vortech FAQ: read this before asking vortech questions
Old Apr 18, 2014 | 02:06 PM
  #2141
kilogram's Avatar
kilogram
Originally Posted by OldManZ350
With uprev you will need to upgrade.
There's always this option: https://my350z.com/forum/tuning/5921...ing-uprev.html
This extends the MAF curve for about $0.40 using uprev. Should be good for 500whp+, depending on how much he decides to attenuate the signal. The stock MAF is perfectly capable of reading big airflow, it's the ECU that's limited to 5.1v input. This squeezes more of the MAF curve into that voltage range.
I don't know what the upper limit is on the Hitachi sensor, but it's well known in domestic circles that it reads airflow to at least 6V. Maybe someday my curiosity will get the better of me and I'll hook a leafblower up to it
Old Apr 21, 2014 | 01:04 PM
  #2142
TunerMax's Avatar
TunerMax
Default V3 Dipstick....
This has been argued with me, so I seek full clarification.
Which one is the dipstick? The one with the Allen key in it, or the lower one?>
Thanks Gents!!!
Old Apr 21, 2014 | 01:07 PM
  #2143
TunerMax's Avatar
TunerMax
this is really interesting stuff, but for all that trouble, why wouldn't you just put the MAFS in a 3.5" pipe? Done.
Old Apr 21, 2014 | 01:22 PM
  #2144
Staisman's Avatar
Staisman
Thanks Gents!!!
Lower one, should be.
Old Apr 21, 2014 | 09:58 PM
  #2145
- bigc -'s Avatar
- bigc -
The lower one. Its the only one that will have a dipstick looking thing attached to it when you unscrew it from the blower.
Old Apr 22, 2014 | 02:21 PM
  #2146
kilogram's Avatar
kilogram
It's surprisingly little trouble. If I had a car that was already completely tuned and I needed more MAF capacity, I'd probably do the tube like you mentioned since compensating for it is very easy and shouldn't mess much with the tune. I'd also use the tube if I were going big boost (>20psi), since I don't know how much that plastic housing can reliably handle
If I were just in the beginning stages of tuning the car, I'd definitely do the resistors since I'd have to tune it anyway. This was one of the easiest things I've done to the car so far.
Old May 8, 2014 | 12:43 PM
  #2147
Guilty1s's Avatar
Guilty1s
I swapped a vq into my 240. My fuel system is pretty simple...
Walbro to fuel filter to fuel rails to AFPR back to tank all on 6an lines.
I have the base fuel pressure set via the AFPR and has no vacuum lines attached cause na vq's run a static fuel pressure... 52psi iirc.
Well when I hook up the Vortech, should I have a have a vacuum line attached to the fpr so it raises fuel pressure with boost?
If so, is it 52psi I set it at with or without the vacuum line connected at idle?
Old May 13, 2014 | 02:34 AM
  #2148
lethal3's Avatar
lethal3
Default Bogging ?
I just had installed a used vortech kit. 350z 2005 vq35de
On high rpm everything seems to be working fine, the boost holds and car moves strong.
The problem is that when driving slow and in low rpm car bogs heavily under full throttle from 2000-3800rpm.
Seems to run way way rich in fuel and smokes black.
This happens immediatly afther the bov closes on low rpm.
Is there a way to program the vortech boost computer manually, or are there revised maps available?
The car is in iceland. it does not show a CEL.
sidenote:
I have researched this by my extent on google and on the forum, and there are no answers other than i need a tune.
but should a tune be necessary to get the car to a useable state for the standard 3.33 pulley kit on a standard 350z.
Osiris is very expensive when it would be in my hands. about 1400$ because of crazy import laws.
Old May 13, 2014 | 11:45 AM
  #2149
350z006's Avatar
350z006
If your kit has the split second box, then your you can tune that...you may want to PM OldManZ350, he's very familair with the SS Box...
sidenote:
Old Jun 2, 2014 | 03:16 PM
  #2150
350Z_Al's Avatar
350Z_Al
Can the NPT side tap from this oil filter sandwich plate (for an oil cooler) be used to supply oil to the vortech SC?
http://www.mishimoto.com/oil-sandwic...20-silver.html
Old Jun 3, 2014 | 08:28 AM
  #2151
str8dum1's Avatar
str8dum1
of course
Old Jun 4, 2014 | 12:49 AM
  #2152
lethal3's Avatar
lethal3
Thanks. talked to OldManZ350 and got to know that the split second box is programmable, got the car to a tuner and we fixed the problem.
seems that the EU ecu and the USA ecu are different in fuel mapping so my
EU z33 got flooded with fuel on wot at 1-4psi.
Old Jun 23, 2014 | 05:12 AM
  #2153
lethal3's Avatar
lethal3
I have the V2, and it runs insanely hot. is that regular for this supercharger
Old Jun 24, 2014 | 05:17 AM
  #2154
OldManZ350's Avatar
OldManZ350
Under normal driving on a Hot day, the SC will be Hot to the Touch.
What is Insanely Hot?
Old Jun 27, 2014 | 02:18 PM
  #2155
crd00's Avatar
crd00
I am installing the v3 sci kit right now on my 350z but I ran into one issue I need clarification on. I bought my own fuel injectors and fuel pump so i dont have the fmu, my question is, what do I do with the 5/32 hose that hooks up to the bypass valve? It has a locknut, two washers and bolt included with it? Where do I run this?
Old Jun 27, 2014 | 08:06 PM
  #2156
crd00's Avatar
crd00
This is the only thing i have left to do with the install before i can start the car. Someone must of had the tuner kit to be able to clarify this
Old Jun 27, 2014 | 08:09 PM
  #2157
- bigc -'s Avatar
- bigc -
connect it to an engine vacuum source (at the manifold, tee'd off the evap line, etc.). the BPV needs a vacuum source to tell it whether to stay open or close.
Old Jun 28, 2014 | 04:37 AM
  #2158
crd00's Avatar
crd00
Will this be a sufficient area to put the hose? Its a nipple with a rubber cover over it that can be removed on the intake manifold.
Attached Thumbnails vortech FAQ: read this before asking vortech questions-img_2120.jpg
Old Jun 28, 2014 | 05:12 AM
  #2159
Conway_160's Avatar
Conway_160
That will work.
Old Jun 28, 2014 | 08:05 AM
  #2160
crd00's Avatar
crd00
The nipple i have a picture of is too small for the hose I have. Theres a small hose about 8 inches long that leaves the front of the plenum on the front left side and goes to the engine cover(down by the spark plugs) to a white nipple. Would this be fine to TEE into?
