Official STS Rear Mount Turbo Discussion Thread
Every one that has this problem seem to have a stable idle.. My idle isn't really bad but I can see it dip about 100rpm but my Innovate WB actually read 16-18:1 A/F. Also mine only happen when I'm idling for a long time. I dont have problem when driving or doing a quick stop on a stop light.
I just looked at my spark plugs and tighten up everything.. I noticed that when I pulled my spark plugs that they are barely screwed in. I did a quick test and everything seem to be fine. I'm due for inspection this coming December so I want this fixed before then.
Update... I added some fuel on the 0% column and so far everything is stable which is pretty good. Tried to replicate my driving habit and let it idle for a good amount of time and A/F seem to be stable (A/F perefect around 14.5-14.9) now even let the car idle for 10 mins. while tuning the 0% column now I get a P0507 error...ggrrr but at least P01273 is gone. I think reving the car very high cause the P0507 error so I erased all the code now and crossing my fingers it wont go back.
I toyed with the temp correction in my UTEC a few days ago. So far, no TOO LEAN code.
P0507 Idle Speed Control System, I had this error once this summer when I had my AC on and the Idle was above 1100rpm. I reset the ECU and the error never came back until today. I didn't think the Utec temp compensation take effect under ECU control? Anyways, before the change when I rev the car my A/F was 15.2-15.5 all the way to 5000rpm so I added some fuel and now it is fixed. Did some driving without boost and A/F is stable now. I didnt really payed attention on my 0% before coz I never had any error but now that I'm thinking, I had my TP installed last March so it made my car a little lean even without boost. I guess it didnt complain in the summer but now that it is colder it start freaking out.... I'm going to do some driving this weekend and I'm crossing my fingers hoping this is the end of it... lol
/\ Mid boost? better get a WB on that right side to verify your A/F.. You A/F on boost should be well in the 11's and I dont think the ECU will even complain at 12's. Are you sure it comes from mid boost? ECU dont pop the CEL right away so it could've happen at cruising or idling. For example, I had no CEL and then grabbed my ODBII and next thing you know I see P01273 even though I dont have CEL.. Try log your A/F with no boost or do rev it and see if you are below 15:1 A/F.
For now, the motor has zero knock and no stability problems at idle, cruise, mid, or full boost, so I'm pretty sure I won't blow anything up.
My summer tires are starting to slip up everywhere anyway, so the winter tires have to go on soon, and i'm probably going to dial down my boost to my 10PSI WG-Spring. Less boost and less fun.
Maybe you need to retune your 0% column. I was running a little lean and that is why I'm getting the P01273 error so I made adjustment to my 0% column and so far it's been a few days now and hasn't come back. I did have problem with high Idle (P0507) when I reset my ECU, but after doing the idle re-learn and cleaning my MAF and TB its been stable now. I'm not worried about the P01273 anymore but I'm worried the P0507 might come back, if it does then I may need a new throttle body. I think your problem is more tune ralated.
So, what would explain my idle issues? I went through the reset procedure of the ECU, drove the car around, and still had issues when I pulled into the garage. Looking at my BOV, it will open very slightly, the idle will increase, it will close, then the idle will fall to where it almost stalls. It will continue to surge, then stumble, then surge, etc.
Basically, it seems as though the motor is starved for air trying to suck it through the turbo at idle. But if the vacuum is high enough, the BOV will open slightly and air will get sucked in. I'll have to diagnose it more in the spring, since I don't even know how logical this is.
So your Bov slightly open when just idling or below 1000rpm? Since your compressor surge didn't go away with the lighter Bov spring then you might as well go back to the original spring and see if that makes a difference.
Just curios does your BOV make a sound when you just rev your engine?
We just did a universal kit from STS on a Dodge Stealth.
It was a ton of fabrication work since it was a universal kit, but in the end it turned out looking great and netted a 105 wheel horsepower gain in at abot 6-7 psi with an auto trans.
I am looking at doing a 350 kit right now.
Here's some pics from the set-up we did on the Stealth:
Originally Posted by DanielW
sorry if this has been covered already but have you checked all your vaccum lines?
I'll diagnose this more in the spring. I just wanted to see what you guys thought.
Very nice todd. I'm wondering though - is the larger diameter of the charge pipes affecting the lag? The Z kit's charge pipes are the same diameter as the compressor housing's going up to just before the FMIC. Might not be an issue though.
Does your idle stay stable even with this error?
