Oil cooler/warmer removal.............
Old Jun 21, 2010 | 02:09 PM
  #161
DavesZ#3's Avatar
DavesZ#3
I have a question for anybody that has done this mod - what size is the rubber hose that runs from the passenger side hard pipe (#8) down to the oil cooler?
It's #2 in this diagram originally posted by Jason.
Old Jun 21, 2010 | 06:20 PM
  #162
06blueZ's Avatar
06blueZ
Just measured the OD of the metal hard pipe, and it is 13mm or 1/2 inch. Visually it looks to be the same size in and out. So the ID of the rubber hose would be 1/2 inch.
I'm going to do this mod all at once this winter. going with an aftermarked air to oil cooler with adapter using the HR oil stud, HR thermostat, etc. I think I'll switch to Stans coolant at the same time.
Old Jun 21, 2010 | 07:03 PM
  #163
06blueZ's Avatar
06blueZ
Originally Posted by QuadCam
I forgot about something I discovered several months ago...........
you can buy an HR thermostat housing. It is exactly the same as the DE housing, but it doesn't have the extra nipple on it! It is a perfect fit....same gasket and all!
about to order some parts... but before I do, does the HR thermostat come with a gasket or is it separate?
Old Jun 21, 2010 | 07:13 PM
  #164
Glex25's Avatar
Glex25
The gasket is seperate
Old Jun 21, 2010 | 07:26 PM
  #165
06blueZ's Avatar
06blueZ
Thanks for the reply... of course my luck just after I ordered the parts assuming the thermostat came with a new gasket from courtesy nissan! Hopefully they can adjust my order...
Old Jun 22, 2010 | 03:25 AM
  #166
DavesZ#3's Avatar
DavesZ#3
Thanks, the hard pipe on the outlet size looked to be about 1/2" but I just wanted to check to make sure the inlet hose was the same.
Old Jun 22, 2010 | 04:00 AM
  #167
JasonZ-YA's Avatar
JasonZ-YA
ya, coming out of the passenger side coolant log (#8) is half inch heater hose...
You may wanna check the oil cooler inlet nipple that it goes to, i don't remember what size those hoses were..
I pm'd you just now..
-J
Old Jun 22, 2010 | 10:53 AM
  #168
06blueZ's Avatar
06blueZ
350z HR engine Oil Filter Stud
[15213] STUD-OIL FILTER
Product SKU: 15213-31U00
Your Price: $6.83
So I just placed an order with Courtesy Nissan, and they removed this part from my order because it is on back order with no release date from Nissan... Has anyone bought this, or know of another part number or vehicle that would have the same filter stud?
Old Jun 22, 2010 | 11:33 AM
  #169
Glex25's Avatar
Glex25
Your Price: $6.83
I got mine like 2 weeks ago but I had to wait 2 weeks for it to come in.
Old Jun 28, 2010 | 05:49 AM
  #170
Glex25's Avatar
Glex25
Question for those that went the HR thermostat route.
Did you reuse the DE bolts for the thermostat or did you get the HR Bolts?
The HR thermostat has a higher profile and I don't feel that the DE bolts have enough thread, it has like 3-4 turns into the motor that is about it.
Old Jul 9, 2010 | 10:14 AM
  #171
specialist's Avatar
specialist
do ppl still keep the one for the throttle body connected? number (2) in the pic
because motordyne engineering put a valve on it? should i just block it off too?
Old Jul 9, 2010 | 10:19 AM
  #172
JasonZ-YA's Avatar
JasonZ-YA
Interesting? how much thicker is it? measure it off and purchase bolts accordingly by adding the mm thickness to the length required??
.........im sure at Nissan, the bolts are $2-$4 bucks each or some crazy number....you can probably just get some metric at local auto parts store....Probably like M8-1.25-XXmm......etc...
-J
Old Jul 9, 2010 | 10:24 AM
  #173
QuadCam's Avatar
QuadCam
i don't recall the HR thermostat being any thicker.....or having to use longer bolts
Old Jul 9, 2010 | 10:35 AM
  #174
specialist's Avatar
specialist
aren't the nismo thermo stat good just need to block it off that one port?
Old Jul 9, 2010 | 11:16 AM
  #175
QuadCam's Avatar
QuadCam
the nismo t-stats aren't really needed. they just open up at a lower temperature but they are many times more expensive than a brand new stock t-stat.
Old Jul 13, 2010 | 05:06 PM
  #176
Glex25's Avatar
Glex25
-J
I finally got the bolts from Nissan today and placed them side by side with the DE thermostat bolt. The Hr bolts are slightly longer not by much though but I got them for peace of mind
Old Jul 14, 2010 | 12:18 PM
  #177
bikinilust's Avatar
bikinilust
doesnt even look like a 5mm difference in length.... and bolts come in 5mm incriments.
looks like Nissan made a custom length bolt?
im sure DE bolts are fine
Old Jul 14, 2010 | 12:34 PM
  #178
JasonZ-YA's Avatar
JasonZ-YA
Yeah, I would agree that they would most likely be fine...
What is the torque spec on the FSM on the HR diagram versus the FSM Torque spec on the DE diagram???..
if the torque spec is the same then the axial tension on the bolt required is the same and they are only lengthening the bolt due to the thicker part and for more thread engagement...as you can see the shank is greater on the silver bolt over the DE bolt.....by about 3 threads..
-J
Old Jul 14, 2010 | 12:39 PM
  #179
str8dum1's Avatar
str8dum1
OMG, I used bolt from ACE hardware at $0.33 each.
are the axial loads going to be the same? what about the bearing colateral stress?
LOL, its a plain jane bolt to hold a gasketed t-stat housing down. Nissan is not making magic bolts with odd thread pitch, etc
Old Jul 14, 2010 | 12:58 PM
  #180
JasonZ-YA's Avatar
JasonZ-YA
sure it is...so whats the pressure exerted on the part......what is the joint design strength....
Nissan actually does make an odd thread pitch...........for the sizes they use typically everything is 1.25 thread pitch where the metric standard everywhere else is 1.5 or even 1.75...........Nissan uses 1.25 everywhere pretty much.....which in turn is odd against the standard.....
That plus I have a few Nissan Design engineers I have become friends with and i have been fortune to find out the grade of the Nissan Green bolts and their gold shoulder/tapered shank suspension bolts, etc....
Hey i track my car, and the last thing im gonna do is save a dollar on a bolt, thermostat housing, or anywhere really........
Is the bolt you bought from ACE hardware the typical ace hardware 8.8 , 10.9 strength rating...??? or does it even have a stamp..??
I'm not trying argue......just saying...there ARE difference and requirements...
with out knowning the design loads there is no way to tell.........
now sure, the bolt can be a grade 10.9 from nissan.......and its loaded at less than half its strength so it has a 1.5 Margin of safety.......
So then using an 8.8 would lower the Margin of safety but still be positive with an 8.8 grade bolt....
I'm an ME that deals with highly loaded fasteners of all types in the Aerospace industry.....so i tend to at least understand GLEN25's concerns on the bolt and i don't blame him for asking nor buying a bolt to ease his thoughts and concerns...
-J
