Dynosty: Haltech 350Z Pro Plug-In - OEM ECU Replacement
Old Apr 3, 2013 | 12:09 PM
  #301
_Dolle_'s Avatar
_Dolle_
Originally Posted by jerryd87
ahhhh that explains alot interesting is it the tune or simply the unit though?
I think it's hardwareproblem.
Ive spoke to Adam at haltech,hal at dynosty and ray at czp about this problem but without progress.
I hope they are working on it.
Or else i have to buy an used old platinum pro against my will.
Old Apr 8, 2013 | 09:59 PM
  #302
R6n350GT's Avatar
R6n350GT
I have got one of these new Haltechs to try and fix my car not starting after build issues.. Had competition clutch s2 initially and was getting cam angle sensor issues and crank position sensor issues so Haltech said i need better quality flywheel as the notches are not being picked up by the sensor.. so i ask around and 2 friends have the same clutch and ecu (gtm exedy) so i buy that.. So in goes the new clutch and 3 new sensors (cams/crank) and SAME issue. Haltech are saying you have to use stock flywheel as the stand alone unit will not tolerate flywheel not being perfect.. ANYONE had the same issues???
Old Apr 9, 2013 | 04:48 AM
  #303
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Have you scoped and inspected the cam and crank signals at the ECU?
Old Apr 9, 2013 | 02:11 PM
  #304
R6n350GT's Avatar
R6n350GT
We scoped the cam signals and they are syncing (both sensors replaced)
It is not picking up crank signal, stock sensors and brand new sensor tried
Even tried wiggling the sensor around and spacing it out while it was cranking..
It wont even run on stock ecu but at least it tries to fire, same with stock ecu + Utec (has a friends map on it with same turbo setup but 600cc injectors (i have 800).....
It initially ran on competition clutch and the utec for 2mins, we bled radiator and it rpm just dropped during the processed, stalled and never started since.
Haltech are trying to tell me that only a stock flywheel will work
Old Apr 11, 2013 | 12:39 PM
  #305
Dynosty's Avatar
Dynosty
Thanks for the sales!
Old Apr 15, 2013 | 12:18 AM
  #306
_Dolle_'s Avatar
_Dolle_
Check the ground on the main engine harness.. it has to be connected to make the sensors working.. It's located on top of the timingcover..
I had the same problem once.. i connect the ground and then it fired right up
Good luck
Old Apr 15, 2013 | 05:13 AM
  #307
Dynosty's Avatar
Dynosty
Did you check for good power and ground at the sensor?
Old Apr 17, 2013 | 11:14 AM
  #308
Dynosty's Avatar
Dynosty
Old Apr 19, 2013 | 10:14 AM
  #309
Dynosty's Avatar
Dynosty
To the top for Friday
Old Apr 22, 2013 | 12:07 PM
  #310
Dynosty's Avatar
Dynosty
Good afternoon! Great Product
Old Apr 29, 2013 | 10:18 AM
  #311
Dynosty's Avatar
Dynosty
Up for a Monday
Old May 1, 2013 | 10:16 AM
  #312
Dynosty's Avatar
Dynosty
Thanks for the orders!
Old May 6, 2013 | 11:09 AM
  #313
Dynosty's Avatar
Dynosty
Old May 8, 2013 | 10:46 AM
  #314
Dynosty's Avatar
Dynosty
bump
Old May 13, 2013 | 01:41 PM
  #315
Dynosty's Avatar
Dynosty
Old May 23, 2013 | 06:11 AM
  #316
Dynosty's Avatar
Dynosty
Old May 27, 2013 | 07:43 PM
  #317
Juztin's Avatar
Juztin
Any VQ35HR luv yet? Apologies guys I tried looking in the VQ35HR section but didn't see a post concerning the haltech. Can you give an update on the haltech vq35hr support roadmap?
Old May 28, 2013 | 04:59 AM
  #318
rcdash's Avatar
rcdash
^ I hope you guys get a positive response from Hal because I am really impressed with the functionality for my DE motor. I know Hal has gotten the older Haltech (that keeps the stock ECU for drive by wire) to work on the HR. For the plug in replacement, with a custom harness and symmetric throttle control, I think it should be possible...
Old Jun 14, 2013 | 10:21 AM
  #319
Dynosty's Avatar
Dynosty
I checked in with Haltech on the VQ35HR pro plugin and VQ37... still in progress, but without an ETA. Will post more as it becomes available.
We do offer a custom patch harness option for the VQ35HR to make the Haltech work. Please give us a call to discuss, 502-384-8882
Old Jun 14, 2013 | 12:43 PM
  #320
Boosted Performance's Avatar
Boosted Performance
Hal, do you know if the VQ37 unit will be a piggyback, like the earlier version for the DE?
