Official STS Rear Mount Turbo Discussion Thread
Old Apr 5, 2012 | 06:55 PM
  #2821
rawley_12003's Avatar
rawley_12003
yeah this is why i am looking at slicks. So what are you guys running on your 60ft. ?
Old Apr 5, 2012 | 07:00 PM
  #2822
rawley_12003
this is why i am looking at et slicks bias ply possibly 26x10x15 what do you guys think.
Old Apr 5, 2012 | 07:56 PM
  #2823
djamps's Avatar
djamps
With ET Streets I am 1.7's with occasional 1.6's
Old Apr 6, 2012 | 11:47 AM
  #2824
athenG's Avatar
athenG
Originally Posted by rawley_12003
Wouldnt elevation play a big part in my time? Just asking plus my rpm range is set at 6500 rpm I know its low
what RPM did you shift? I noticed on mine that shifting close to redline make a difference on my trap speed instead of shifting on my peak hp...
Old Apr 6, 2012 | 05:54 PM
  #2825
rawley_12003
just about 6500 rpm is when i shift, oh i'm looking at some 300zx tt wheels for 200 and good condition would this be a good wheel to put some et street slicks? anybody can chime in. I know the rear wheels is a 16 in. wheel with a 8 in. width.
Old Apr 20, 2012 | 04:56 PM
  #2826
rawley_12003
http://www.youtube.com/watch?v=iHdH4fUN8hA
Old Apr 25, 2012 | 11:22 AM
  #2827
rawley_12003
Has anybody done anything new to their sts turbo setup lately?
Old Apr 25, 2012 | 11:30 AM
  #2828
athenG's Avatar
athenG
can you post some #'s? look like the truck got a better launch than you.
I'll be upgrading my injector to a 560cc, mid-pipe and charge pipe in the next couple of weeks. Haven't touch my tune in 2 years so with the bigger injector I'll have re-visit my tuning skills...
Old Apr 25, 2012 | 07:02 PM
  #2829
rawley_12003
sorry i had just moved to another apt. and missed placed all my papers. But this was my first time on slicks so i know ther is more to improve on lol i will be heading back out there next month. I thought about upping boost looking for 500 hp need to upgrade my fuel pump to a aeromtive pump.
What size piping are you going with on the charge pipe, and mid pipe what are going to do with that.
Old Apr 26, 2012 | 05:50 PM
  #2830
athenG's Avatar
athenG
/\ I'm just replacing the rusty portion. I replaced my stock midpipe muffler with a bigger one. I went with the magnaflow 12216 universal muffler. Boy that made a difference in noise reduction. Injector is also in and i just started tuning the lower rpm and low boost. It start raining here in nyc so i'll continue tomorrow....
Old Apr 26, 2012 | 07:42 PM
  #2831
rawley_12003
oh nice i when i got my reroute piping in i hand sanded and coated my charge pipes flat black to help prevent from corrosion. So did that help with boost on the mid pipe upgrade or just quiet down the exhaust noise.
Old Apr 27, 2012 | 04:41 AM
  #2832
athenG's Avatar
athenG
goosgoose had this muffler and I had it for a short time but it crack (install error) so I dont know yet. I"ll start tuning today so I'll find out. It's nice to be able to know I have more fuel left to pump.. Before I had to leverage my Water/Meth to compensate for the lack of fuel... at redline my inj. duty cycle was around 93% and in the winter I had to bring down my boost to 7psi because my injector was maxed out with the colder temp...
Old Apr 29, 2012 | 06:42 PM
  #2833
rawley_12003
[IMG][/IMG]
Best time so far i think i can do a little bit better. mine is number 13. Ran a 12.3!
Old Apr 30, 2012 | 10:39 AM
  #2834
athenG's Avatar
athenG
NICE ET but 1/4 mile trap is a little low.. the 1/8 mile trap looks good though. Did you let go of the gas in the end or did you have to shift to 5th gear? did you do any any logging with this run? I try to log with my Utec every run I do so I know what RPM I shifted so I can make adjustment on my next run.
Old Apr 30, 2012 | 12:36 PM
  #2835
rawley_12003
yeah my trap is low i missed 5th gear.. so pretty much coasted to the end. I did not do any data logging unfortunately but i have been shifting at like 6k rpm to 6300 rpm everytime
Old May 1, 2012 | 07:38 AM
  #2836
athenG's Avatar
athenG
have you tried shifting at 6500rpm especially the lower gears.. I usually shift close to redline or redline on 1st and 2nd gear and that makes a difference... Base on my tq curve, I have calculated that shifting at redline in the lower gears help me land closer to my peak TQ on the next gear. I'll try to see if I still have my spreadsheet where it calculate the estimate power you can put in the ground by plugging the value of your TQxRPMxGear ratio.
edit: also 1st gear and 2nd gear rpm goes up so fast and you may think you are shifing at 6300rpm but if you do any logging you'll see that you are actually shifting only at 5900-6000rpm... This is why i shift at redline on the lower gears.
Old May 2, 2012 | 12:01 PM
  #2837
rawley_12003
oh ok yeah i talked to my mechanic/tuner and he said it was only tuned to 6300 rpm, he highly suggest suggest installed jwt spring to handly the high rev.
Old May 2, 2012 | 12:11 PM
  #2838
athenG's Avatar
athenG
/\ I'm talking about the lower gears here.. there is less load on 1st vs 4th gear. You probably not even hitting full boost on 1st. As I said, the RPM goes so fast on 1st and 2nd and you may think you are shifting at 6300rpm but in reality you are shifting at 6000rpm. anyways I think you did a good ET with your last run while just coasting in the end.
Old May 2, 2012 | 02:58 PM
  #2839
rawley_12003
yeah i will talk to my tuner and ask if he will do some data logging with me when i'm at the track next time he is usually there tuning his civic drag cars anyways.
Old May 11, 2012 | 02:49 PM
  #2840
GBoger's Avatar
GBoger
I used the apexi avc-r unit and was able to tune it to hit full boost in first and second gear...
