JflSS8g" frameborder="0" allowfullscreen></iframe>
Old Nov 10, 2014 | 02:19 AM
  #546
03threefiftyz
Track: Summit Point Main
Date: 11/9/14
Best Lap time: 1:24.87
Car: 2003 350Z
Tires: 275 x 4 used up NT01's
Brakes: Stoptech 332 front/ST43 and Brembo rears/ST42
Other Modifications: Penske's, bolt-ons, etc, etc
3200# with driver
Old Nov 10, 2014 | 07:38 AM
  #547
mhoward1's Avatar
mhoward1
Date: 11/9/14
Car: 2003 350Z
3200# with driver
What track?
Old Nov 10, 2014 | 07:59 AM
  #548
03threefiftyz
edited...
Old Nov 10, 2014 | 11:11 AM
  #549
scotts300's Avatar
scotts300
^^^ was in discussion of Maxxix RC-1. Now I have data (see below)
20 HC so far, and still pulling great lap times.
Track: Laguna Seca, Monterey, CA
Date: 9-11 September 2011
Best Lap time: 1:46.1x
Tires: Hankook RS3, 285/35/18 x 4
Brakes: Stoptech 332mm front kit with Raybestos ST47, Brembo rear with Raybestos ST45
Other Modifications: TCKline DA shocks, NISMO LSD, Hotchkis sways, Intake, Plenum Spacer, Pulleys, Shockwave Exhaust, ART pipes, APR GTC300 wing
A little faster than my last outing in September (1:46.13):
Date: 1 November 2010 with NCRC
Best Lap time: 1:45.28
Tires: Hoosier R6, 285/30/18 x 4
Brakes: Stoptech 332mm front kit with PF97, Brembo rear with PF97
Date: 8 November 2014
Best Lap time: 1:44.9
Car: 2007 NISMO, partial SpecZ build, 3140# (full interior)
Tires: NEW Hankook RS3, 275/35/18 x 4 on 9.5" square
Brakes: OEM Brembo with ST43/ST45 pads
Other Modifications: KW Clubsport DA coilovers, Wavetrac LSD, SpecZ sways, stock Intake, ART pipes to MD XYZ Y-pipe, oem mid-pipe and muffler
Date: 9 November 2014
Best Lap time: 1:43.9
Tires: 15HC Maxxis RC1, 275/35/18 x 4 on 9.5" square
Old Nov 10, 2014 | 01:12 PM
  #550
03threefiftyz
Sort of surprised to see the track record for Spec Z at Summit is only a 1:24.0....T3 record is mid 1:22's by Rob Hines.
Old Nov 10, 2014 | 02:51 PM
  #551
scotts300's Avatar
scotts300
Has Rob driven SpecZ at Summit also? T3 allows better suspension and spring rates that make more sense. T3 also allows Hoosiers, which I think are faster as stickers than BFG R1, although they are only 245 on 8.5s vs 275s on 10s. I suspect SpecZ will be faster there than T3 with some more lap time, and likely faster than T2 also. I've fought to get SpecZ weights back down and allow the HP to creep back up to attract more people, but my soft-skills failed and I got my hand slapped for being honest on an this forum.
For reference, SpecZs ran 1:39s at the NASA Nats at Laguna a few weeks ago, which killed both T2 and T3 lap records there. Thunderhill 3 mile with cyclone lap record for T3 is 2:03.233, which I eclipsed in SpecZ also.
Old Nov 10, 2014 | 02:54 PM
  #552
03threefiftyz
I think the T3 cars are back on 285's now?
Old Nov 15, 2014 | 04:44 PM
  #553
SE5spd's Avatar
SE5spd
Track: Thunderhill West
Date: Oct 12, 2014
Best Lap time: 1:28.0
Car: 2007 350Z BASE, 3500lbs, base model brakes
Tires: Hankook C51 275/35/18 (18 heat cycles on them, corded on my 3rd session of the day)
Brakes: base model 2 piston, Raybestos ST45 pads
Other Modifications: swift spec R, STOCK shocks OS Giken LSD, exhaust, misc bushings and alignment tools.
Weather: 80*F?
other notes: drivers side rear SPC camber arms bushing was blown out. You can see the steering wheel is crooked a bit to the right, so wheel kept changing alignment setting making the car extremely unpredictable. Did not realize the issue until I got home and inspected the car. First time on the west side by itself, second time on the surface at all.
Old Dec 18, 2014 | 04:31 AM
  #554
2TH PWR's Avatar
2TH PWR
My best time on this track.
Toronto Motorsports Park.
Track conditions dry, overcast, 23C.
285 width Hankook TDs Roughly 20-25 heat cycles.
Old Dec 18, 2014 | 05:08 PM
  #555
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Track: Eagles Canyon Raceway, Decatur, TX
Date: Dec 6, 2014
Best Lap time: 2:06.48
Car: 2003 350Z Touring
Tires: Hankook R-S3s 265/35/18 & 285/35/18
Brakes: OEM Brembo with HP Plus
Other Modifications: popcharger, mrev2, plenum spacer, 75mm tb, obx longtubes, custom APS 2.5" true dual, KW V2, camber kits, Hotchkis sways.. no tune, full weight
Lap Notes (Rain, heat, etc): 50sºF, Dry
Old Jan 9, 2015 | 09:20 AM
  #556
scotts300's Avatar
scotts300
Getting a little more out of the street tires. . .
Date: 4 January 2015
Best Lap time: 1:43.982
Tires: Hankook RS3 with two track days on them, 275/35/18 x 4 on 9.5" square
Other Modifications: KW Clubsport DA coilovers, Wavetrac LSD, Stock sway bars, stock Intake, ART pipes to MD XYZ Y-pipe, oem mid-pipe and muffler, SPL FR/RR control arms
Old Jan 9, 2015 | 09:52 AM
  #557
03threefiftyz
You're running 45's in back with 43's up front? 3140 with driver?
Old Jan 9, 2015 | 04:03 PM
  #558
scotts300's Avatar
scotts300
I believe that's the order; I always forget, but the braking is good.
NOooooooooooooooooo, 3140 no driver. No weight reduction minus lighter wheels, two race seats, spare tire removed, but that's it. With a tune (likely add 20whp) and real tires (R1/R1S), it'd run 1:40 I think; add weight reduction, and high 1:30s I figure, maybe faster.
Old Jan 9, 2015 | 05:05 PM
  #559
03threefiftyz
Oh dang, that's heavy.
Old Jan 27, 2015 | 11:19 AM
  #560
scotts300's Avatar
scotts300
Date: 25 January 2015
Best Lap time: 1:42.7
Car: 2007 NISMO, 3140# (full interior)
Tires: Take-off 275 BFG R1 on 11" square
Other Modifications: KW Clubsport DA coilovers, Wavetrac LSD, SPL FR/RR control arms
Wheel bearing started to shimmy (can hear it at the end of the video), so only got one session with the new tire set-up, or "likely" would have run low 1:42 or high 1:41 after a few more laps.
