vortech FAQ: read this before asking vortech questions
Old Feb 21, 2013 | 03:21 PM
  #2061
wilkins81's Avatar
wilkins81
So can I use that tuner an hook up the extra fuel pump my self an everything should run fine eh?
Old Feb 23, 2013 | 08:46 AM
  #2062
TunerMax's Avatar
TunerMax
Wow, here:
Had some spare ones, feel free to use them dude. lol
Old Feb 24, 2013 | 07:56 AM
  #2063
SkyZ33's Avatar
SkyZ33
I have a Vortech V3 on a 04 350z, tuned with Orsiris and with DW 600cc injectors.
Everytime I start the car I need to give a little gas or else it would die, but this morning I forgot to give a little gas and it die, and won't let me start at all after that, any suggestion plz, thanks!
Old Feb 25, 2013 | 12:39 PM
  #2064
npr350z's Avatar
npr350z
Hi! Let me start off by saying very informative, I've only read about 1/3 of the post, I plan on once I have the time finishing reading the rest. But let me get to the meat and patotoes of it, I'm picking up a used vortech for a non rev up in a few days. It doesn't come with injectors, and I opted to not get the black box with it as I plan on going with Osiris, but if I'm using the stock pulley will I need to upgrade my injectors and fuel pump? I'm not planning on swapping out the pulley till I build the engine. Also what should I check for for wear and tear? I'm not in a rush to put it on and I plan on getting the air fuel gauge, oil temp, and boost gauge and using the greddy oil pan for the return lines and oil temp gauge. I have the kinetix intake manifold, z1 test pipes, motordyne y pipe, and nismo cat...err y back exhaust, I plan on Crawford headers, and the motordyne art pipes when I get the headers and a over bored throttle body. But will the injectors and fuel pump be able to handle low 300hp or is it better to just upgrade now? The only thing I plan on after the headers, art pipes, and throttle body is a electronic 3 inch cut out after the y pipe, and possibly switching the piping diameter too 80mm.
Old Feb 25, 2013 | 12:40 PM
  #2065
npr350z's Avatar
npr350z
Also thankyou very much
Old Feb 25, 2013 | 12:57 PM
  #2066
npr350z's Avatar
npr350z
Also is it worth picking up the revised pulley setup? Or will the standard pulley set up suffice?
Old Feb 25, 2013 | 02:03 PM
  #2067
str8dum1's Avatar
str8dum1
this is the proper order for building
1.fuel system
2.gauges
3.FI
4.anything else
do not spend a dollar on exhaust headers etc until you have fuel pump and injectors.
Old Feb 25, 2013 | 02:28 PM
  #2068
npr350z's Avatar
npr350z
So a walbro 255 and 440cc dw injectors or should I just get the 600cc for some over head?
Old Feb 25, 2013 | 02:50 PM
  #2069
- bigc -'s Avatar
- bigc -
the answers are in the other 2/3rds of the posts in this thread.
Old Feb 26, 2013 | 10:27 AM
  #2070
TunerMax's Avatar
TunerMax
Sounds like your goals will quickly outrun the 440s. Id go bigger right off the hop. And yes, the answers are all in here
str8 Laid that order down awesome also
Old Feb 26, 2013 | 10:44 AM
  #2071
Calinismo350z's Avatar
Calinismo350z
I would say just install the Vortech kit with the SS box and stock pulley, your stock injectors would be good. then save that money your gonna waist on Osiris at te end once you have build the engine and upgrad it to smaller pulley. also upgrade the injectors once the engine it's been build. you'll save time and money. and if your gonna build your engine your gonna need at least 800cc w fuel return system. if you want I have the SS box w the inline fuel pump FMU system. I would let it go for 200$+ shipping
Old Mar 24, 2013 | 12:06 AM
  #2072
TSG-Z's Avatar
TSG-Z
My pride has taken a hit for the question that I'm about to ask, so I apologize up front! However, I'm about to order the 928 impeller and for the life of me I cant recall the rotation of the impeller! I want to say it's spins clockwise, but I'm not sure and car is not with me right now.
Old Mar 24, 2013 | 07:11 AM
  #2073
Threads's Avatar
It's CCW if you're using a vortech kit made for our vehicles.
Old Mar 24, 2013 | 01:01 PM
  #2074
Triji's Avatar
Triji
Threads is correct CCW... Seems a bit counter intuitive as you watch the belt it seems to turn CW but here is a pic to put your mind at ease from 928's site.
Compare the volute in pic w/ yours... Have to turn it upside down in your mind with the way it sits in the car: http://www.928motorsports.com/parts/...h_impeller.php
Attached Thumbnails vortech FAQ: read this before asking vortech questions-ccwdirection.jpg
Old Mar 24, 2013 | 01:34 PM
  #2075
TSG-Z's Avatar
TSG-Z
Thanks guys! I'm ordering tomorrow, considering getting their 2.62 pulley as well.
Old Mar 25, 2013 | 10:57 AM
  #2076
str8dum1's Avatar
str8dum1
get a ATI crank damper pulley before bothering with the 2.62. that tiny 2.62 pulley has so little belt wrap, all it does is slip. bigger crank pulley means more belt wrap and less slip.
Old Mar 26, 2013 | 03:08 AM
  #2077
Threads's Avatar
While I agree with getting a larger crank pulley first for more belt wrap, I wouldn't necessarily say that all the 2.62 pulley does is slip. FWIW, I've used the 2.62 pulley, and my boost graph was still linear until redline. Now, was there belt slip? I'm sure there was, but the vehicle still made more boost than with a larger pulley.
Old May 6, 2013 | 05:11 AM
  #2078
TunerMax's Avatar
TunerMax
I finally fixed the belt squeal/slip and accellerated belt wear issue
If we didn't ALL fight this issue, I'd consider this a shameless self plug. However, since everyone with a non-revup Vortech kit WILL experience slip, squeal, and belt problems due to improper tension and a crappy stock design, it's more to help than it is to self promote.
If the mods feel I should not post this here please feel free to remove it.
Here's the feeler thread for newest pulley mod for this kit, please chime in with your imput!
https://my350z.com/forum/forced-indu...l#post10115727
Old May 6, 2013 | 09:18 AM
  #2079
binder's Avatar
binder
A serpentine belt is designed to slip so it doesn't damage the drive components. That is the whole point behind it. The stock design isn't crappy because it's only designed for around 400hp. Anything more then vortech uses thicker belts like they do on the kits for domestics. 8 or 10 rib belts are for higher hp application. I personally think they designed it quite well for what the supercharger was made to do.
Old May 6, 2013 | 09:54 AM
  #2080
OldManZ350's Avatar
OldManZ350
This was fix by TimRod's Vortech Belt Slip/ Noise Solution in 2004
https://my350z.com/forum/forced-indu...-solution.html
