vortech FAQ: read this before asking vortech questions
Old Jul 26, 2007 | 02:27 PM
  #101
sentry65's Avatar
sentry65
the burninator
I think either method is safe enough to use really
Old Jul 27, 2007 | 06:53 PM
  #102
BornSlippyZ's Avatar
BornSlippyZ
Great thread, It answered all my questions about the vortech. My wife's Scion has the TRD(vortech) supercharger on her car and it performs excellent. I would love to TT my Z but I think the economical choice for 360rwhp to 380rwhp is the Vortech.
Old Jul 29, 2007 | 08:16 AM
  #103
Quamen's Avatar
Quamen
Has anyone considered filling up the vortech 1/3 full of light weight oil similar to the ATI and plugging the nozzle holes in order to reduce temps?
I would think that if you changed the oil frequesntly there would be no issues with doing so. The only problem I could see would be that the stock kit doesn't have the headunit mounted level if I am not mistaken and it could possibly leak out one of the seals. I could be wrong though.
Old Jul 29, 2007 | 08:22 AM
  #104
booger's Avatar
booger
I know ATI does this . But I wouldnt know if Vortech's gear set would be made for it , or if.....like you said....if the seals could handle it .
Old Jul 29, 2007 | 11:59 AM
  #105
Cux350z's Avatar
Cux350z
hatersgonnahate
Inventoried my tuner kit:
conclusion, looks like everything i need is there EXCEPT a vacuum hose. I guess its not included in the tuner kit?
Also, got a extra part: 7U032-020 hose, 3/8" id pwrstr Looks like its for a 2006. Hope i was sent the correct kit.
where should i buy my vacuum hose?
OH ****! ****ING GREAT! i was sent a revup vortech kit! I have a 03 6mt. God damnit.
Old Jul 30, 2007 | 10:39 PM
  #106
Quamen's Avatar
Quamen
There should be no issues with the gearset holding up to it. The main concern would be the seals. I may just try it for a while with the volute and impeller off (so it doesn't get ruined if the bearing let go) running NA just to see if the bearing hold up and the seals hold. Worst case scenario is that I ruin the bearings and then I have to rebuild it.
Old Jul 30, 2007 | 11:09 PM
  #107
iStan's Avatar
iStan
ZR
Just a note:
AMS (50mm) and Flex-a-lite FLX-220B Fan fit with the Vortech.
Old Aug 3, 2007 | 07:03 PM
  #108
Cux350z's Avatar
Cux350z
hatersgonnahate
i need to get a vaccuum line for my bypass valve. seems its not included in the tuner kit. Any suggestions? I dont know if its 5/32 id or od. Jeremy suggested fuel line.
Would a hardware store have it? Advance auto parts?
Old Aug 3, 2007 | 07:10 PM
  #109
Cux350z's Avatar
Cux350z
hatersgonnahate
http://cgi.ebay.com/ebaymotors/New-S...QQcmdZViewItem
will that work?
Old Aug 4, 2007 | 11:14 AM
  #110
skaterbasist's Avatar
skaterbasist
I thought the tuner kit came with everything needed to run safe with the exception of the EMS (no SS box... need UTEC, Fcon, Greddy, etc), injectors, and fuel pump?
Old Aug 4, 2007 | 04:29 PM
  #111
Cux350z's Avatar
Cux350z
hatersgonnahate
For those that have bought the tuner kit, was the hose for the bypass valve included? I need to find one asap!
Old Aug 4, 2007 | 04:34 PM
  #112
Audible Mayhem's Avatar
Audible Mayhem
My350z
the vacuum line is not included. you will need to grab some from your local auto parts store...
1/4 inch should do but i am not sure on that...
thanks
Old Aug 4, 2007 | 04:40 PM
  #113
Cux350z's Avatar
Cux350z
hatersgonnahate
1/4? manual says 5/32. 5/32 is a tight fit. Is that id or od?
another question, the utec map sensor provides a tiny hose, do i need a reducer to tap it to the vacuum line? What kind of footage is really needed for the bypass valve's vacuum line? manual says 7' but thats quite a bit to reach from front of the plenum to the bypass valve.
i install in two weeks! trying to get everything in order.
Old Aug 15, 2007 | 01:15 PM
  #114
Cux350z's Avatar
Cux350z
hatersgonnahate
theres new pulley layout even for the 03's, are the belt sizes different?
i was given a gates: 13/16" by 80 1/8" oc
part# k060795
6pk2020
doesnt the old vortech use a 93 inch belt?
Old Aug 15, 2007 | 01:27 PM
  #115
Cux350z's Avatar
Cux350z
hatersgonnahate
https://my350z.com/forum/attachment....1&d=1187213211
new pulley layout for nonrevup motors
Old Aug 22, 2007 | 03:50 PM
  #116
Bahraini350Z's Avatar
Bahraini350Z
Just recieved my full kit today and it does have the new pulley layout, I hope this design helps with any slippage issue
Old Oct 3, 2007 | 09:27 AM
  #117
Biochem7's Avatar
Biochem7
Regular
part# k060795
6pk2020
For the 3.12 pulley with the new layout you need Gates K060790.
Old Oct 3, 2007 | 09:28 AM
  #118
Biochem7's Avatar
Biochem7
Regular
Its 5/32. Tight fit but you don't want that line popping off under boost. I suggest zip ties for all your vacuum lines.
Old Oct 3, 2007 | 10:41 AM
  #119
ecorona6's Avatar
ecorona6
Great idea!
Old Oct 8, 2007 | 11:10 PM
  #120
accordfreak's Avatar
accordfreak
great write up. one question: will the 350z non-revup kit work on the g35 non-revup?
