Official STS Rear Mount Turbo Discussion Thread
Old Jan 5, 2012 | 02:24 PM
  #2721
rawley_12003's Avatar
rawley_12003
does anybody think 8:8.1 is too low for a compression?
Old Jan 6, 2012 | 10:56 AM
  #2722
rawley_12003
Does anybody know the base fuel pressure for a 350z need yo know asap
Old Jan 6, 2012 | 12:31 PM
  #2723
ace32x's Avatar
ace32x
no, im running 8.59:1
Old Jan 6, 2012 | 04:56 PM
  #2724
konrad's Avatar
konrad
Was your engine built before spun bearing and has anybody driven their z on long trips with their sts turbokit installed?
my build engine spun 2 main bearings. second build in progress
Old Jan 7, 2012 | 05:12 PM
  #2725
rawley_12003
ok so i got to crank up my car for the first time in 6 months and it sounded so amazing. i will be starting the break in monday ipp recommend 500 to 1000 miles what are your guys opinions
Old Jan 7, 2012 | 05:20 PM
  #2726
str8dum1's Avatar
str8dum1
well if IPP built your motor and recommends 500-1000, go by what they say and not what a bunch of internet mechanics say.
Old Jan 7, 2012 | 05:25 PM
  #2727
rawley_12003
oh i got you, just opinions is all.
Old Jan 8, 2012 | 07:45 AM
  #2728
streetzlegend's Avatar
streetzlegend
Ya go by what they recommend. Also do a lot of engine braking. I changed my oil about 2 or 3 times within the first 1500 miles.
Old Jan 8, 2012 | 02:23 PM
  #2729
rawley_12003
Oh ok thanks for the info guys I should get the car tomorrow hopefully.
Old Jan 11, 2012 | 12:41 PM
  #2730
rawley_12003
oh guys have a question i tried calling sts turbo but there phones are messed so i need your help well everytime my tuner gets into boost my sts oil pump blows a fuse but on idle and crusing its fine has anybody ran into this problem.
Old Jan 11, 2012 | 07:51 PM
  #2731
rawley_12003
BUMP!!!
Old Jan 11, 2012 | 08:14 PM
  #2732
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
What is the fuse size? Keep in mind that with DC the long wire all the way to the back will add resistance to the circuit, so if your pump is loaded (pumping a lot during WOT) a small fuse will blow.
I use 20A fuses with the Exa pumps.
Old Jan 12, 2012 | 05:35 AM
  #2733
rawley_12003
Sts recommend a 15amp underload it blew so my tuner used a 20amp and that blew too it only blows whenyou going into boost
Old Jan 12, 2012 | 06:25 AM
  #2734
Boosted Performance
What is the wire size (ga) going to your pump? If you are blowing a 20A fuses, that means that you are drawing 240W, and that is a lot (1/3hp) for such a small pump.
Maybe increased flow of hot oil is making the gears expand, causing gear tolerance (binding issues) issues? Get yourself an Exa pump and never worry about it again.
Old Jan 12, 2012 | 06:40 AM
  #2735
rawley_12003
Yeah I thought about going with exa pump with my car but they are like 400 on there web page is there another place to get one with a better deal?
Old Jan 12, 2012 | 07:01 AM
  #2736
Boosted Performance
Call Dynosty, they carry them.
Old Jan 12, 2012 | 07:18 AM
  #2737
rawley_12003
Ok thanks
Old Jan 12, 2012 | 10:20 AM
  #2738
rawley_12003
Well my tuning got the pump to work it was a bit of a wiring issue but its fixed now
Old Jan 14, 2012 | 11:05 AM
  #2739
rawley_12003
Ok guys I have a precision turbo 6265 that might be any good during spool up I here like a clicking noise during initial spool and when it spools faster it goes a away would I need a new turbo or rebuild it it didn't do this before my motor blew if I would have to get another turbo I have a guy with a gt35, not a gt35r for sale for 400you with no shaft play. Can you guys please help oh has anybody rerouted the intake piping to the center of the car if so can you post pics on how you did it thank you
Old Jan 14, 2012 | 06:15 PM
  #2740
str8dum1's Avatar
str8dum1
you can send it to precision to get rebuild for under 400$. i'd send it in and at least have them look at it. dont mess with any non "r" garretts.
