Ditched my vortech: Built motor, greddy twins, budget build: updated 9-18-2010
Old Jan 6, 2012 | 03:26 PM
  #281
Son of Mad Dog's Avatar
Son of Mad Dog
chris, I have a chainsaw if you need help mate. (plus a truck to haul **** out of the way...)
I need to get with you and see it, its been. . . 5 years since I sat in the car? (you had the vortech all of a month or so...)
Old Jan 7, 2012 | 02:03 PM
  #282
Cux350z's Avatar
Cux350z
hatersgonnahate
Whats up luke! Yeah that would be awesome. Insurance quote guy is giving me the run around.
Took the Z out to cars and coffee of the upstatelast month. Lots of nice cars were there, you ought to head up.
Old Jan 8, 2012 | 05:18 AM
  #283
suprasam's Avatar
suprasam
^^^ Chris, I got some pics from the C&C. I will post them in the media share.
Old Jan 8, 2012 | 05:28 AM
  #284
Cux350z's Avatar
Cux350z
hatersgonnahate
Theres also a bunch here
http://www.facebook.com/#!/media/set...8139531&type=1
Old Feb 13, 2012 | 04:51 AM
  #285
Son of Mad Dog
is she running "full" boost yet?
Need to talk to you man, wife approved me doing my project. Realized that ya'll might be the people to talk to about finding a z with no motor or trans. (going to use the suspension and diff parts for a locost mated to a 5.3l gm motor...) looking for <2k lbs and ~400 hp...
Old Feb 13, 2012 | 07:51 AM
  #286
Cux350z's Avatar
Cux350z
hatersgonnahate
Nope, not running full boost.
I had the wife run the engine for me yesterday while I looked under the car for oil leaks. It appears to be leaking from above the mating point of the upper oil pan and block...FML. That and the passenger side oil feed line. I just do not like having an oil leak.
350z without motor/trans...im sure that can be had. theres a pull a part 2 blocks from my house, just opened up a few months back.
Also just picked up a 2007 335i.....fun little car. Keeps my mind off the 350z for now.
Old Feb 13, 2012 | 08:43 AM
  #287
taywan's Avatar
taywan
Id hate any kinds of leaks also. That sucks man. Hope you get her all sealed up.
Old Feb 13, 2012 | 10:21 AM
  #288
str8dum1's Avatar
str8dum1
rear oil seal leaking. good luck. gotta pull upper pan to replace. I had to do mine twice because it leaked the 1st time i put my upper pan on.
Both times, with the motor in the car and a 4x4 across the shock towers to hold the motor when i removed the subframe.
Not fun
Old Feb 13, 2012 | 11:52 AM
  #289
Cux350z's Avatar
Cux350z
hatersgonnahate
Its on the front. If you go under your car and look up inline with the pressure sender there is a bolt head(pointed up, threads pointing towards intake manifold), it gets covered in oil from what looks like another bolt that is going through the front timing cover and into the block.
Not looking forward to any of it. Removing the oil feed line.......ugh
Old Feb 13, 2012 | 04:21 PM
  #290
str8dum1's Avatar
str8dum1
there are o-rings that go on the upper pan at that point i think as well. Still have to pull the upper pan regardless.
Old Feb 14, 2012 | 05:08 AM
  #291
binder's Avatar
binder
ewww, ya, those 2 orings.
Old Mar 11, 2012 | 04:19 PM
  #292
Cux350z's Avatar
Cux350z
hatersgonnahate
covers ears and:
La la la la la la la la i cant hear you la la la la la ..............ugh
Wrapped all my lines with silicone Resuce tape to help point out the source of the oil. None of them looked suspect.........oil pressure sender? Pulled it, re RTV'ed it and stuck it back in. 6 new qts of oil. Will try to test it this week before I fly out for work.
Also, just purchased the seibon wide rear fenders. 10mm wider than stock. This will allow me to run my wide rear tires and not rub ( going to cut the stock fenders. I hate seibon and their shitty fitment but the tire scrubbing is killing me too.
Old Mar 11, 2012 | 04:27 PM
  #293
JAM3Z's Avatar
JAM3Z
Phenom
Originally Posted by Cux350z
covers ears and:
Oh damn son! No going back after that!
Old Mar 11, 2012 | 06:56 PM
  #294
taywan's Avatar
taywan
Can't go to narrower tread?
Old Mar 12, 2012 | 02:57 AM
  #295
Cux350z's Avatar
Cux350z
hatersgonnahate
do what!
Old Mar 12, 2012 | 06:37 AM
  #296
taywan's Avatar
taywan
Dont wana let go of those 305s huh.
They look good on there
Old Mar 12, 2012 | 06:47 AM
  #297
binder's Avatar
binder
offset must be different on the rims. My 305's fit with plenty of room. I just rolled the fenders and now have about an inch of clearance. Maybe g35 is wider in the rear as well though.
I'd try to pull the fenders some before cutting them and doing all that body work.
Old Mar 12, 2012 | 07:38 AM
  #298
Cux350z's Avatar
Cux350z
hatersgonnahate
tread width varys by brand. My 305 hankooks fit fine, my michelins are WIDE.
Wheels are 10.5 +18
Fenders are rolled.
Cannot shave the disks since my BBK kit is only about 2mm from the spokes.
Havent read any success stories about pulling/flaring since the fender already has a crease. Not trying to do a hellaflush style flare and do not trust a phonebook.
As far as bodywork, the Z already needs it. Its got 85k miles of abuse.
Old Mar 13, 2012 | 06:34 AM
  #299
binder's Avatar
binder
oh, well I was just saying since you will be cutting them off anyways trying to pull them won't do any harm. It gets messed up just hack them off
Old Mar 13, 2012 | 07:33 AM
  #300
Cux350z's Avatar
Cux350z
hatersgonnahate
that crossed my mind.
Who knows, maybe next time i get 315 or 325 tires
