vortech FAQ: read this before asking vortech questions
Old May 29, 2008 | 11:44 AM
  #181
MDK's Avatar
MDK
I've read through the entire thread but the question of using an oil pan spacer tap for the return doesn't seem like it's been answered yet. Is going this route bad or not?
JonnyC- were you at the cruise on the 18th? I'm the guy who had the disco party on the side of the highway. Anyway I'm putting a SC on the car now after having all that fun.
Old May 29, 2008 | 12:53 PM
  #182
JonnyC's Avatar
JonnyC
There is no definitive answer on the oil pan spacer yet :-/ Some people say it's fine, others warn against doing it.
Yup, I was there. Sending you a PM...
Old Jun 13, 2008 | 10:11 AM
  #183
c3 rolling's Avatar
c3 rolling
speaking of MPG....is it normal to go from 21 mpg N/A, 20.5 mpg Stillen stage 2....and now 27 mpg with the vortech? lol.....
Old Jun 16, 2008 | 07:31 PM
  #184
ESP350Z's Avatar
ESP350Z
Im going to do a vortech install next month. I'm getting ready to purchase the gates belt but in reading about the kit I have a question that I didnt see in the faq. With the new non revup belt layout, is there different belt length used? Per the faq, "For the original non-REVUP kit, you want a 93.5 inch belt for the stock 3.33 pulley"
Old Jun 17, 2008 | 08:03 AM
  #185
05Z33's Avatar
05Z33
Yes there is a differenet belt, it is now a 79.5 inch belt. I have the 3.12 pulley on it with no slip at all.
Old Jun 17, 2008 | 08:05 AM
  #186
05Z33's Avatar
05Z33
My mpg went from 24 to 15 after the vortech install. Maybe it's because I'm haveing too much fun with my new found power.
Old Jun 17, 2008 | 12:02 PM
  #187
MDK's Avatar
MDK
I bought a brand new kit from Vortech and it came with an 80" gates belt.
Old Jun 17, 2008 | 02:07 PM
  #188
ESP350Z's Avatar
ESP350Z
Any vendors monitoring this thread able to confirm the change?
Old Jun 17, 2008 | 02:50 PM
  #189
Cux350z's Avatar
Cux350z
hatersgonnahate
the brand new tuner kit i bought last JULY came with the new layout for nonrevups and the shorter belt. It will not utilize the stock idler pulley.
Old Jun 17, 2008 | 04:24 PM
  #190
ESP350Z's Avatar
ESP350Z
Do you know your belt length off hand. Was the belt supplied in your kit a gates belt?
Old Jun 18, 2008 | 12:19 PM
  #191
Drewer's Avatar
Drewer
I got a tuner kit also last year. There's a whole thread on the belt sizes that you can search for. The new "short" belt is a 79.5" gates belt.
Old Jun 19, 2008 | 06:38 AM
  #192
4SHIZZIL's Avatar
4SHIZZIL
Thumbs up
Best right up on both sides of the Mississippi...lol!
I got a Vortech RevUp kit (3.1 pulley but idlers offset the boos pressure? ) and it came with a Unichip...
I am getting a tuned on Thurs...
I am all about low air fuels and safety..,
Running APS Tall boy Plenum
HF Cats...
Stillen Y pipe
Stock mid pipe and muffler (quiet FTW)
Confused on running colder plugs with engine temps so low (vs. turbo)????
Debating on running 440 cc injectors??
My HP goal is 350-380 wheel.
Comments????
Old Jun 19, 2008 | 06:40 AM
  #193
4SHIZZIL's Avatar
4SHIZZIL
Default Vortech FTW!
I got a Vortech RevUp kit (3.1 pulley but the idler pulley offset the boost pressure? )
It came with a Unichip piggy back...
Vortech instructions were wrong for the fuel pressure relay ( I demand credit in the manual...lol)
I am getting it tuned on Thurs...June 26.
I am all about low air fuels and safety...
Did NOT go with Underdrive pulleys because of the gamble, so therefore I drilled into my oil pan per the Vortech instructions. about 600 miles on the car...granny driving with no leaks or issues.
HF Cats...
Stillen Y pipe
Confused on running colder plugs with engine air temps so low (vs. turbo)????
Unichip experiences?
Car put down 282 at 4K RPMs (shop could not tune Unichip)...then air fuel shot up because its not tuned after 4.5K RPMs
My HP goal is 350-380 REAL rear wheel numbers no inflated crap.
Comments????
Old Jun 19, 2008 | 08:22 AM
  #194
05Z33's Avatar
05Z33
HF Cats...
Stillen Y pipe
Comments????
Get rid of the unichip and pick up a Utec. There are a few on the classifieds for a great deal.
Old Jun 19, 2008 | 03:24 PM
  #195
ax6_g35's Avatar
ax6_g35
^+2
also go with 550cc injectors
Old Jun 19, 2008 | 07:24 PM
  #196
ekelly36's Avatar
ekelly36
is there a way to run a bigger blower to get boost a lot faster but limit the amount of boost you get up high? and by that I mean like some sort of waste gate maybe...... I dont know, I am just wanting more than 1 or 2 PSI at 2500 to 3k rpm..... but I dont want 20 at redline....... idealy I would want about 5 psi at about 3k but not go over what the 2.87 pulley would give at redline..... does anyone have a lay out of what boost you are at when going through the rpm ranges?
Old Jun 19, 2008 | 09:18 PM
  #197
JonnyC's Avatar
JonnyC
I bought a used blower with an upgrade to the Si-trim, and I was thinking I was going to have to install a pressure relief valve (http://www.928m.com/parts/boostlimitervalve.php - found much cheaper elsewhere). However, I haven't gone over 9 psi yet with a 3.33 pulley.
3 psi at 3250
5 psi at 4500
6 psi at 5000
7 psi at 5500
8.5 psi at 6000
Max out at about 9 right now
Old Jun 20, 2008 | 08:24 AM
  #198
ekelly36's Avatar
ekelly36
ok so basically with that I could run a 2.87 pulley and limit my boost to 10 psi at redline.... or even a bigger blower where decent boost (5 to 6 psi) comes on around 2500 to 3k but everything over a certain boost level gets dumped.....
Old Jun 23, 2008 | 06:38 AM
  #199
4SHIZZIL's Avatar
4SHIZZIL
Thumbs up
thanks, we will see how the Unichip performs on Thurs the 26th after a tune...if 350 wheel...im good...if anything less, Unichip FTW!
Old Jun 23, 2008 | 06:55 AM
  #200
05Z33's Avatar
05Z33
I think you will hit 350 with no problems. Did you get the 440cc injectors? I went for the 550 and put down 392whp with the 3.12 pulley. I'm using the utec though. I had a unichip when I was NA then switched to the utec and noticed a major difference in performance. I would hate to see pay for a tune twice. I really think you should invest in the utec, and sell the unichip. I sold mine on ebay for 400.
