Cass007.... ver 5.0
Old Mar 29, 2011 | 07:20 AM
  #361
ttg35fort's Avatar
ttg35fort
Professional
Congratulations Chris!!!
Old Mar 29, 2011 | 07:59 AM
  #362
Glex25's Avatar
Glex25
Nice Cass congrats
How are you routing the oil return lines now?
If you got pictures that would be great
Old Mar 29, 2011 | 08:05 AM
  #363
graffkid732's Avatar
graffkid732
Congrats man.
Old Mar 29, 2011 | 10:42 AM
  #364
binder's Avatar
binder
graff kid, thanks for the info. I'll try leaving the trans in this time to save trouble.
Cass, with a built low compression engine you will see less vac under idle. Mine only idles high 13/ low 14mmhg when i'm at idle. It has been checked multiple times for leaks and nothing found.
Old Mar 29, 2011 | 10:48 AM
  #365
str8dum1's Avatar
str8dum1
thats great news! good luck with the tune
Old Mar 29, 2011 | 12:53 PM
  #366
Cass007's Avatar
Cass007
Thanks guys!! The smoke test revealed 6-8 very small leaks in various spots, nothing huge, they were all fixed.
There is some definate valvetrain noise upon startup, but the oil pressure is good and comes up immediately. Possibly cam clearences need to be adjusted. It goes away when warm for the most part, but is still somewhat noisier than previous motors always have to have some drama
Glex - I took a few pics for you and will get them posted up hopefully later tonight.
I just got the car home. 70 mile trip and oil temps were between 150*-180*F cruising and up to 200*F in stop and go traffic on the highway. The AFRs are way off right now, so no boosting till I sort out when/who is tuning. I am still running the ViPEC though.
Old Mar 29, 2011 | 02:16 PM
  #367
binder's Avatar
binder
all my engines have been noisy up top. I never thought much about it.
Old Mar 29, 2011 | 03:15 PM
  #368
jeffie7's Avatar
jeffie7
Depending on what items you have in your head, yeah they get can loud. My built civic sounded like a spray can with marbles rattling around when starting it up.
My Trailblazer with the stock inline 6 4.2 also sounds like *** when cold.
Old Mar 29, 2011 | 09:11 PM
  #369
Alberto's Avatar
Alberto
Cranky FI Owner
Congrats man, remind me what block did you go with and who did the assembly?
This is awesome Im truly happy for you. I hope you have a minimal drama spring & summer
Old Mar 30, 2011 | 06:03 AM
  #370
Cass007's Avatar
Cass007
Sent you a PM.
The block was from a used DE that was said to be in fine running condition... it was an oil burner, but was suitable for use as a core.
Old Mar 30, 2011 | 07:39 AM
  #371
Driven1's Avatar
Driven1
Professional
Congrats Chris. Im stoked for you man.
Old Mar 30, 2011 | 10:06 AM
  #372
Cass007's Avatar
Cass007
Thanks Robbie... you still have the sweetest looking car in the Mid-A IMO.
For Glex:
Drivers side: Cass007.... ver 5.0-2011-03-29_12-38-12_391.jpg Pass side: Cass007.... ver 5.0-2011-03-29_12-38-31_937.jpg
Just drilled and tapped the upper pan just below the windage tray and bought a solid piece to cover the the drivers side hole in the oil pan and a fitting that had the correct size/thread for the Defi oil temp sensor to go in the passenger side of the oil pan (you can see this in the second pic).
Old Mar 31, 2011 | 08:40 AM
  #373
Glex25's Avatar
Glex25
Let me know if you run into the smoking on deceleration.
Does it have enough downward angle for it to be gravity returned?
Old Mar 31, 2011 | 09:15 AM
  #374
Cass007's Avatar
Cass007
Will do. Yes, they have enough angle to be gravity fed and they should flow at least as well as the regular kit setup. Plus, these hoses shouldn't swell like the stock hoses did.
Old Mar 31, 2011 | 09:30 AM
  #375
rh_334's Avatar
rh_334
Soon there will be another option for APS owners to fix this. Im testing a set now.
Old Mar 31, 2011 | 06:04 PM
  #376
Sylvan Lake V35's Avatar
Sylvan Lake V35
I have a buddy that has the same set up with his JWT TT kit and he dosent smoke at all he ran it for 2-3 years like that.
Good to hear you are running again, my built engine was fairly noisy as well with C2s JWT springs they had the clearances checked at least twice now!!! The only upside to multiple engines each time I do something I missed the last time or change/check things I didn't like.
Old Apr 1, 2011 | 10:14 AM
  #377
str8dum1's Avatar
str8dum1
thats the truth!
Old Apr 1, 2011 | 12:54 PM
  #378
ajcool2's Avatar
ajcool2
Congrats man. I saw you all working on the car the other day. Glad its running again.
Old Apr 1, 2011 | 04:44 PM
  #379
Cass007's Avatar
Cass007
The tentative diagnosis is that I have a bad timing chain tensioner on the passenger side. Not valve lash related.
Got the new ViPEC firmware update today and made some decent power. It drives smoother than ever, tuner said something about it being in closed loop mode until one of three triggers change it to open loop during acceleration... most of this is lost on me.
Still need to get the oil cooler installed, but oil temps never got over 220*F while on the dyno. I will be running Brad Penn 10W30 right now and see how it holds up as it gets warmer outside. It came highly recommended by several places and used to be known as Kendall GT Race Oil before Kendall got bought out by a larger company and changed the formula.
http://www.bradpennracing.com/Produc...SAE-10W30.aspx
Old Apr 1, 2011 | 05:04 PM
  #380
Barnabas's Avatar
Barnabas
National Z Club President
let me know when you come back down this way so we can meet up
