Custom Engine Grounding/Earthing Kit
Old Jan 1, 2003 | 12:26 PM
  #141
MSOsr's Avatar
MSOsr
I went to put the cover back on and noticed that the top left cover hole area already had 3 wires bolted to it so my cover now only has 3 bolts lol. Oh well I was proud that I did it myself and didn't have to pay an hour labor to someone.
Max:
Sounds like you might have hooked those 3 wires to the wrong bolt......if you look at Insaneamine's instructions, you'll see the bolt you remove on the left side (facing the engine from the front of the car) is actually on a bracket. The 3 wires attach with a bolt you put in the bracket bolt hole, not the engine cover hole.
Check it out.
Old Jan 1, 2003 | 01:15 PM
  #142
12SecZ's Avatar
12SecZ
Default lol
I told people I wasn't a DIY'er haha.
Guess I have a weekend project.
Other than that is everything correct?
Thanks!!!!!
P.S. If I can live with 3 bolts on the cover is this change necassary???
Old Jan 1, 2003 | 01:26 PM
  #143
MSOsr's Avatar
MSOsr
Check with Insaneamine.......but it seems to me it would make no difference really. You can probably leave them where they are.
Old Jan 1, 2003 | 10:29 PM
  #144
12SecZ's Avatar
12SecZ
I looked at the pictorial again and my wiring is right it's just using different bolts on the same area of the engine. I'm gonna redo it this weekend anyway to get my fourth bolt back on the cover so it looks right.
Other than that it was smooth sailinga and a good mod and a good dealing with the seller.
If I can do this mod *anyone* can!
Old Jan 4, 2003 | 06:30 AM
  #145
insaneamine's Avatar
insaneamine
Inventor
Z-Xtreme.com
Default Grounding Kit Dyno’d – This settles the debate!
One of my many fantastic customers and fellow Z fanatics sent me this today.
He took the time and effort to have his car dyno’d with and without the Grounding Kit. This should settle the long running debate of whether the Grounding Kit really works or if it is just a placebo.
"I dyno my Z today and Guess what i got 1.4 rwhp from your grounding kit!!!!!"
Behold the results… an increase of 1.4 HP!!!
I have been meaning to have this done myself. I just have not found the time. I figured it would be good for business. I have also purchased the “back-issue” of the fabled Import Tuner magazine in which they field-test the grounding kit on several cars. I’ll post the article when I get the mag.
Thanks again everyone!!!
Attached Thumbnails Custom Engine Grounding/Earthing Kit-350z_groundingkit_dyno.jpg
Old Jan 4, 2003 | 06:32 AM
  #146
insaneamine
Inventor
Z-Xtreme.com
Default His post
You can see his original post here:
https://my350z.com/forum/engine-and-drivetrain/15440-before-and-after-dyno.html
Old Jan 4, 2003 | 08:26 AM
  #147
12SecZ's Avatar
12SecZ
Default Cool Thanks
I knew my car felt more powerful, my sotp butt meter is *never* wrong.
So phhhhtt to all the nay sayers
Old Jan 4, 2003 | 10:50 AM
  #148
Bob_Red's Avatar
Bob_Red
Well the install is done. Your kit came the other day and the JWT Pop_Charger came yesterday.
Started with the Pop_Charger first and that went smoth but for the two screws that hold the heat sheld. Those are in to tight of a spot, used a 90 degree phillips to reach them. If you can change them out for sheet metal srews with a hex head do it. From everything that I have read I choose the Pop-Charger for 3 reasons. The Install, The Placement and The Cost.
After that was all set for the final tighting I started on the Earthing kit. The instructions that came with it were dead on but as I'm a little slow so I downloaded the some of the pages of the thread on the laptop and took it out in the garage for the pics. This went just like it should.
By now I had about 2 1/2 hours in tightened everything down and I was out of there.
Attached Thumbnails Custom Engine Grounding/Earthing Kit-installed.jpg
Old Jan 4, 2003 | 09:32 PM
  #149
dkmura's Avatar
dkmura
General & DIY Moderator
Default Another dyno test!
Today (1/4/03) I had the opportunity to run my track model on a chassis dyno (www.dynopro.com). The first two pulls established consistent results and curves. I disconnected the battery ground for the third and HP went down (although it was only be 2 HP). After that I reconnected the grounding kit that insaneamine supplied and sure enough, the fourth pull established a clear gain.
Max power: 244.3 HP
Max Torque: 238.4
Ran the motor to 6400 RPM
Thanks again, insaneamine!
P.S. I forgot to mention that the 'extra gift' was also much appreciated!
Old Jan 4, 2003 | 09:47 PM
  #150
12SecZ's Avatar
12SecZ
Default Forgot to add
I redid mine this weekend, glad I did, wanted it done right.
I highly recommend this mod. Heck I would have bought that blue one available now for 70 bucks if it was available when I bought mine. Someone should swoop on that! Pics of mine are on my website.
Old Jan 4, 2003 | 10:13 PM
  #151
Intrepid's Avatar
Intrepid
I ordered a silver kit from insaneamine. It was shipped promptly and received in good condition with instructions and a very valuable bonus gift. Well constructed and excellent service. Highly recommended.
Old Jan 5, 2003 | 03:11 PM
  #152
insaneamine
Inventor
Z-Xtreme.com
Default Red on red!
I have to say, those red cables look fantastic on the Redline!
Sa-weet!
Thanks again everyone.
May the New Year bring good health, much happiness, and great success to you all.
Old Jan 5, 2003 | 03:27 PM
  #153
Dolfan13's Avatar
Dolfan13
I just finished installing my kit. It was very easy to install and I could feel the smoothness in the acceleration andidle. Thanks for sending everything so quickly.
Old Jan 5, 2003 | 04:57 PM
  #154
zogan's Avatar
zogan
Default Re: Another dyno test!
Max power: 244.3 HP
Max Torque: 238.4
what were your gains?
Old Jan 5, 2003 | 07:17 PM
  #155
JimmysZ's Avatar
JimmysZ
Does anyone have silver pics installed???
insaneamine???
Thanks...
Old Jan 5, 2003 | 08:03 PM
  #156
dkmura's Avatar
dkmura
Default What were your gains?
HP gains were slight- between 2-3 HP. They were measurable however and the dyno tech said to me: "Whatever you did in there between runs made a difference".
All I did was reconnect the grounding kit to the negative side of the battery.
Old Jan 7, 2003 | 08:11 PM
  #157
redz32/bluez33's Avatar
redz32/bluez33
Default Blue one available for $70?
Insaneamine-
I would like to "swoop on that" if it's still available. I will write you email also to check. Although I am the king of DIY, I looked into it, and I'm better off buying the kit from you. Just the crimp tool purchase alone makes it worthwhile. I'm guessing you got your money's worth on that purchase.
Old Jan 7, 2003 | 09:32 PM
  #158
chazzg's Avatar
chazzg
Redline Vs Datona Blue
Damn we are good
Attached Thumbnails Custom Engine Grounding/Earthing Kit-antitperty.jpg
Old Jan 8, 2003 | 05:29 AM
  #159
insaneamine
Inventor
Z-Xtreme.com
Thumbs up Update
You guys are good! Thanks for sharing your pictures.
The sapphire blue set from the classified section is SOLD.
And,
I promise, I will post some pictures of a silver set installed this weekend.
Stay cool!
Old Jan 8, 2003 | 09:46 AM
  #160
Bob_Red's Avatar
Bob_Red
Damn we are good
Looken Gooood
I'm not sure how good we are but insaneamine has put together a professional looking product with instructions that even I can follow.
Thanks again
PS The Pop-Charger sets it off also
Now what are you going to come up with next...
TT for Dumbies
