Another built motor Vortech dreamer thread.
Old Feb 5, 2015 | 10:36 AM
  #321
OldManZ350's Avatar
OldManZ350
Take the belt up 1/2 turn.
Originally Posted by meanz
We are here at dynosty. Hal has been tuning on the z for a while now. Picked up 30hp over baseline on old tune. Most of the gains are above 5500rpms. Seeing some belt slip. Only hitting 20-21psi with this new cog. Numbers are low compared to what I dynoed on before at Cin. He did say that my numbers are kinda unheard of on his dyno with a blower. No final numbers yet, we all took lunch.
Old Feb 5, 2015 | 12:53 PM
  #322
meanz's Avatar
meanz
https://www.youtube.com/watch?v=G_oP...ature=youtu.be
Went from 502 baseline to 565 when finished. Little under 6500rpms @20psi. I am seeing slip obviously. Gonna try to cure this on my own this week. Gonna redyno on cins so I can get an accurate reading of my gains from the SI blower to this t trim.
Old Feb 5, 2015 | 03:02 PM
  #323
Conway_160's Avatar
Conway_160
Damn that sucks that your only seeing 20Psi at 6500. Are you going to move your rev limit up to see more boost once you get your belt slip fixed? Are you getting retuned at Cin or just dyno'd?
Old Feb 5, 2015 | 03:15 PM
  #324
meanz's Avatar
meanz
Rev is set to 7200ish. I'm seeing 22 on highway pulls.. Just dyno runs at Cin.. No more tuning.
Old man, are you supposed to be able to see the bracket flex? Columbo told me his moved s lot. But I didn't see any with mine.
Old Feb 5, 2015 | 03:22 PM
  #325
OldManZ350's Avatar
OldManZ350
Ya, at the 20psi the bracket is flexing. And Yes you should be able to see it flex under load. It's does not take much to cause belt slip.
When Driving how does the car feel compared to before?
Got a pic of the dyno? that will help.
Old Feb 5, 2015 | 03:26 PM
  #326
Conway_160's Avatar
Conway_160
So if you get your slip fixed and your seeing 4-5 more psi how bad will it affect your tune?
  #327
meanz's Avatar
meanz
Car feels like it pulls little bit harder up top for sure. Still seeing 22 on highway..
Old Feb 5, 2015 | 03:28 PM
  #328
OldManZ350's Avatar
OldManZ350
Did hal have anything to say about your belt slip?
Old Feb 5, 2015 | 03:30 PM
  #329
OldManZ350's Avatar
OldManZ350
Good Video.......Great to have.
Bracket is flexing Big Time.....
How to you plan to stop it?
I see you got the GTM pulley on.
350z vortech - YouTube
  #330
meanz's Avatar
meanz
Old Feb 5, 2015 | 03:34 PM
  #331
meanz's Avatar
meanz
Which way is it flexing? Because honestly I can't even tell that it is... I am half blind though lol. I really didn't think that it was.
Old Feb 5, 2015 | 03:37 PM
  #332
meanz's Avatar
meanz
Oh and I don't have the GTM pulley on yet. It's in my trunk right now. I just have a slightly different belt configuration.
Old Feb 5, 2015 | 03:47 PM
  #333
OldManZ350's Avatar
OldManZ350
It is hard to see because the camera is moving.
But it flexes toward the front of the car.
It does not take much at all to get less tension on the belt and ten get belt slip.
When it flexes forward, it makes the distance shorter and then the belt gets loose.
You MUST have NO Flex at all.....
Let me help you fix it!
  #334
OldManZ350's Avatar
OldManZ350
Can you tell me again , what is your belt and pulley specs?
Crank, serp, and cogs please.
Old Feb 5, 2015 | 03:55 PM
  #335
meanz's Avatar
meanz
2.87 pulley
6.12 crank
34/26
7k
Old Feb 5, 2015 | 03:59 PM
  #336
OldManZ350's Avatar
OldManZ350
Intercooler?
How is your Air filter routed, and Air Filter size?
Old Feb 5, 2015 | 04:05 PM
  #337
meanz's Avatar
meanz
I don't have the dimensions right now but it's a vibrant intercooler rated to 850hp I think. Intake comes off the blower and goes through the core support. Big cone filter sitting behind the intercooler. I did see another setup that Iiked on triji car at dynosty that prolly gonna do.
Old Feb 5, 2015 | 04:08 PM
  #338
meanz's Avatar
meanz
If your that confident that it is flex, I'll take your strut. If I don't see an increase in boost, I'll send it back.. Really don't want to throw more money around I don't have.
Old Feb 5, 2015 | 05:16 PM
  #339
Classy's Avatar
Classy
I have watched the video 3 times, I could not see any flex.
I can't find the video and it is pissing me off, but there is a video of a ls swapped rx7 track car with a supercharger and he put a go pro in his engine bay while driving it on the track and that belt was going wild when he was pushing it. I think going for better belt wrap will be more beneficial than a rod to prevent flex.
Old Feb 5, 2015 | 05:37 PM
  #340
Conway_160's Avatar
Conway_160
Im betting tim's radius rod will help alot, may mot fix it completely but it will be better than nothing.
