RevUp Oil Consumption TSB and discussion
Old 10-15-2010, 11:33 PM
  #4421
xray2
xray2's Avatar
I was just pointed to the correct giant thread on oil consumption. The Z is my weekend driver, so I just crossed over 16k miles recently.
The dealer only replaced the short block. However, the dealer did state - and I believe there is documentation - that the engine was starved of oil upon their receipt of it. Ii was down at least 5 quarts. It had not seized yet, but my oil pressure was fairly low.
I see that the TSB states long block. Is the protocol that was followed incorrect in replacing only the short block? I see that 2 years worth of posts point more headaches even if I get a long block.
Old 10-16-2010, 08:06 AM
  #4422
Wu-Watt
Wu-Watt's Avatar
Originally Posted by 06CPV35
True TP's don't care about oil, but keep an eye on those wide-band lambda sensors. They don't like oil
Lambda sensors? What???
Yesterday morning it was 1 degree celcius when I left and my car was blowing smoke like a train. When I took off I could see the smoke as I drove down the street. It was lingering in the street, to the point of embarrassment.
Old 10-16-2010, 08:55 AM
  #4423
bswanny
bswanny's Avatar
I took my Z in and I am getting a long block, no questions or fight needed. They actually called me to tell me after my OC appointment that they just ordered me a long block and its arriving in one day. Very happy about the ease and experience with this dealer.
Old 10-16-2010, 04:05 PM
  #4424
J's 350z!
J's 350z!'s Avatar
My car is doing this too I believe Its barely only been like 3000miles and ive added a 1 1/4qt
Old 10-16-2010, 05:18 PM
  #4425
06CPV35
06CPV35's Avatar
Originally Posted by Wu-Watt
Lambda sensors? What??? Yesterday morning it was 1 degree celcius when I left and my car was blowing smoke like a train. When I took off I could see the smoke as I drove down the street. It was lingering in the street, to the point of embarrassment.
aka: http://en.wikipedia.org/wiki/Oxygen_sensor
Wow, I'd get pulled over as a gross polluter in my parts.
G/L with your VQ...
Old 10-16-2010, 06:32 PM
  #4426
xray2
xray2's Avatar
Default New TSB 7/30/2010
Just so everyone is aware. I just had my vehicle repaired and returned. The TSB now states: short-block, not long-block.
New TSB as of 07/30/10:
NTB07-088d.pdf
Old 10-16-2010, 07:00 PM
  #4427
e30cabrio
e30cabrio's Avatar
Received 2,600 Likes on 2,056 Posts
What if the engine has been changed and is doing it again?
I bought my car with 10k on a new engine and it took 2 quarts in less than 3k miles after an oil change. (currently 18k on the motor more or less).
Old 10-17-2010, 06:38 AM
  #4428
06CPV35
06CPV35's Avatar
Attachment 302769
Infiniti did the same to us G35 revup vq's too: ITB08-002d and shortblocks only for G37's: ITB10-048.
If still under warranty, start consumption test with dealer. Maybe they finally did something right with this shortblock only thing now.
Old 10-17-2010, 06:42 AM
  #4429
e30cabrio
e30cabrio's Avatar
It is getting an oil change at the dealer Tuesday. I will ask then.
Thanks
Old 10-19-2010, 01:23 PM
  #4430
Dicks06
Dicks06's Avatar
So does this TSB only cover vehicles that are still under warranty? I'm about to hit 70k miles, but I've noticed considerable oil loss the past three changes. There's just so many posts in this thread. Is there someplace I can get official information on this? Thank you for any direction anyone can give me.
Old 10-19-2010, 01:36 PM
  #4431
e30cabrio
e30cabrio's Avatar
Dealer changed my oil, said oil level/mileage will be compared at next change and Nissan considers 1k /qt normal.
Old 10-21-2010, 06:43 AM
  #4432
thekinn
thekinn's Avatar
Read the first post of this thread. 1qt/1k miles is not normal.. and fails the consumption test.
Old 10-21-2010, 08:10 AM
  #4433
06CPV35
06CPV35's Avatar
Yes.
I believe Z's powertrain warranty is only 5yr/60K.
Scroll a few posts back and download the most recent revised TSB. Look at page 7.
Old 10-26-2010, 01:58 PM
  #4434
J's 350z!
J's 350z!'s Avatar
Going to start my consumption test saturday.
Old 10-26-2010, 02:20 PM
  #4435
e30cabrio
e30cabrio's Avatar
Yes.
Thanks!
Old 10-29-2010, 02:18 PM
  #4436
J's 350z!
J's 350z!'s Avatar
Has anyone had any experience with hfcs on there car while getting this test done? My car has always burned alot before i got hfcs.
Old 11-02-2010, 10:33 AM
  #4437
onagao
onagao's Avatar
So I really didn't think this day would come, but I apparently look to be joining the ranks of Oil-Consuming RevUps. After about 3K miles of driving, I apparently was WAY low on oil - so much so that my car was developing a mechanical rattle/flutter whenever I let off the throttle (the Z technician I spoke to said it sounded like the lifters were starved for oil). My oil pressure also dropped to about 3psi and wouldn't even go above 35psi at full throttle. I checked it out, and the oil was extremely dark and 3/4" below the L at the tip of the dipstick. After putting in another quart, the rattle/flutter went away, my oil pressure returned to normal values, and everything has been working fine.
I'll be taking my car in to the shop tomorrow to have my spacer removed (just to avoid any complications at the dealership). I'm also going to remove my tune and return the ECU to stock, before hitting up the dealership for the Oil-Consumption test (which they kindly asked me to come in and have performed).
Note - this is also the second time I've encountered the rattle/flutter sound prior to an oil change. I just wasn't able to identify the problem the first time.
Really couldn't be much better timing, to be honest. My warranty runs out in 6 months and I have 45,800 miles on the car. What a great time to get a new engine.
Old 11-02-2010, 11:36 AM
  #4438
Wu-Watt
Wu-Watt's Avatar
^^ Even with all those mods, you will be eligible for a replacement? You might have a tough time. And MANY replacements simply FAIL! Read up on all the failures..
I'm thinking a LS7 in a few years. Till then I add a qrt every 900 miles!
Old 11-02-2010, 12:27 PM
  #4439
J's 350z!
J's 350z!'s Avatar
Thats exactly what mine was doing. Ive added 3 qts now in 3700 miles im taking my hks exhaust and hfcs off and putting stock back on and going to the dealer to get the test done. I dont want them to say anything because of the mods.
Old 11-02-2010, 04:19 PM
  #4440
Wu-Watt
Wu-Watt's Avatar
^^ I was asked to remove my mods by a service manager that is cool. Especially the intake, and make sure you have the stok cats in..
Quick Reply: RevUp Oil Consumption TSB and discussion
